The downloaded Mandarin rmir ASR Model i.e. asr-citrinet-1024_zh_cn-streaming.rmir with Riva2.0 sdk having 588.9MB is optimized to 1.2GB after following riva optimization steps.
Steps are as follows-
- Changed the flag of config.sh .i.e. use_existing_rmirs=true
- Changed the langugage code to "zh-CN"
- Run riva_init.sh
- Run riva_start.sh
Because of its bigger size, I can not use this because systems hangs.
Hardware - GPU : Nvidia Xavier NX
Hardware - CPU : Nvidia Xavier NX
Operating System : Jetpack4.6
Riva Version : 2.0
Hi @user115721
Thanks for your interest in Riva
Apologies for the delay
I will take this further with the team and provide update soon
Thanks for your patience
Hi @user115721
I have some inputs from the team
Using rmir file has larger batch size values,
So we don’t recommend using these larger batch size values rmir’s for Embedded.
On embedded, we have created the model repositories which can be directly deployed and are with Batch size 1.
For Embedded we recommend using embedded specific model repositories (BS = 1). Refer to this document here for loading non-English Language models on embedded : Best Practices — NVIDIA Riva Skills
