Hey everyone.
I’ve been working with the movidius intel stick and one of the things ive been having difficulties with is training my own network that will run on it. I’m getting lots of errors.
What I’m looking to do is train the Kitti vehicle example found here https://github.com/nvidia/digits/tree/master/examples/object-detection , but instead of training it for use on detectnet. I would like to train it for use with Mobilenet. I’ve found two mobilenet prototxt files, one for MobilenetV1 and the other for MobilenetV2. Can someone help me understand what I need to do to train the new network for Mobilenet?
MobilenetV1
https://gist.github.com/kndt84/a9af7b1bfed3324de13ae95cceaf6766
MobilenetV2
https://gist.github.com/kndt84/6492cc0a082245e99a46c0ae8ff25492
It really doesn’t matter to me at this point which, as I just need to get one of them.
I set everything up the same way I do for the detectnet model. Except, 1) I’ve reduced the image size by 25% and 2) I’m inserting the Mobilenet model description instead of the detectnet model description.
The first error I’m getting is
File "/usr/local/lib/python2.7/dist-packages/digits/scheduler.py", line 512, in run_task
task.run(resources)
File "/usr/local/lib/python2.7/dist-packages/digits/task.py", line 189, in run
self.before_run()
File "/usr/local/lib/python2.7/dist-packages/digits/model/tasks/caffe_train.py", line 220, in before_run
self.save_files_generic()
File "/usr/local/lib/python2.7/dist-packages/digits/model/tasks/caffe_train.py", line 632, in save_files_generic
network = cleanedUpGenericNetwork(self.network)
File "/usr/local/lib/python2.7/dist-packages/digits/model/tasks/caffe_train.py", line 1710, in cleanedUpGenericNetwork
"Don't leave inner_product_param.num_output unset for generic networks (layer %s)" % layer.name
AssertionError: Don't leave inner_product_param.num_output unset for generic networks (layer fc8
So I found the inner_product_param{} in the model description. I assumed I should set the num_output to 1 as this is only using 1 class, vehicle. Then the next error I get, when I set num_output to 1 is
Memory required for data: 19267712
Creating layer train-data
Creating Layer train-data
Top blob 'data' produced by multiple sources.
Opened lmdb /jobs/20180723-171705-254f/train_db/labels
And honestly, I have no idea where to go from here.
Any help would be much appreciated.
Michael
