I have a custom Orin NX (16GB) carrier card with only a few overlays provided by the board manufacturer. I want to repurpose 2 Jetson I/O pins that are currently UART (uart2_tx_px4 and uart_rx_px5) to GPIO inputs. I also want to repurpose 1 Jetson I/O pin that is currently GPIO input (soc_gpio39_pn1) to a PWM output. I have used the Jetson Orin Nano&NX Pinmux HDMI tab of the pinmux spreadsheet to attempt to determine what the overlay would look like (changes only … I have the full DTSI file if needed, but I didn’t see the equivalent file in the source tree to replace):
gpio.dtsi (added to gpio@2200000…gpio_main_default…gpio-input):
TEGRA234_MAIN_GPIO(X, 4)
TEGRA234_MAIN_GPIO(X, 5)
gpio.dtsi (removed from gpio@2200000…gpio_main_default…gpio-input):
TEGRA234_MAIN_GPIO(N, 1)
pinmux.dsti (changed):
uart2_tx_px4 {
nvidia,pins = "uart2_tx_px4";
nvidia,function = "rsvd1";
nvidia,pull = <TEGRA_PIN_PULL_NONE>;
nvidia,tristate = <TEGRA_PIN_ENABLE>;
nvidia,enable-input = <TEGRA_PIN_ENABLE>;
nvidia,io-high-voltage = <TEGRA_PIN_DISABLE>;
nvidia,lpdr = <TEGRA_PIN_DISABLE>;
uart2_rx_px5 {
nvidia,pins = "uart2_rx_px5";
soc_gpio39_pn1 {
nvidia,pins = "soc_gpio39_pn1";
nvidia,function = "gp";
nvidia,tristate = <TEGRA_PIN_DISABLE>;
nvidia,enable-input = <TEGRA_PIN_DISABLE>;
What are the steps to incorporate these changes into the DTB that is used at boot time and/or create a overlay with these changes (and have that overlay recognized)?
Configuration/build Details:
Jetpack 36.4.3
cat /etc/nv_tegra_release
# R36 (release), REVISION: 4.3, GCID: 38968081, BOARD: generic, EABI: aarch64, DATE: Wed Jan 8 01:49:37 UTC 2025
# KERNEL_VARIANT: oot
TARGET_USERSPACE_LIB_DIR=nvidia
TARGET_USERSPACE_LIB_DIR_PATH=usr/lib/aarch64-linux-gnu/nvidia
ls /boot/dtb
kernel_tegra234-p3768-0000+p3767-0000-nv.dtb
uname -a
Linux custom-board 5.15.148-tegra #1 SMP PREEMPT Tue Jan 7 17:14:38 PST 2025 aarch64 aarch64 aarch64 GNU/Linux
sudo apt-cache show nvidia-jetpack
Package: nvidia-jetpack
Source: nvidia-jetpack (6.2.1)
Version: 6.2.1+b38
Architecture: arm64
Maintainer: NVIDIA Corporation
Installed-Size: 194
Depends: nvidia-jetpack-runtime (= 6.2.1+b38), nvidia-jetpack-dev (= 6.2.1+b38)
Homepage: http://developer.nvidia.com/jetson
Priority: standard
Section: metapackages
Filename: pool/main/n/nvidia-jetpack/nvidia-jetpack_6.2.1+b38_arm64.deb
SHA256: dd9cb893fbe7f80d2c2348b268f17c8140b18b9dbb674fa8d79facfaa2050c53
SHA1: dc630f213f9afcb6f67c65234df7ad5c019edb9c
MD5sum: 9c8dc61bdab2b816dcc7cd253bcf6482
Description: NVIDIA Jetpack Meta Package
Description-md5: ad1462289bdbc54909ae109d1d32c0a8
Source: nvidia-jetpack (6.2)
Version: 6.2+b77
Architecture: arm64
Installed-Size: 194
Depends: nvidia-jetpack-runtime (= 6.2+b77), nvidia-jetpack-dev (= 6.2+b77)
Priority: standard
Filename: pool/main/n/nvidia-jetpack/nvidia-jetpack_6.2+b77_arm64.deb
SHA256: 70553d4b5a802057f9436677ef8ce255db386fd3b5d24ff2c0a8ec0e485c59cd
SHA1: 9deab64d12eef0e788471e05856c84bf2a0cf6e6
MD5sum: 4db65dc36434fe1f84176843384aee23
Source: nvidia-jetpack (6.1)
Version: 6.1+b123
Architecture: arm64
Installed-Size: 194
Depends: nvidia-jetpack-runtime (= 6.1+b123), nvidia-jetpack-dev (= 6.1+b123)
Priority: standard
Filename: pool/main/n/nvidia-jetpack/nvidia-jetpack_6.1+b123_arm64.deb
SHA256: b6475a6108aeabc5b16af7c102162b7c46c36361239fef6293535d05ee2c2929
SHA1: f0984a6272c8f3a70ae14cb2ca6716b8c1a09543
MD5sum: a167745e1d88a8d7597454c8003fa9a4
Thanks in advance!
