Modifying GPU Fan Curve on Ubuntu Cluster
I am running scientific calculations on a GPU cluster, and have found myself needing to modify the GPU fan curves. Our cluster is set up so that each individual node has 4 GPUs, and runs Ubuntu 18.04 off of a head node. I have come across nvidia-settings --cool-bit=28 flag, but I am unable to run the nvidia-settings command on an individual node as I get the error:
libgtk-3.so.0: cannot open shared object file: No such file or directory
libnvidia-gtk3.so: cannot open shared object file: No such file or
directory
libgtk-x11-2.0.so.0: cannot open shared object file: No such file or
directory
libnvidia-gtk2.so: cannot open shared object file: No such file or
directory
ERROR: A problem occured when loading the GUI library. Please check your
installation and library path. You may need to specify this library when
calling nvidia-settings. Please run nvidia-settings --help for usage
information.
I thought this was due to a missing package on the head node, so I downloaded gtk2.0 and gtk3.0 with sudo apt-get install gtk3.0, but I still receive that error even after rebooting.
Is there a way to use nvidia-settings on a setup like mine, with only command line arguments?
Thank you!
This would require running an Xserver and xscreens on each gpu, so not really feasible in your case.
Did you ever find a solution to your errors?
Six years after your post in 2019 and it is now almost 2025 and the same errors appear for me and I cannot find solution.
