Using the production module in max mode with heavy processing.
Measured around 62 Celsius (on the surface).
Q1: Are these the expected results ?
Q2: Is it possible to put the unit in thermally insulated sealed box ?
Thanks, Best
Danny.
Thanks, Best
Danny.
Hi dannykario,
Not sure what the test tool is on your heavy processing, you may need to design more long-run test to ensure the system is stable, and not shut down due to thermal problem.
I can’t answer whether that’s suitable to put the device into a thermally insulated sealed box because don’t know if the heat will cause the system temperature getting higher or not at your case. You will need to do more experiments.
