Modifying the struct NvDsInferObjectDetectionInfo in nvdsinfer.h
Hi All,
I am looking to modify this structure to add in a a new variable would it be possible and what would be the best way to go about it.
typedef struct
  /** ID of the class to which the object belongs. */
  unsigned int classId;
  /** Horizontal offset of the bounding box shape for the object. */
  unsigned int left;
  /** Vertical offset of the bounding box shape for the object. */
  unsigned int top;
  /** Width of the bounding box shape for the object. */
  unsigned int width;
  /** Height of the bounding box shape for the object. */
  unsigned int height;
  /** Object detection confidence. Should be a float value in the range [0,1] */
  float detectionConfidence;
} NvDsInferObjectDetectionInfo;
The documentation and examples include ways to attach custom metadata.
Thanks for the reply.
In my case i am using the mask rcnn custom app provided by IOT to generate the segment metadata though i am able to dump the segments but i am unable to access it in the deepstream app where we write metadata in text files.
You can add additional fields to the mentioned structure - needs to compile nvdsinfer library and gstnvinfer plugin again
Thanks it helped solving the issue.
