I have a need to build a custom plugin, I’m currently modifying the gst-dsexample, currently named gst-dsexample2 or dsexample2. Just trying to modify and compile a new plugin.
The problem is that I’m not able to find the dsexample2 I’ve built. Similar as: renaming custom gst-dsexample which seems to be outdated.
The steps I’ve taken is to copy the gst-dsexample directory, renamed as gst-dsexample2
Renamed gstdsexample.cpp as gstdsexample2.cpp, gstdsexample.h as gstdsexample2.h.
In gstdsexample2.cpp I’ve edited:
#include "gstdsexample2.h"
static gboolean
dsexample_plugin_init (GstPlugin * plugin)
GST_DEBUG_CATEGORY_INIT (gst_dsexample_debug, "dsexample2", 0,
"dsexample2 plugin");
return gst_element_register (plugin, "dsexample2", GST_RANK_PRIMARY,
GST_TYPE_DSEXAMPLE);
in gstdsexample2.h I’ve edited:
#define PACKAGE "dsexample2"
in Makefile I’ve edited:
ifeq ($(USE_OPTIMIZED_DSEXAMPLE),1)
SRCS:= gstdsexample_optimized.cpp
else
SRCS:= gstdsexample2.cpp
endif
INCS:= $(wildcard *.h)
LIB:=libnvdsgst_dsexample2.so
Then I execute
export CUDA_VER=10.2
make
make install
However when I try to inspect dsexample2 I’m not able to find it, gst-inspect-1.0 dsexample2:
No such element or plugin 'dsexample2'
