ModelExpress: Distributing Model Artifacts at the Speed of Light
Originally published at: ModelExpress: Distributing Model Artifacts at the Speed of Light | NVIDIA Technical Blog
Every byte moved has a cost. As model checkpoints grow to hundreds of gigabytes or even a terabyte, that cost adds up quickly. To make things even worse, moving these model weights around the cluster is extremely common. For instance, a cold start may pull weights from remote storage into GPU memory; autoscaling and rolling…
