--volume /tmp/argus_socket:/tmp/argus_socket
AL OCUPAR EL CÓDIGO PARA CSI RECOMENDADA SOLO SE AÑADE LA LINEA DE ARRIBA, SIN EMBARGO NO FUNCIONA, AYUDA.
“BY USING THE CODE FOR RECOMMENDED CSI ONLY THE ABOVE LINE IS ADDED, HOWEVER IT DOES NOT WORK, IT HELPS.”
What’s the camera you’re using?
May I know which code you’re referring?
