I updated to 460.20 and get an error like below. When I go back to 460.15 or earlier everything works fine. The same happens on 1060 and 2080.
Looking at maybe related topic I should add my compilation options:
m_module_compile_options.optLevel = OPTIX_COMPILE_OPTIMIZATION_DEFAULT;
m_module_compile_options.debugLevel = OPTIX_COMPILE_DEBUG_LEVEL_LINEINFO;
Thanks for any help!
The error message:
[ 2][COMPILE FEEDBACK]: COMPILE ERROR: Module compilation failed
Info: Pipeline parameter "params" size is 280 bytes
Info: Module uses 4 payload values. Pipeline configuration: 4.
Info: Module uses 6 attribute values. Pipeline configuration: 6.
Info: Entry function "__closesthit__occlusion" with semantic type CLOSESTHIT has 0 trace call(s), 0 continuation callable call(s), 0 direct callable call(s), 2 basic block(s), 8 instruction(s)
Info: Entry function "__closesthit__occlusion_transparency" with semantic type CLOSESTHIT has 0 trace call(s), 0 continuation callable call(s), 0 direct callable call(s), 7 basic block(s), 78 instruction(s)
Info: Entry function "__anyhit__occlusion" with semantic type ANYHIT has 0 trace call(s), 0 continuation callable call(s), 0 direct callable call(s), 2 basic block(s), 9 instruction(s)
Info: Entry function "__closesthit__radiance__flat" with semantic type CLOSESTHIT has 0 trace call(s), 0 continuation callable call(s), 0 direct callable call(s), 41 basic block(s), 504 instruction(s)
Info: Entry function "__closesthit__radiance__cos" with semantic type CLOSESTHIT has 0 trace call(s), 0 continuation callable call(s), 0 direct callable call(s), 41 basic block(s), 528 instruction(s)
Info: Entry function "__closesthit__radiance__blurred_dot" with semantic type CLOSESTHIT has 0 trace call(s), 0 continuation callable call(s), 0 direct callable call(s), 46 basic block(s), 563 instruction(s)
Info: Entry function "__closesthit__radiance__diffuse_masked" with semantic type CLOSESTHIT has 1 trace call(s), 0 continuation callable call(s), 0 direct callable call(s), 86 basic block(s), 1249 instruction(s)
Info: Entry function "__closesthit__radiance__diffuse" with semantic type CLOSESTHIT has 1 trace call(s), 0 continuation callable call(s), 0 direct callable call(s), 81 basic block(s), 1187 instruction(s)
Info: Entry function "__closesthit__radiance__glass" with semantic type CLOSESTHIT has 0 trace call(s), 0 continuation callable call(s), 0 direct callable call(s), 124 basic block(s), 1235 instruction(s)
Info: Entry function "__closesthit__radiance__reflective_masked" with semantic type CLOSESTHIT has 2 trace call(s), 0 continuation callable call(s), 0 direct callable call(s), 141 basic block(s), 2052 instruction(s)
Info: Entry function "__closesthit__radiance__reflective" with semantic type CLOSESTHIT has 2 trace call(s), 0 continuation callable call(s), 0 direct callable call(s), 136 basic block(s), 1998 instruction(s)
Info: Entry function "__closesthit__radiance__light_soft" with semantic type CLOSESTHIT has 0 trace call(s), 0 continuation callable call(s), 0 direct callable call(s), 47 basic block(s), 561 instruction(s)
Info: Entry function "__closesthit__radiance__light_hard" with semantic type CLOSESTHIT has 0 trace call(s), 0 continuation callable call(s), 0 direct callable call(s), 45 basic block(s), 542 instruction(s)
Info: Entry function "__closesthit__radiance__shadow_catcher" with semantic type CLOSESTHIT has 1 trace call(s), 0 continuation callable call(s), 0 direct callable call(s), 77 basic block(s), 1129 instruction(s)
Info: 7 non-entry function(s) have 42 basic block(s), 647 instruction(s)
OPTIX_ERROR_INTERNAL_COMPILER_ERROR: Optix call 'optixModuleCreateFromPTX( m_context, &m_module_compile_options, &m_pipeline_compile_options, ptx.c_str(), ptx.size(), log, &sizeof_log, &mnew )' failed: c:\...\modules.cpp:37)
Log:
