Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
2.1.0
other
Host Machine Version
other
Issue Description
<Please provide details about your query/application pipeline/usecase/pictures here >
I want to know how to be able to change the os_args or kernel cmdline from the userspace.
This one is the default:
pl:[I]: Kernel Cmdline: aurixfw=AFW root=/dev/vblkdev0p1 loglevel=3 ip=off usr_fs=/dev/vblkdev1:/mnt/persistent/metadata usr_fs2=/dev/vblkdev2:/mnt/persistent/data rw_overlay=/dev/vblkdev3:/rw_overlay gpt rootwait rw gpt tegra_k
is there a tool in the userspace to change it?
Regards
Thanks for the response.
I tried it, but it seems it is not supported for hypervisor:
Check finished successfully
There is no supported for specifying kernel-dtb with Hypervisor
command line used was:
['/drive/drive-foundation/tools/flashtools/bootburn/./bootburn.py', '-b', 'p3710-10-s05', '-B', 'qspi', '-x', '/dev/ttyACM5', '-d', 'kernel-dtb', '/drive/drive-foundation/virtualization/hypervisor/t23x/configs/t234ref-release/pct/p3710-10-s05/linux/tegra234-p3710-0010-a01-linux-driveav-gos.dtb', '-D']
s_ERROR_OPTION_VALUE_INVALID -- Cannot specify dtb with Hypervisor
2
Failed to initialize target config
Exception caught in bootburn
File "/drive/drive-foundation/tools/flashtools/bootburn/../bootburn_t23x_py/bootburn_parser.py", line 199, in initializeTargetConfig
self.ValidateParameters(targetConfig)
File "/drive/drive-foundation/tools/flashtools/bootburn/../bootburn_t23x_py/bootburn_parser.py", line 887, in ValidateParameters
AbnormalTermination ("s_ERROR_OPTION_VALUE_INVALID -- Cannot specify dtb with Hypervisor", nverror.NvError_NotSupported)
File "/drive/drive-foundation/tools/flashtools/bootburn/../bootburn_t23x_py/flashtools_nverror.py", line 251, in AbnormalTermination
raise OSError(errorCode)
OSError: 2
During handling of the above exception, another exception occurred:
File "/drive/drive-foundation/tools/flashtools/bootburn/../bootburn_t23x_py/bootburn.py", line 255, in bootburn
cmdParser.initializeTargetConfig(targetConfig, GenericOptions, False)
File "/drive/drive-foundation/tools/flashtools/bootburn/../bootburn_t23x_py/bootburn_parser.py", line 206, in initializeTargetConfig
AbnormalTermination("Failed to initialize target config", nverror.NvError_ConfigVarNotFound)
OSError: 67
Is there another way?
Regards
