Modifying cb_rtspsrc_select_stream() to support mjpeg RTSP streams
Hi, this is a new topic related to this previous post:
From that previous post, I can see that the function which requires modification to support mjpeg is “cb_rtspsrc_select_stream”, from /opt/nvidia/deepstream/deepstream-6.0/sources/apps/apps-common/src/deepstream_source_bin.c.
I can see also that the offending part of the function is:
/* Add the proper depay element based on codec. */
    if (!g_strcmp0 (encoding_name, "H264")) {
      bin->depay = gst_element_factory_make ("rtph264depay", elem_name);
      g_snprintf (elem_name, sizeof (elem_name), "h264parse_elem%d", bin->bin_id);
      bin->parser = gst_element_factory_make ("h264parse", elem_name);
    } else if (!g_strcmp0 (encoding_name, "H265")) {
      bin->depay = gst_element_factory_make ("rtph265depay", elem_name);
      g_snprintf (elem_name, sizeof (elem_name), "h265parse_elem%d", bin->bin_id);
      bin->parser = gst_element_factory_make ("h265parse", elem_name);
    } else {
      NVGSTDS_WARN_MSG_V ("%s not supported", encoding_name);
      return FALSE;
Could nvidia share the precise change needed to this function to support mjpeg streams alongside h264 and h265 streams ?
This is customization and please give it a try. You can check the gstreamer pipeline is good in gst-launch-1.0 command:
$ gst-launch-1.0 rtspsrc uri=_URI_OF_RTSP_SOURCE_ ! rtpjpegdepay ! jpegparse ! nvv4l2decoder mjpeg=1 ! nvoverlaysink
And then apply the pipeline to deepstream-app.
Other users may have experience and can share suggestion.
Thanks for the suggestion, we modified the function and it worked correctly.
