Modifying textures/setting backgrounds in Isaac Sim
Hi all,
I am having trouble assigning textures to prims in Isaac Sim. In the in-built script editor, the following snippet sets the texture parameter of a DomeLight for me successfully:
import omni.kit.commands
from pxr import Sdf
omni.kit.commands.execute('CreatePrim',
        prim_type='DomeLight',
        attributes={'intensity': 1000, 'texture:format': 'latlong'})
omni.kit.commands.execute('ChangeProperty',
        prop_path=Sdf.Path('/World/DomeLight.texture:file'),
        value=Sdf.AssetPath('omniverse://localhost/Users/admin/strawberry/DR/backgrounds/evening_meadow_4k.hdr'),
        prev=None)
Interestingly, this does not work when called through running python.sh. The code runs without errors, but the texture does not show up on images acquired by a script similar to python_samples/syntheticdata/basic/visualize_groundtruth.py.
Has anyone achieved texture modification for domain randomization? If so, whats the catch?
Two things that can help:
  • When launching via the OmniKitHelper, set sync_loads to true to force omniverse to fully load all assets before rendering another frame.
  • You can also try adding update() calls after setting the property to let the texture load before capturing data.
