I train a model and prune it.
I run it in my xavier but founds that it runs slow a lot .
so why this happens
Hi lc5104hit,
Pleases maximize the device performance with the following commands first:
$ sudo nvpmodel -m 0
$ sudo jetson_clocks
does not work.
Is there any rules that I should follow?
I really puzzle about this result
Have you tried the non-pruned model on Xavier first?
Is it also slow?
If yes, the performance issue should originate from the frameworks you used.
Please share which framework do you use for inference that we can give you a further suggestion.
If not, there is some issue in your pruning process.
Please share the tool or source you used for the pruning.
the non-pruned model in xavier is about 70ms,
actually the pruned model in xavier is about 150ms
I think may exist some bug in trtexec tool.
I write inference code myself and found the model speed is okey now.
Thanks for your kindly reply.
best wished
Could you share the non-pruned and pruned model with us?
We want to reproduce this internally.
I cannot sent a file larger than 4mb,
T_T
Could you update to a third-party drive and share the link with us?
Hi lc5104hit
Is this still an issue to support?
I try baiduyun
Do you have the link of baiduyun?
链接: 百度网盘-链接不存在 密码: 6c7q
