Model swapping on limited GPUs (2x L40) with NIM Operator 3.1.2: load-on-demand, idle unload, and eviction priority
Hi all,
We’re evaluating NVIDIA NIM for a multi-model production deployment where we have more models than GPUs. We’d like to know the recommended pattern for swapping models in and out on demand.
Environment
  • 2 GPU nodes, one NVIDIA L40 each, so only 2 models can be resident at once
  • Many models served in production, so they must be loaded on first request and unloaded when idle
  • NIM Operator v3.1.2, using NIMCache and NIMService custom resources
  • Kubernetes version: [fill in]
  • Models in scope: [list sizes/architectures, e.g. 8B LLM, embedding, reranker]
What we’ve measured (3 runs on a test server)
  • Load time: about 1 to 2.5 minutes (average ~103 s), higher on a cold start
  • Unload time: about 30 s
  • Swap time varies with model size and architecture
Questions
  1. Swap pattern. What is the recommended approach for load-on-first-request and unload-when-idle on a fixed GPU pool? Is it scaling NIMService replicas to 0 and back, or something else?
  2. Operator support. Does NIM Operator natively support scale-to-zero, idle timeouts, or priority classes? If not, what should we use to decide which model is evicted when both GPUs are occupied (e.g. Kubernetes PriorityClass and preemption, KEDA, or a custom controller)?
  3. Run:ai. Is NVIDIA Run:ai the recommended scheduler for this (queues, priorities, fractional GPUs, GPU memory swap)? How does it integrate with NIM Operator, NIMCache, and NIMService?
  4. Reducing swap time. Are there NIMCache optimisations or pre-warming techniques that bring load time down? For example, caching the model profile or TensorRT engines on a PVC, keeping weights on local NVMe, or keeping a warm standby. Which part of the ~103 s is typically dominant: image pull, weight load, or engine build or compile?
  5. Licensing. Which orchestration or scheduling features come with the NVIDIA AI Enterprise licence, and which should we evaluate for this use case?
