I ran the SDK provided by OptiX on L20 and H20 GPUs and obtained the following results:
Ubuntu 22.04
L20, H20
Driver Version: 550.90.07
CUDA Version: 12.1
Optix Version: 7.7, 8.1
NVIDIA-OptiX-SDK-7.7.0-linux64-x86_64/SDK/build$ bin/optixHello
[ 4][ KNOBS]: All knobs on default.
[ 4][ DISKCACHE]: Opened database: "/var/tmp/OptixCache_zhengyulong/optix7cache.db"
[ 4][ DISKCACHE]: Cache data size: "0 Bytes"
[ 4][ DISKCACHE]: Cache miss for key: ptx-6792-keybafd77f26dfb101b5d65c755ee65c60b-sm_89-rtc1-drv550.90.07
[ 4][ COMPILER]: Info: Pipeline parameter "params" size is 16 bytes
[ 2][ COMPILER]: COMPILE ERROR: Module compilation failed
Info: Module Statistics
payload values : 0
attribute values : 0
Pipeline configuration: (default)
Info: Properties for entry function "__raygen__draw_solid_color"
semantic type : RAYGEN
trace call(s) : 0
continuation callable call(s): 0
direct callable call(s) : 0
basic block(s) : 1
instruction(s) : 75
Info: Compiled Module Summary
non-entry function(s): 0
basic block(s) : 0
instruction(s) : 0
Caught exception: OPTIX_ERROR_INTERNAL_COMPILER_ERROR: Optix call 'optixModuleCreate( context, &module_compile_options, &pipeline_compile_options, input, inputSize, LOG, &LOG_SIZE, &module )' failed: /home/zhengyulong/models/gaussian-raytracing/NVIDIA-OptiX-SDK-7.7.0-linux64-x86_64/SDK/optixHello/optixHello.cpp:150)
Log:
payload values : 0
trace call(s) : 0
basic block(s) : 1
instruction(s) : 75
basic block(s) : 0
instruction(s) : 0
If I use a higher version of OptiX, such as 8.1, the following error occurs:
NVIDIA-OptiX-SDK-8.1.0-linux64-x86_64/SDK/build$ bin/optixHello
Caught exception: OPTIX_ERROR_UNSUPPORTED_ABI_VERSION: Optix call 'optixInit()' failed: /home/zhengyulong/models/gaussian-raytracing/NVIDIA-OptiX-SDK-8.1.0-linux64-x86_64/SDK/optixHello/optixHello.cpp:125)
I have tried various methods but still cannot resolve this issue.
Looking forward to your assistance. Thanks!
The error you are seeing when trying to use 8.1 is due to a too-old driver. 8.1 requires an 555+ driver.
Optix 7.7 should work with 12.1, but it has only been tested with 12.0.
Thank you. However, I tested OptiX 7.7 with CUDA 12.0 and still got the same results. Is it an issue with my driver version, or do L20 and H20 not support OptiX?
Hi everyone,
I am experiencing similar issues with module compilation failures on an H200 GPU, while the same setup works fine on an H100 GPU. Here are the details of the environment:
Driver Version: 570.86.15
CUDA Driver Version / Runtime Version: 12.8 / 12.1
Optix Versions tried: 8.0.0, 9.0.0
When building and running the OptiX SDK sample optixHello, it works fine on an H100, while I encounter the following error on the H200 (very similar to the one reported above):
user@worker:/home/user/optix/SDK/build/bin$ ./optixHello
[ 4][ DISKCACHE]: Opened database: "/var/tmp/OptixCache_user/optix7cache.db"
[ 4][ DISKCACHE]: Cache miss for key: ptx-7084-key07759fb807706d1d0443fda686bc5bb8-sm_90-rtc0-drv570.86.15
payload values : 0
trace call(s) : 0
basic block(s) : 1
instruction(s) : 75
basic block(s) : 0
instruction(s) : 0
Caught exception: OPTIX_ERROR_INTERNAL_COMPILER_ERROR: Optix call 'optixModuleCreate( context, &module_compile_options, &pipeline_compile_options, input, inputSize, LOG, &LOG_SIZE, &module )' failed: /home/user/optix/SDK/optixHello/optixHello.cpp:153)
Log:
payload values : 0
trace call(s) : 0
basic block(s) : 1
instruction(s) : 75
basic block(s) : 0
instruction(s) : 0
Any insights or suggestions would be greatly appreciated. Thank you!
g-vid
April 4, 2025, 7:27pm
5
I have the same error as reported by m-naumann with WSL Ubuntu / GeForce RTX 3050 / Cuda12.8/ Driver Version: 572.83 / Optix9.0
Tried on Windows at the same machine, all examples are executed fine.
