I have a system with a Quadro P620 with 4 mini-dp. I want to have an X server with a resolution of 1280x1024 showing at the DP-4 output, and I want it to be active regardless of whether there are connected screens or not.
In order to do that, I’ve connected a screen (with a native resolution of 1280x1024) and I’ve used xvidtune to get the modeline. Then, I’ve written the following xorg.conf:
Section "ServerFlags"
Option "DefaultServerLayout" "Layout0"
Option "AllowMouseOpenFail" "false"
Option "Xinerama" "0"
EndSection
Section "ServerLayout"
Identifier "Layout0"
Screen "Screen0"
Option "Clone" "off"
Option "StandbyTime" "0"
Option "SuspendTime" "0"
Option "OffTime" "0"
Option "BlankTime" "0"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
Option "ModeValidation" "AllowNon60hzmodesDFPModes, NoEDIDDFPMaxSizeCheck, NoVertRefreshCheck, NoHorizSyncCheck, NoDFPNativeResolutionCheck, NoMaxSizeCheck, NoMaxPClkCheck, AllowNonEdidModes, NoEdidMaxPClkCheck"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
Horizsync 30-83
VertRefresh 56-76
Option "DPMS"
DisplaySize 339 271
Modeline "1280x1024" 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync
Option "PreferredMode" "1280x1024"
Option "UseEDID" "false"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "off"
SubSection "Display"
Depth 24
Virtual 1280 1024
Modes "1280x1024"
EndSubSection
Option "UseEDID" "False"
Option "UseEDIDFreqs" "False"
Option "ExactModeTimingsDVI" "True"
Option "ModeDebug" "True"
Option "metamodes" "DP-4: 1280x1024 +0+0"
Option "ConnectedMonitor" "GPU-0.DP-4"
Option "UseDisplayDevice" "GPU-0.DP-4"
EndSection
But everytime I restart the X server, the modes are ignored and it reverts back to 1024x768. Here’s the output of the log:
[code]
[2064792.574]
X.Org X Server 1.20.1
X Protocol Version 11, Revision 0
[2064792.574] Build Operating System: 3.10.0-862.2.3.el7.x86_64
[2064792.574] Current Operating System: Linux CCTVRADAR 3.10.0-957.el7.x86_64 #1 SMP Thu Oct 4 20:48:51 UTC 2018 x86_64
[2064792.575] Kernel command line: BOOT_IMAGE=/vmlinuz-3.10.0-957.el7.x86_64 root=UUID=1d0eefaa-276a-499e-9cde-04d602401e51 ro crashkernel=auto rd.md.uuid=aa92f21a:a457d6b2:28c6fb88:21fb9377 rd.md.uuid=0d826ec3:506b5a81:b7e61d2f:e825a56c rhgb quiet LANG=es_ES.UTF-8
[2064792.575] Build Date: 24 September 2018 06:30:46PM
[2064792.575] Build ID: xorg-x11-server 1.20.1-3.el7
[2064792.575] Current version of pixman: 0.34.0
[2064792.575] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[2064792.575] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[2064792.575] (==) Log file: “/var/log/Xorg.5.log”, Time: Thu Jun 20 11:52:36 2019
[2064792.576] (==) Using config file: “/etc/X11/xorg.conf”
[2064792.576] (==) Using config directory: “/etc/X11/xorg.conf.d”
[2064792.576] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[2064792.576] () Option “defaultserverlayout” “Layout0”
[2064792.576] () ServerLayout “Layout0”
[2064792.576] () |–>Screen “Screen0” (0)
[2064792.576] () | |–>Monitor “Monitor0”
[2064792.576] () | |–>Device “Device0”
[2064792.576] () Option “AllowMouseOpenFail” “false”
[2064792.576] () Option “BlankTime” “0”
[2064792.576] () Option “StandbyTime” “0”
[2064792.576] () Option “SuspendTime” “0”
[2064792.576] () Option “OffTime” “0”
[2064792.576] () Option “Xinerama” “0”
[2064792.576] (==) Automatically adding devices
[2064792.576] (==) Automatically enabling devices
[2064792.576] (==) Automatically adding GPU devices
[2064792.576] (==) Automatically binding GPU devices
[2064792.576] (==) Max clients allowed: 256, resource mask: 0x1fffff
[2064792.576] (==) FontPath set to:
catalogue:/etc/X11/fontpath.d,
built-ins
[2064792.576] (==) ModulePath set to “/usr/lib64/xorg/modules”
[2064792.576] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[2064792.576] (II) Loader magic: 0x55a397132020
[2064792.576] (II) Module ABI versions:
[2064792.576] X.Org ANSI C Emulation: 0.4
[2064792.576] X.Org Video Driver: 24.0
[2064792.576] X.Org XInput driver : 24.1
[2064792.576] X.Org Server Extension : 10.0
[2064792.577] (II) xfree86: Adding drm device (/dev/dri/card1)
[2064792.577] (II) Platform probe for /sys/devices/pci0000:00/0000:00:02.0/0000:02:00.0/drm/card1
[2064792.577] (II) Platform PCI device at pci:0000:00:02.0
[2064792.577] (II) xfree86: Adding drm device (/dev/dri/card0)
[2064792.577] (II) Platform probe for /sys/devices/pci0000:00/0000:00:1c.6/0000:07:00.0/0000:08:00.0/drm/card0
[2064792.577] (II) Platform PCI device at pci:0000:00:1c.6
[2064792.588] (–) PCI:*(2@0:0:0) 10de:1cb6:10de:1264 rev 161, Mem @ 0xfa000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x???/524288
[2064792.589] (–) PCI: (8@0:0:0) 1a03:2000:15d9:0834 rev 48, Mem @ 0xf8000000/16777216, 0xf9000000/131072, I/O @ 0x0000c000/128, BIOS @ 0x???/65536
[2064792.589] (II) LoadModule: “glx”
[2064792.589] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
[2064792.590] (II) Module glx: vendor=“X.Org Foundation”
[2064792.590] compiled for 1.20.1, module version = 1.0.0
[2064792.590] ABI class: X.Org Server Extension, version 10.0
[2064792.590] (II) LoadModule: “nvidia”
[2064792.590] (II) Loading /usr/lib64/xorg/modules/drivers/nvidia_drv.so
[2064792.590] (II) Module nvidia: vendor=“NVIDIA Corporation”
[2064792.590] compiled for 4.0.2, module version = 1.0.0
[2064792.590] Module class: X.Org Video Driver
[2064792.590] (II) NVIDIA dlloader X Driver 418.43 Tue Feb 19 01:07:27 CST 2019
[2064792.590] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[2064792.591] (–) using VT number 7
[2064792.623] (II) Loading sub module “fb”
[2064792.623] (II) LoadModule: “fb”
[2064792.623] (II) Loading /usr/lib64/xorg/modules/libfb.so
[2064792.624] (II) Module fb: vendor=“X.Org Foundation”
[2064792.624] compiled for 1.20.1, module version = 1.0.0
[2064792.624] ABI class: X.Org ANSI C Emulation, version 0.4
[2064792.624] (II) Loading sub module “wfb”
[2064792.624] (II) LoadModule: “wfb”
[2064792.624] (II) Loading /usr/lib64/xorg/modules/libwfb.so
[2064792.624] (II) Module wfb: vendor=“X.Org Foundation”
[2064792.624] (II) Loading sub module “ramdac”
[2064792.624] (II) LoadModule: “ramdac”
[2064792.624] (II) Module “ramdac” already built-in
[2064792.625] () NVIDIA(0): Depth 24, (–) framebuffer bpp 32
[2064792.625] (==) NVIDIA(0): RGB weight 888
[2064792.625] (==) NVIDIA(0): Default visual is TrueColor
[2064792.625] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[2064792.625] () NVIDIA(0): Option “UseEdidFreqs” “False”
[2064792.625] () NVIDIA(0): Option “ExactModeTimingsDVI” “True”
[2064792.625] () NVIDIA(0): Option “SLI” “Off”
[2064792.625] () NVIDIA(0): Option “MultiGPU” “Off”
[2064792.625] () NVIDIA(0): Option “ModeValidation” “AllowNon60hzmodesDFPModes, NoEDIDDFPMaxSizeCheck, NoVertRefreshCheck, NoHorizSyncCheck, NoDFPNativeResolutionCheck, NoMaxSizeCheck, NoMaxPClkCheck, AllowNonEdidModes, NoEdidMaxPClkCheck”
[2064792.625] () NVIDIA(0): Option “ModeDebug” “True”
[2064792.625] () NVIDIA(0): Option “BaseMosaic” “off”
[2064792.625] () NVIDIA(0): NVIDIA SLI disabled.
[2064792.625] () NVIDIA(0): NVIDIA Multi-GPU disabled.
[2064792.625] () NVIDIA(0): Option “UseEDID” “False”
[2064792.625] () NVIDIA(0): Option “ConnectedMonitor” “GPU-0.DP-4”
[2064792.625] () NVIDIA(0): Option “MetaModes” “DP-4: 1280x1024 +0+0”
[2064792.625] () NVIDIA(0): Option “UseDisplayDevice” “GPU-0.DP-4”
[2064792.625] () NVIDIA(0): Enabling 2D acceleration
[2064792.625] () NVIDIA(0): ConnectedMonitor string: “GPU-0.DP-4”
[2064792.625] () NVIDIA(0): Ignoring EDIDs
[2064792.625] (II) Loading sub module “glxserver_nvidia”
[2064792.625] (II) LoadModule: “glxserver_nvidia”
[2064792.625] (II) Loading /usr/lib64/xorg/modules/extensions/libglxserver_nvidia.so
[2064792.631] (II) Module glxserver_nvidia: vendor=“NVIDIA Corporation”
[2064792.631] compiled for 4.0.2, module version = 1.0.0
[2064792.631] Module class: X.Org Server Extension
[2064792.631] (II) NVIDIA GLX Module 418.43 Tue Feb 19 01:05:57 CST 2019
[2064792.998] (–) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:2:0:0
[2064792.998] (–) NVIDIA(0): DFP-0
[2064792.998] (–) NVIDIA(0): DFP-1
[2064792.998] (–) NVIDIA(0): DFP-2
[2064792.998] (–) NVIDIA(0): DFP-3
[2064792.998] (–) NVIDIA(0): DFP-4 (boot)
[2064792.998] (–) NVIDIA(0): DFP-5
[2064792.998] (–) NVIDIA(0): DFP-6
[2064792.998] (–) NVIDIA(0): DFP-7
[2064792.998] () NVIDIA(0): Using ConnectedMonitor string “DFP-4”.
[2064792.999] (II) NVIDIA(0): NVIDIA GPU Quadro P620 (GP107GL-A) at PCI:2:0:0 (GPU-0)
[2064792.999] (–) NVIDIA(0): Memory: 2097152 kBytes
[2064793.000] (–) NVIDIA(0): VideoBIOS: 86.07.51.00.04
[2064793.000] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[2064793.000] (–) NVIDIA(GPU-0): DFP-0: disconnected
[2064793.000] (–) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[2064793.000] (–) NVIDIA(GPU-0): DFP-0 Name Aliases:
[2064793.000] (–) NVIDIA(GPU-0): DPY-0
[2064793.000] (–) NVIDIA(GPU-0): DP-0
[2064793.000] (–) NVIDIA(GPU-0): DFP-0: 1440.0 MHz maximum pixel clock
[2064793.000] (–) NVIDIA(GPU-0): DFP-1: disconnected
[2064793.000] (–) NVIDIA(GPU-0): DFP-1: Internal TMDS
[2064793.000] (–) NVIDIA(GPU-0): DFP-1 Name Aliases:
[2064793.000] (–) NVIDIA(GPU-0): DPY-1
[2064793.000] (–) NVIDIA(GPU-0): DP-1
[2064793.000] (–) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[2064793.000] (–) NVIDIA(GPU-0): DFP-2: disconnected
[2064793.000] (–) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[2064793.000] (–) NVIDIA(GPU-0): DFP-2 Name Aliases:
[2064793.000] (–) NVIDIA(GPU-0): DPY-2
[2064793.000] (–) NVIDIA(GPU-0): DP-2
[2064793.000] (–) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[2064793.000] (–) NVIDIA(GPU-0): DFP-3: disconnected
[2064793.000] (–) NVIDIA(GPU-0): DFP-3: Internal TMDS
[2064793.000] (–) NVIDIA(GPU-0): DFP-3 Name Aliases:
[2064793.000] (–) NVIDIA(GPU-0): DPY-3
[2064793.000] (–) NVIDIA(GPU-0): DP-3
[2064793.000] (–) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[2064793.000] (–) NVIDIA(GPU-0): DFP-4: connected
[2064793.000] (–) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[2064793.000] (–) NVIDIA(GPU-0): DFP-4 Name Aliases:
[2064793.000] (–) NVIDIA(GPU-0): DPY-4
[2064793.000] (–) NVIDIA(GPU-0): DP-4
[2064793.000] (–) NVIDIA(GPU-0): DFP-4: 1440.0 MHz maximum pixel clock
[2064793.000] (–) NVIDIA(GPU-0): — EDID for DP-0 —
[2064793.000] (–) NVIDIA(GPU-0): No EDID Available.
[2064793.000] (–) NVIDIA(GPU-0): — End of EDID for DP-0 —
[2064793.000] (–) NVIDIA(GPU-0): DFP-5: disconnected
[2064793.000] (–) NVIDIA(GPU-0): DFP-5: Internal TMDS
[2064793.000] (–) NVIDIA(GPU-0): DFP-5 Name Aliases:
[2064793.000] (–) NVIDIA(GPU-0): DPY-5
[2064793.000] (–) NVIDIA(GPU-0): DP-5
[2064793.000] (–) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[2064793.000] (–) NVIDIA(GPU-0): DFP-6: disconnected
[2064793.000] (–) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[2064793.000] (–) NVIDIA(GPU-0): DFP-6 Name Aliases:
[2064793.000] (–) NVIDIA(GPU-0): DPY-6
[2064793.000] (–) NVIDIA(GPU-0): DP-6
[2064793.000] (–) NVIDIA(GPU-0): DFP-6: 1440.0 MHz maximum pixel clock
[2064793.000] (–) NVIDIA(GPU-0): DFP-7: disconnected
[2064793.000] (–) NVIDIA(GPU-0): DFP-7: Internal TMDS
[2064793.000] (–) NVIDIA(GPU-0): DFP-7 Name Aliases:
[2064793.000] (–) NVIDIA(GPU-0): DPY-7
[2064793.000] (–) NVIDIA(GPU-0): DP-7
[2064793.000] (–) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[2064793.000] (II) NVIDIA(GPU-0):
[2064793.000] (II) NVIDIA(GPU-0): — Building ModePool for DFP-4 —
[2064793.000] (WW) NVIDIA(GPU-0): Unrecognized ModeValidation token “AllowNon60hzmodesDFPModes”;
[2064793.000] (WW) NVIDIA(GPU-0): ignoring.
[2064793.000] (WW) NVIDIA(GPU-0): Unrecognized ModeValidation token “NoEDIDDFPMaxSizeCheck”;
[2064793.000] (WW) NVIDIA(GPU-0): “NoDFPNativeResolutionCheck”; ignoring.
[2064793.000] () NVIDIA(GPU-0): Mode Validation Overrides for DFP-4:
[2064793.000] () NVIDIA(GPU-0): NoMaxSizeCheck
[2064793.000] () NVIDIA(GPU-0): NoMaxPClkCheck
[2064793.000] () NVIDIA(GPU-0): NoEdidMaxPClkCheck
[2064793.000] () NVIDIA(GPU-0): NoHorizSyncCheck
[2064793.000] () NVIDIA(GPU-0): NoVertRefreshCheck
[2064793.000] (**) NVIDIA(GPU-0): AllowNonEdidModes
[2064793.001] (II) NVIDIA(GPU-0): Validating Mode “640x350_85”:
[2064793.001] (II) NVIDIA(GPU-0): Mode Source: VESA
[2064793.001] (II) NVIDIA(GPU-0): 640 x 350 @ 85 Hz
[2064793.001] (II) NVIDIA(GPU-0): Pixel Clock : 31.50 MHz
[2064793.001] (II) NVIDIA(GPU-0): HRes, HSyncStart : 640, 672
[2064793.001] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 736, 832
[2064793.001] (II) NVIDIA(GPU-0): VRes, VSyncStart : 350, 382
[2064793.001] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 385, 445
[2064793.001] (II) NVIDIA(GPU-0): Sync Polarity : +H -V
[2064793.001] (II) NVIDIA(GPU-0): Viewport 640x350+0+0
[2064793.001] (II) NVIDIA(GPU-0): Horizontal Taps 1
[2064793.001] (II) NVIDIA(GPU-0): Vertical Taps 1
[2064793.001] (II) NVIDIA(GPU-0): Core Depth 64
[2064793.001] (II) NVIDIA(GPU-0): Base Depth 64
[2064793.001] (II) NVIDIA(GPU-0): Distributed Rendering 1
[2064793.001] (II) NVIDIA(GPU-0): Overlay Depth 32
[2064793.001] (II) NVIDIA(GPU-0): Mode “640x350_85” is valid.
[2064793.001] (II) NVIDIA(GPU-0): Validating Mode “640x400_85”:
[2064793.001] (II) NVIDIA(GPU-0): 640 x 400 @ 85 Hz
[2064793.001] (II) NVIDIA(GPU-0): VRes, VSyncStart : 400, 401
[2064793.001] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 404, 445
[2064793.001] (II) NVIDIA(GPU-0): Sync Polarity : -H +V
[2064793.001] (II) NVIDIA(GPU-0): Viewport 640x400+0+0
[2064793.001] (II) NVIDIA(GPU-0): Mode “640x400_85” is valid.
[2064793.001] (II) NVIDIA(GPU-0): Validating Mode “720x400_85”:
[2064793.001] (II) NVIDIA(GPU-0): 720 x 400 @ 85 Hz
[2064793.001] (II) NVIDIA(GPU-0): Pixel Clock : 35.50 MHz
[2064793.001] (II) NVIDIA(GPU-0): HRes, HSyncStart : 720, 756
[2064793.001] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 828, 936
[2064793.001] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 404, 446
[2064793.001] (II) NVIDIA(GPU-0): Viewport 720x400+0+0
[2064793.001] (II) NVIDIA(GPU-0): Mode “720x400_85” is valid.
[2064793.001] (II) NVIDIA(GPU-0): Validating Mode “640x480_60”:
[2064793.001] (II) NVIDIA(GPU-0): 640 x 480 @ 60 Hz
[2064793.001] (II) NVIDIA(GPU-0): Pixel Clock : 25.17 MHz
[2064793.001] (II) NVIDIA(GPU-0): HRes, HSyncStart : 640, 656
[2064793.001] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 752, 800
[2064793.001] (II) NVIDIA(GPU-0): VRes, VSyncStart : 480, 490
[2064793.001] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 492, 525
[2064793.001] (II) NVIDIA(GPU-0): Sync Polarity : -H -V
[2064793.001] (II) NVIDIA(GPU-0): Viewport 640x480+0+0
[2064793.001] (II) NVIDIA(GPU-0): Mode “640x480_60” is valid.
[2064793.001] (II) NVIDIA(GPU-0): Validating Mode “640x480_73”:
[2064793.001] (II) NVIDIA(GPU-0): 640 x 480 @ 73 Hz
[2064793.001] (II) NVIDIA(GPU-0): HRes, HSyncStart : 640, 664
[2064793.001] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 704, 832
[2064793.001] (II) NVIDIA(GPU-0): VRes, VSyncStart : 480, 489
[2064793.001] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 492, 520
[2064793.001] (II) NVIDIA(GPU-0): Mode “640x480_73” is valid.
[2064793.001] (II) NVIDIA(GPU-0): Validating Mode “640x480_75”:
[2064793.001] (II) NVIDIA(GPU-0): 640 x 480 @ 75 Hz
[2064793.001] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 720, 840
[2064793.001] (II) NVIDIA(GPU-0): VRes, VSyncStart : 480, 481
[2064793.001] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 484, 500
[2064793.001] (II) NVIDIA(GPU-0): Mode “640x480_75” is valid.
[2064793.002] (II) NVIDIA(GPU-0): Validating Mode “640x480_85”:
[2064793.002] (II) NVIDIA(GPU-0): Mode Source: VESA
[2064793.002] (II) NVIDIA(GPU-0): 640 x 480 @ 85 Hz
[2064793.002] (II) NVIDIA(GPU-0): Pixel Clock : 36.00 MHz
[2064793.002] (II) NVIDIA(GPU-0): HRes, HSyncStart : 640, 696
[2064793.002] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 752, 832
[2064793.002] (II) NVIDIA(GPU-0): VRes, VSyncStart : 480, 481
[2064793.002] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 484, 509
[2064793.002] (II) NVIDIA(GPU-0): Sync Polarity : -H -V
[2064793.002] (II) NVIDIA(GPU-0): Viewport 640x480+0+0
[2064793.002] (II) NVIDIA(GPU-0): Horizontal Taps 1
[2064793.002] (II) NVIDIA(GPU-0): Vertical Taps 1
[2064793.002] (II) NVIDIA(GPU-0): Core Depth 64
[2064793.002] (II) NVIDIA(GPU-0): Base Depth 64
[2064793.002] (II) NVIDIA(GPU-0): Distributed Rendering 1
[2064793.002] (II) NVIDIA(GPU-0): Overlay Depth 32
[2064793.002] (II) NVIDIA(GPU-0): Mode “640x480_85” is valid.
[2064793.002] (II) NVIDIA(GPU-0): Validating Mode “800x600_56”:
[2064793.002] (II) NVIDIA(GPU-0): 800 x 600 @ 56 Hz
[2064793.002] (II) NVIDIA(GPU-0): HRes, HSyncStart : 800, 824
[2064793.002] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 896, 1024
[2064793.002] (II) NVIDIA(GPU-0): VRes, VSyncStart : 600, 601
[2064793.002] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 603, 625
[2064793.002] (II) NVIDIA(GPU-0): Sync Polarity : +H +V
[2064793.002] (II) NVIDIA(GPU-0): Viewport 800x600+0+0
[2064793.002] (II) NVIDIA(GPU-0): Mode “800x600_56” is valid.
[2064793.002] (II) NVIDIA(GPU-0): Validating Mode “800x600_60”:
[2064793.002] (II) NVIDIA(GPU-0): 800 x 600 @ 60 Hz
[2064793.002] (II) NVIDIA(GPU-0): Pixel Clock : 40.00 MHz
[2064793.002] (II) NVIDIA(GPU-0): HRes, HSyncStart : 800, 840
[2064793.002] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 968, 1056
[2064793.002] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 605, 628
[2064793.002] (II) NVIDIA(GPU-0): Mode “800x600_60” is valid.
[2064793.002] (II) NVIDIA(GPU-0): Validating Mode “800x600_72”:
[2064793.002] (II) NVIDIA(GPU-0): 800 x 600 @ 72 Hz
[2064793.002] (II) NVIDIA(GPU-0): Pixel Clock : 50.00 MHz
[2064793.002] (II) NVIDIA(GPU-0): HRes, HSyncStart : 800, 856
[2064793.002] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 976, 1040
[2064793.002] (II) NVIDIA(GPU-0): VRes, VSyncStart : 600, 637
[2064793.002] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 643, 666
[2064793.002] (II) NVIDIA(GPU-0): Mode “800x600_72” is valid.
[2064793.002] (II) NVIDIA(GPU-0): Validating Mode “800x600_75”:
[2064793.002] (II) NVIDIA(GPU-0): 800 x 600 @ 75 Hz
[2064793.002] (II) NVIDIA(GPU-0): Pixel Clock : 49.50 MHz
[2064793.002] (II) NVIDIA(GPU-0): HRes, HSyncStart : 800, 816
[2064793.002] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 896, 1056
[2064793.002] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 604, 625
[2064793.003] (II) NVIDIA(GPU-0): Mode “800x600_75” is valid.
[2064793.003] (II) NVIDIA(GPU-0): Validating Mode “800x600_85”:
[2064793.003] (II) NVIDIA(GPU-0): Mode Source: VESA
[2064793.003] (II) NVIDIA(GPU-0): 800 x 600 @ 85 Hz
[2064793.003] (II) NVIDIA(GPU-0): Pixel Clock : 56.30 MHz
[2064793.003] (II) NVIDIA(GPU-0): HRes, HSyncStart : 800, 832
[2064793.003] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 896, 1048
[2064793.003] (II) NVIDIA(GPU-0): VRes, VSyncStart : 600, 601
[2064793.003] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 604, 631
[2064793.003] (II) NVIDIA(GPU-0): Sync Polarity : +H +V
[2064793.003] (II) NVIDIA(GPU-0): Viewport 800x600+0+0
[2064793.003] (II) NVIDIA(GPU-0): Horizontal Taps 1
[2064793.003] (II) NVIDIA(GPU-0): Vertical Taps 1
[2064793.003] (II) NVIDIA(GPU-0): Core Depth 64
[2064793.003] (II) NVIDIA(GPU-0): Base Depth 64
[2064793.003] (II) NVIDIA(GPU-0): Distributed Rendering 1
[2064793.003] (II) NVIDIA(GPU-0): Overlay Depth 32
[2064793.003] (II) NVIDIA(GPU-0): Mode “800x600_85” is valid.
[2064793.003] (WW) NVIDIA(GPU-0): Validating Mode “1024x768_87i”:
[2064793.003] (WW) NVIDIA(GPU-0): Mode Source: VESA
[2064793.003] (WW) NVIDIA(GPU-0): 1024 x 768 @ 87 Hz
[2064793.003] (WW) NVIDIA(GPU-0): Pixel Clock : 44.90 MHz
[2064793.003] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 1024, 1032
[2064793.003] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 1208, 1264
[2064793.003] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 768, 768
[2064793.003] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 776, 817
[2064793.003] (WW) NVIDIA(GPU-0): Sync Polarity : +H +V
[2064793.003] (WW) NVIDIA(GPU-0): Extra : Interlace
[2064793.003] (WW) NVIDIA(GPU-0): Mode is rejected: Interlaced modes are not supported over
[2064793.003] (WW) NVIDIA(GPU-0): DisplayPort.
[2064793.003] (WW) NVIDIA(GPU-0): GPU extended capability check failed.
[2064793.003] (WW) NVIDIA(GPU-0): Mode “1024x768_87i” is invalid.
[2064793.003] (II) NVIDIA(GPU-0): Validating Mode “1024x768_60”:
[2064793.003] (II) NVIDIA(GPU-0): 1024 x 768 @ 60 Hz
[2064793.003] (II) NVIDIA(GPU-0): Pixel Clock : 65.00 MHz
[2064793.003] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1024, 1048
[2064793.003] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 1184, 1344
[2064793.003] (II) NVIDIA(GPU-0): VRes, VSyncStart : 768, 771
[2064793.003] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 777, 806
[2064793.003] (II) NVIDIA(GPU-0): Sync Polarity : -H -V
[2064793.003] (II) NVIDIA(GPU-0): Viewport 1024x768+0+0
[2064793.003] (II) NVIDIA(GPU-0): Mode “1024x768_60” is valid.
[2064793.003] (II) NVIDIA(GPU-0): Validating Mode “1024x768_70”:
[2064793.003] (II) NVIDIA(GPU-0): 1024 x 768 @ 70 Hz
[2064793.003] (II) NVIDIA(GPU-0): Pixel Clock : 75.00 MHz
[2064793.003] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 1184, 1328
[2064793.003] (II) NVIDIA(GPU-0): Mode “1024x768_70” is valid.
[2064793.003] (II) NVIDIA(GPU-0): Validating Mode “1024x768_75”:
[2064793.003] (II) NVIDIA(GPU-0): 1024 x 768 @ 75 Hz
[2064793.003] (II) NVIDIA(GPU-0): Pixel Clock : 78.75 MHz
[2064793.003] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1024, 1040
[2064793.003] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 1136, 1312
[2064793.003] (II) NVIDIA(GPU-0): VRes, VSyncStart : 768, 769
[2064793.003] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 772, 800
[2064793.003] (II) NVIDIA(GPU-0): Mode “1024x768_75” is valid.
[2064793.003] (II) NVIDIA(GPU-0): Validating Mode “1024x768_85”:
[2064793.003] (II) NVIDIA(GPU-0): 1024 x 768 @ 85 Hz
[2064793.003] (II) NVIDIA(GPU-0): Pixel Clock : 94.50 MHz
[2064793.003] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1024, 1072
[2064793.003] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 1168, 1376
[2064793.003] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 772, 808
[2064793.003] (II) NVIDIA(GPU-0): Mode “1024x768_85” is valid.
[2064793.003] (II) NVIDIA(GPU-0): Validating Mode “1152x864_75”:
[2064793.003] (II) NVIDIA(GPU-0): 1152 x 864 @ 75 Hz
[2064793.003] (II) NVIDIA(GPU-0): Pixel Clock : 108.00 MHz
[2064793.003] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1152, 1216
[2064793.003] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 1344, 1600
[2064793.003] (II) NVIDIA(GPU-0): VRes, VSyncStart : 864, 865
[2064793.003] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 868, 900
[2064793.003] (II) NVIDIA(GPU-0): Viewport 1152x864+0+0
[2064793.004] (II) NVIDIA(GPU-0): Horizontal Taps 1
[2064793.004] (II) NVIDIA(GPU-0): Vertical Taps 1
[2064793.004] (II) NVIDIA(GPU-0): Core Depth 64
[2064793.004] (II) NVIDIA(GPU-0): Base Depth 64
[2064793.004] (II) NVIDIA(GPU-0): Distributed Rendering 1
[2064793.004] (II) NVIDIA(GPU-0): Overlay Depth 32
[2064793.004] (II) NVIDIA(GPU-0): Mode “1152x864_75” is valid.
[2064793.004] (II) NVIDIA(GPU-0): Validating Mode “1280x960_60”:
[2064793.004] (II) NVIDIA(GPU-0): Mode Source: VESA
[2064793.004] (II) NVIDIA(GPU-0): 1280 x 960 @ 60 Hz
[2064793.004] (II) NVIDIA(GPU-0): Pixel Clock : 108.00 MHz
[2064793.004] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1280, 1376
[2064793.004] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 1488, 1800
[2064793.004] (II) NVIDIA(GPU-0): VRes, VSyncStart : 960, 961
[2064793.004] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 964, 1000
[2064793.004] (II) NVIDIA(GPU-0): Sync Polarity : +H +V
[2064793.004] (II) NVIDIA(GPU-0): Viewport 1280x960+0+0
[2064793.004] (II) NVIDIA(GPU-0): Mode “1280x960_60” is valid.
[2064793.004] (II) NVIDIA(GPU-0): Validating Mode “1280x960_85”:
[2064793.004] (II) NVIDIA(GPU-0): 1280 x 960 @ 85 Hz
[2064793.004] (II) NVIDIA(GPU-0): Pixel Clock : 148.50 MHz
[2064793.004] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1280, 1344
[2064793.004] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 1504, 1728
[2064793.004] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 964, 1011
[2064793.004] (II) NVIDIA(GPU-0): Mode “1280x960_85” is valid.
[2064793.004] (II) NVIDIA(GPU-0): Validating Mode “1280x1024_60”:
[2064793.004] (II) NVIDIA(GPU-0): 1280 x 1024 @ 60 Hz
[2064793.004] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1280, 1328
[2064793.004] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 1440, 1688
[2064793.004] (II) NVIDIA(GPU-0): VRes, VSyncStart : 1024, 1025
[2064793.004] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 1028, 1066
[2064793.004] (II) NVIDIA(GPU-0): Viewport 1280x1024+0+0
[2064793.004] (II) NVIDIA(GPU-0): Mode “1280x1024_60” is valid.
[2064793.004] (II) NVIDIA(GPU-0): Validating Mode “1280x1024_75”:
[2064793.004] (II) NVIDIA(GPU-0): 1280 x 1024 @ 75 Hz
[2064793.004] (II) NVIDIA(GPU-0): Pixel Clock : 135.00 MHz
[2064793.004] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1280, 1296
[2064793.004] (II) NVIDIA(GPU-0): Mode “1280x1024_75” is valid.
[2064793.005] (II) NVIDIA(GPU-0): Validating Mode “1280x1024_85”:
[2064793.005] (II) NVIDIA(GPU-0): Mode Source: VESA
[2064793.005] (II) NVIDIA(GPU-0): 1280 x 1024 @ 85 Hz
[2064793.005] (II) NVIDIA(GPU-0): Pixel Clock : 157.50 MHz
[2064793.005] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1280, 1344
[2064793.005] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 1504, 1728
[2064793.005] (II) NVIDIA(GPU-0): VRes, VSyncStart : 1024, 1025
[2064793.005] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 1028, 1072
[2064793.005] (II) NVIDIA(GPU-0): Sync Polarity : +H +V
[2064793.005] (II) NVIDIA(GPU-0): Viewport 1280x1024+0+0
[2064793.005] (II) NVIDIA(GPU-0): Horizontal Taps 1
[2064793.005] (II) NVIDIA(GPU-0): Vertical Taps 1
[2064793.005] (II) NVIDIA(GPU-0): Core Depth 64
[2064793.005] (II) NVIDIA(GPU-0): Base Depth 64
[2064793.005] (II) NVIDIA(GPU-0): Distributed Rendering 1
[2064793.005] (II) NVIDIA(GPU-0): Overlay Depth 32
[2064793.005] (II) NVIDIA(GPU-0): Mode “1280x1024_85” is valid.
[2064793.005] (WW) NVIDIA(GPU-0): Validating Mode “1600x1200_60”:
[2064793.005] (WW) NVIDIA(GPU-0): Mode Source: VESA
[2064793.005] (WW) NVIDIA(GPU-0): 1600 x 1200 @ 60 Hz
[2064793.005] (WW) NVIDIA(GPU-0): Pixel Clock : 162.00 MHz
[2064793.005] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 1600, 1664
[2064793.005] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 1856, 2160
[2064793.005] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 1200, 1201
[2064793.005] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 1204, 1250
[2064793.005] (WW) NVIDIA(GPU-0): Sync Polarity : +H +V
[2064793.005] (WW) NVIDIA(GPU-0): Viewport 1600x1200+0+0
[2064793.005] (WW) NVIDIA(GPU-0): Horizontal Taps 1
[2064793.005] (WW) NVIDIA(GPU-0): Vertical Taps 1
[2064793.005] (WW) NVIDIA(GPU-0): Core Depth 64
[2064793.005] (WW) NVIDIA(GPU-0): Base Depth 64
[2064793.005] (WW) NVIDIA(GPU-0): Distributed Rendering 1
[2064793.005] (WW) NVIDIA(GPU-0): Overlay Depth 32
[2064793.005] (WW) NVIDIA(GPU-0): Mode (1600 x 1200) is too large for user-requested virtual
[2064793.005] (WW) NVIDIA(GPU-0): screen size (1280 x 1024)
[2064793.005] (WW) NVIDIA(GPU-0): Mode “1600x1200_60” is invalid.
[2064793.005] (WW) NVIDIA(GPU-0): Validating Mode “1600x1200_65”:
[2064793.005] (WW) NVIDIA(GPU-0): 1600 x 1200 @ 65 Hz
[2064793.005] (WW) NVIDIA(GPU-0): Pixel Clock : 175.50 MHz
[2064793.005] (WW) NVIDIA(GPU-0): Mode “1600x1200_65” is invalid.
[2064793.005] (WW) NVIDIA(GPU-0): Validating Mode “1600x1200_70”:
[2064793.005] (WW) NVIDIA(GPU-0): 1600 x 1200 @ 70 Hz
[2064793.005] (WW) NVIDIA(GPU-0): Pixel Clock : 189.00 MHz
[2064793.005] (WW) NVIDIA(GPU-0): Mode “1600x1200_70” is invalid.
[2064793.005] (WW) NVIDIA(GPU-0): Validating Mode “1600x1200_75”:
[2064793.005] (WW) NVIDIA(GPU-0): 1600 x 1200 @ 75 Hz
[2064793.005] (WW) NVIDIA(GPU-0): Pixel Clock : 202.50 MHz
[2064793.005] (WW) NVIDIA(GPU-0): Mode “1600x1200_75” is invalid.
[2064793.005] (WW) NVIDIA(GPU-0): Validating Mode “1600x1200_85”:
[2064793.005] (WW) NVIDIA(GPU-0): 1600 x 1200 @ 85 Hz
[2064793.005] (WW) NVIDIA(GPU-0): Pixel Clock : 229.50 MHz
[2064793.006] (WW) NVIDIA(GPU-0): Viewport 1600x1200+0+0
[2064793.006] (WW) NVIDIA(GPU-0): Horizontal Taps 1
[2064793.006] (WW) NVIDIA(GPU-0): Vertical Taps 1
[2064793.006] (WW) NVIDIA(GPU-0): Core Depth 64
[2064793.006] (WW) NVIDIA(GPU-0): Base Depth 64
[2064793.006] (WW) NVIDIA(GPU-0): Distributed Rendering 1
[2064793.006] (WW) NVIDIA(GPU-0): Overlay Depth 32
[2064793.006] (WW) NVIDIA(GPU-0): Mode (1600 x 1200) is too large for user-requested virtual
[2064793.006] (WW) NVIDIA(GPU-0): screen size (1280 x 1024)
[2064793.006] (WW) NVIDIA(GPU-0): Mode “1600x1200_85” is invalid.
[2064793.006] (WW) NVIDIA(GPU-0): Validating Mode “1792x1344_60”:
[2064793.006] (WW) NVIDIA(GPU-0): Mode Source: VESA
[2064793.006] (WW) NVIDIA(GPU-0): 1792 x 1344 @ 60 Hz
[2064793.006] (WW) NVIDIA(GPU-0): Pixel Clock : 204.80 MHz
[2064793.006] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 1792, 1920
[2064793.006] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 2120, 2448
[2064793.006] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 1344, 1345
[2064793.006] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 1348, 1394
[2064793.006] (WW) NVIDIA(GPU-0): Sync Polarity : -H +V
[2064793.006] (WW) NVIDIA(GPU-0): Viewport 1792x1344+0+0
[2064793.006] (WW) NVIDIA(GPU-0): Mode (1792 x 1344) is too large for user-requested virtual
[2064793.006] (WW) NVIDIA(GPU-0): Mode “1792x1344_60” is invalid.
[2064793.006] (WW) NVIDIA(GPU-0): Validating Mode “1792x1344_75”:
[2064793.006] (WW) NVIDIA(GPU-0): 1792 x 1344 @ 75 Hz
[2064793.006] (WW) NVIDIA(GPU-0): Pixel Clock : 261.00 MHz
[2064793.006] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 1792, 1888
[2064793.006] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 2104, 2456
[2064793.006] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 1348, 1417
[2064793.006] (WW) NVIDIA(GPU-0): Mode is rejected: DP Bandwidth check failed.
[2064793.006] (WW) NVIDIA(GPU-0): GPU extended capability check failed.
[2064793.006] (WW) NVIDIA(GPU-0): Mode “1792x1344_75” is invalid.
[2064793.006] (WW) NVIDIA(GPU-0): Validating Mode “1856x1392_60”:
[2064793.006] (WW) NVIDIA(GPU-0): 1856 x 1392 @ 60 Hz
[2064793.006] (WW) NVIDIA(GPU-0): Pixel Clock : 218.30 MHz
[2064793.006] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 1856, 1952
[2064793.006] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 2176, 2528
[2064793.006] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 1392, 1393
[2064793.006] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 1396, 1439
[2064793.006] (WW) NVIDIA(GPU-0): Viewport 1856x1392+0+0
[2064793.006] (WW) NVIDIA(GPU-0): Mode (1856 x 1392) is too large for user-requested virtual
[2064793.006] (WW) NVIDIA(GPU-0): Mode “1856x1392_60” is invalid.
[2064793.006] (WW) NVIDIA(GPU-0): Validating Mode “1856x1392_75”:
[2064793.006] (WW) NVIDIA(GPU-0): 1856 x 1392 @ 75 Hz
[2064793.006] (WW) NVIDIA(GPU-0): Pixel Clock : 288.00 MHz
[2064793.006] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 1856, 1984
[2064793.006] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 2208, 2560
[2064793.006] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 1396, 1500
[2064793.006] (WW) NVIDIA(GPU-0): Mode “1856x1392_75” is invalid.
[2064793.006] (WW) NVIDIA(GPU-0): Validating Mode “1920x1440_60”:
[2064793.006] (WW) NVIDIA(GPU-0): 1920 x 1440 @ 60 Hz
[2064793.006] (WW) NVIDIA(GPU-0): Pixel Clock : 234.00 MHz
[2064793.006] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 1920, 2048
[2064793.006] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 2256, 2600
[2064793.006] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 1440, 1441
[2064793.006] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 1444, 1500
[2064793.006] (WW) NVIDIA(GPU-0): Viewport 1920x1440+0+0
[2064793.006] (WW) NVIDIA(GPU-0): Mode (1920 x 1440) is too large for user-requested virtual
[2064793.006] (WW) NVIDIA(GPU-0): Mode “1920x1440_60” is invalid.
[2064793.006] (WW) NVIDIA(GPU-0): Validating Mode “1920x1440_75”:
[2064793.006] (WW) NVIDIA(GPU-0): 1920 x 1440 @ 75 Hz
[2064793.006] (WW) NVIDIA(GPU-0): Pixel Clock : 297.00 MHz
[2064793.006] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 1920, 2064
[2064793.006] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 2288, 2640
[2064793.006] (WW) NVIDIA(GPU-0): Mode “1920x1440_75” is invalid.
[2064793.006] (II) NVIDIA(GPU-0): Validating Mode “1280x1024_60”:
[2064793.006] (II) NVIDIA(GPU-0): Mode Source: X Configuration file ModeLine
[2064793.006] (II) NVIDIA(GPU-0): 1280 x 1024 @ 60 Hz
[2064793.006] (II) NVIDIA(GPU-0): Pixel Clock : 108.00 MHz
[2064793.006] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1280, 1328
[2064793.007] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 1440, 1688
[2064793.007] (II) NVIDIA(GPU-0): VRes, VSyncStart : 1024, 1025
[2064793.007] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 1028, 1066
[2064793.007] (II) NVIDIA(GPU-0): Sync Polarity : +H +V
[2064793.007] (II) NVIDIA(GPU-0): Viewport 1280x1024+0+0
[2064793.007] (II) NVIDIA(GPU-0): Horizontal Taps 1
[2064793.007] (II) NVIDIA(GPU-0): Vertical Taps 1
[2064793.007] (II) NVIDIA(GPU-0): Core Depth 64
[2064793.007] (II) NVIDIA(GPU-0): Base Depth 64
[2064793.007] (II) NVIDIA(GPU-0): Distributed Rendering 1
[2064793.007] (II) NVIDIA(GPU-0): Overlay Depth 32
[2064793.007] (II) NVIDIA(GPU-0): Mode “1280x1024_60” is valid.
[2064793.007] (II) NVIDIA(GPU-0): Validating Mode “640x350_85”:
[2064793.007] (II) NVIDIA(GPU-0): Mode Source: X Server
[2064793.007] (II) NVIDIA(GPU-0): 640 x 350 @ 85 Hz
[2064793.007] (II) NVIDIA(GPU-0): Pixel Clock : 31.50 MHz
[2064793.007] (II) NVIDIA(GPU-0): HRes, HSyncStart : 640, 672
[2064793.007] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 736, 832
[2064793.007] (II) NVIDIA(GPU-0): VRes, VSyncStart : 350, 382
[2064793.007] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 385, 445
[2064793.007] (II) NVIDIA(GPU-0): Sync Polarity : +H -V
[2064793.007] (II) NVIDIA(GPU-0): Viewport 640x350+0+0
[2064793.007] (II) NVIDIA(GPU-0): Mode “640x350_85” is valid.
[2064793.007] (II) NVIDIA(GPU-0): Validating Mode “320x175d85”:
[2064793.007] (II) NVIDIA(GPU-0): 320 x 175 @ 85 Hz
[2064793.007] (II) NVIDIA(GPU-0): Pixel Clock : 15.75 MHz
[2064793.007] (II) NVIDIA(GPU-0): HRes, HSyncStart : 320, 336
[2064793.007] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 368, 416
[2064793.007] (II) NVIDIA(GPU-0): VRes, VSyncStart : 175, 191
[2064793.007] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 192, 222
[2064793.007] (II) NVIDIA(GPU-0): Extra : DoubleScan
[2064793.007] (II) NVIDIA(GPU-0): Viewport 320x175+0+0
[2064793.007] (II) NVIDIA(GPU-0): Horizontal Taps 2
[2064793.007] (II) NVIDIA(GPU-0): Vertical Taps 2
[2064793.007] (II) NVIDIA(GPU-0): Mode “320x175d85” is valid.
[2064793.007] (II) NVIDIA(GPU-0): Validating Mode “640x400_85”:
[2064793.007] (II) NVIDIA(GPU-0): 640 x 400 @ 85 Hz
[2064793.007] (II) NVIDIA(GPU-0): VRes, VSyncStart : 400, 401
[2064793.007] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 404, 445
[2064793.007] (II) NVIDIA(GPU-0): Sync Polarity : -H +V
[2064793.007] (II) NVIDIA(GPU-0): Viewport 640x400+0+0
[2064793.007] (II) NVIDIA(GPU-0): Mode “640x400_85” is valid.
[2064793.007] (WW) NVIDIA(GPU-0): Validating Mode “320x200d85”:
[2064793.007] (WW) NVIDIA(GPU-0): Mode Source: X Server
[2064793.007] (WW) NVIDIA(GPU-0): 320 x 200 @ 85 Hz
[2064793.007] (WW) NVIDIA(GPU-0): Pixel Clock : 15.75 MHz
[2064793.007] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 320, 336
[2064793.007] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 368, 416
[2064793.007] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 200, 200
[2064793.007] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 202, 222
[2064793.007] (WW) NVIDIA(GPU-0): Sync Polarity : -H +V
[2064793.007] (WW) NVIDIA(GPU-0): Extra : DoubleScan
[2064793.007] (WW) NVIDIA(GPU-0): ViewPort 320x400 exceeds hardware capabilities.
[2064793.007] (WW) NVIDIA(GPU-0): Mode is rejected: GPU extended capability check failed.
[2064793.007] (WW) NVIDIA(GPU-0): GPU extended capability check failed.
[2064793.007] (WW) NVIDIA(GPU-0): Mode “320x200d85” is invalid.
[2064793.007] (II) NVIDIA(GPU-0): Validating Mode “720x400_85”:
[2064793.007] (II) NVIDIA(GPU-0): 720 x 400 @ 85 Hz
[2064793.007] (II) NVIDIA(GPU-0): Pixel Clock : 35.50 MHz
[2064793.007] (II) NVIDIA(GPU-0): HRes, HSyncStart : 720, 756
[2064793.008] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 828, 936
[2064793.008] (II) NVIDIA(GPU-0): VRes, VSyncStart : 400, 401
[2064793.008] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 404, 446
[2064793.008] (II) NVIDIA(GPU-0): Sync Polarity : -H +V
[2064793.008] (II) NVIDIA(GPU-0): Viewport 720x400+0+0
[2064793.008] (II) NVIDIA(GPU-0): Horizontal Taps 1
[2064793.008] (II) NVIDIA(GPU-0): Vertical Taps 1
[2064793.008] (II) NVIDIA(GPU-0): Core Depth 64
[2064793.008] (II) NVIDIA(GPU-0): Base Depth 64
[2064793.008] (II) NVIDIA(GPU-0): Distributed Rendering 1
[2064793.008] (II) NVIDIA(GPU-0): Overlay Depth 32
[2064793.008] (II) NVIDIA(GPU-0): Mode “720x400_85” is valid.
[2064793.008] (WW) NVIDIA(GPU-0): Validating Mode “360x200d85”:
[2064793.008] (WW) NVIDIA(GPU-0): Mode Source: X Server
[2064793.008] (WW) NVIDIA(GPU-0): 360 x 200 @ 85 Hz
[2064793.008] (WW) NVIDIA(GPU-0): Pixel Clock : 17.75 MHz
[2064793.008] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 360, 378
[2064793.008] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 414, 468
[2064793.008] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 200, 200
[2064793.008] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 202, 223
[2064793.008] (WW) NVIDIA(GPU-0): Sync Polarity : -H +V
[2064793.008] (WW) NVIDIA(GPU-0): Extra
