I was trying to run replicator, I realized that the objects model paths on yaml files in composer parameters or even the paths used in video tutorials on Nvidia website for replicator are not matching the model paths on Nucleus. Probably these addresses are changed after updating to the newer version of Isaac Sim.
Hi there,
it might be that the <mount>
is not set correctly, can you check if this Paths description helps.
Otherwise can you provide the steps to reproduce the issues you are facing?
Best,
Andrei
