I have a couple of questions about the TX2i
The datasheet indicates that the Max-P goes from 15W on the TX2 to 20W on the TX2i. So is this saying that for the same amount of Flops/Performance, power goes up 5W on the TX2i? Why is that if it’s the same process node?
When the module power is stated at 15W for the TX2 and 20W for the TX2i, is this at room temperature or hot temperature (80/85C)?
For the module power Max-P, does this assume close to 100% CPU usage and 100% GPU usage?
