MMU Faults when launching Ubisoft Connect via Lutris
Hello, whenever I launch Ubisoft Connect via Lutris, my display lags five or six times for short intervals of about 5 seconds. dmesg reports MMU faults. I am running an Arch Linux system with a GTX 1650 and have appended some logs describing the system and the dmesg output. I have also checked whether the issue appears when using the open source DKMS modules or the proprietary ones, it appears in both. Please note, that the dates in the logs are a bit older, that is because I tried to contact support via the e-mail, but I did not get a response. However, the issue also appears with the current updates.
~ inxi -a
CPU: quad core Intel Core i7-4770 (-MT MCP-) speed/min/max: 3896/800/3900 MHz
Kernel: 6.12.28-1-lts x86_64 Up: 6m Mem: 3.88/31.28 GiB (12.4%)
Storage: 1.14 TiB (34.5% used) Procs: 293 Shell: fish 4.0.2 inxi: 3.3.38
~ inxi -G
Graphics:
  Device-1: NVIDIA TU116 [GeForce GTX 1650] driver: nvidia v: 570.144
  Display: wayland server: X.org v: 1.21.1.16 with: Xwayland v: 24.1.6
    compositor: gnome-shell v: 48.1 driver: X: loaded: nvidia
    unloaded: modesetting gpu: nvidia,nvidia-nvswitch
    resolution: 1920x1080~60Hz
  API: EGL v: 1.5 drivers: nouveau,nvidia,swrast
    platforms: gbm,wayland,x11,surfaceless,device
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 570.144
    renderer: NVIDIA GeForce GTX 1650/PCIe/SSE2
  API: Vulkan v: 1.4.313 drivers: nvidia surfaces: N/A
  Info: Tools: api: eglinfo, glxinfo, vulkaninfo gpu: lact,
    nvidia-settings, nvidia-smi x11: xprop,xrandr
~ aura -Qs lutris
local/lutris 0.5.19-5
    Open Gaming Platform
~ aura -Qs nvidia
local/nvidia-open-lts 570.144-6
    NVIDIA open kernel modules
~ aura -Qs nvidia
local/nvidia-lts 1:570.144-6
    NVIDIA drivers for linux-lts
# dmesg | less
[  305.124474] NVRM: Xid (PCI:0000:01:00): 31, pid=5286, name=CrGpuMain, Ch 00000014, intr 00000000. MMU Fault: ENGINE GRAPHICS GPC0 GPCCLIENT_PROP_0 faulted @ 0x0_003f3000. Fault is of type FAULT_PDE ACCESS_TYPE_VIRT_WRITE
[  312.233491] NVRM: Xid (PCI:0000:01:00): 31, pid=5486, name=CrGpuMain, Ch 00000012, intr 00000000. MMU Fault: ENGINE GRAPHICS GPC0 GPCCLIENT_PROP_0 faulted @ 0x0_003f3000. Fault is of type FAULT_PDE ACCESS_TYPE_VIRT_WRITE
[  319.038025] NVRM: Xid (PCI:0000:01:00): 31, pid=5516, name=CrGpuMain, Ch 00000012, intr 00000000. MMU Fault: ENGINE GRAPHICS GPC0 GPCCLIENT_PROP_0 faulted @ 0x0_00213000. Fault is of type FAULT_PDE ACCESS_TYPE_VIRT_WRITE
[  326.461243] NVRM: Xid (PCI:0000:01:00): 31, pid=5551, name=CrGpuMain, Ch 00000012, intr 00000000. MMU Fault: ENGINE GRAPHICS GPC0 GPCCLIENT_PROP_0 faulted @ 0x0_003f3000. Fault is of type FAULT_PDE ACCESS_TYPE_VIRT_WRITE
[  343.251765] NVRM: Xid (PCI:0000:01:00): 31, pid=5579, name=CrGpuMain, Ch 00000012, intr 00000000. MMU Fault: ENGINE GRAPHICS GPC0 GPCCLIENT_PROP_0 faulted @ 0x0_003f3000. Fault is of type FAULT_PDE ACCESS_TYPE_VIRT_WRITE
[  355.235212] NVRM: Xid (PCI:0000:01:00): 31, pid=5608, name=CrGpuMain, Ch 00000011, intr 00000000. MMU Fault: ENGINE GRAPHICS GPC0 GPCCLIENT_PROP_0 faulted @ 0x0_003f3000. Fault is of type FAULT_PDE ACCESS_TYPE_VIRT_WRITE
