MoBo BIOs
Chassi: Fractal Design Define XL R2 Black
PSU: Cooler Master V Series 1000W
MoBo: MSI X779A-GD45 PLUS
CPU: Intel Core i7-3930K 3.2GHz, 12MB water coold
GPU: 2x Gigabyte GTX TITAN
HDD: 1x Samsung SSD 840 series 500GB, 2x SATA2 500GB
RAM: 4X8GB Kingstone 32GB 2133MHZ DDR3 HYPERX BEAST
so i wonder about the bios on the mother board as they were on GEN2 first but i changed it to GEN3. but then the PCIE latency time was set to 32MB Clock speed wich is the lowest.
Question is what does the PCIe latency do if i crank it up and how much can i crank it up if i do? as i gues it gives better results if its higher?
See: http://www.techarp.com/showfreebog.aspx?lang=0&bogno=138
Lol was posting every fancy part of your computer actually relevant to your question or do you just like posting fancy parts you bought?
