Model Evaluation of Detectnet_V2(TLT2.0)
We are using DetectNet_V2 in TLT2.0 to evaluate the model.
I would like to check the AP50 for each class. In that case, should I change the value of the minimum_detection_ground_truth_overlap value to 0.5?
Also, if I want check map50, should I set it to 0.5 for all classes?
Yes. This parameter means the minimum overlap of a ground truth and a detection bbox to consider the detection to be a true positive.
Thank you for your answer.
