Module 'pyds' has no attribute 'NvDsAudioFrameMeta'
• Hardware Platform (Jetson / GPU) Jetson nano
• DeepStream Version 6.0
• JetPack Version (valid for Jetson only) 4.6.1
Hello guys, I have been writing an audio python application using deepstream. I already have a successful running pipeline doing the audio inference, but when I tried to get the the classification info from a prob function, following the BatchMeta → FrameMeta->ObjectMeta->ClassifierMeta it gets segmentation fault when getting the ObjectMeta from l_object.data. I have been looking into the sdk C documentation, and there is a specific AudioFrameMeta type for this specific use case but don’t exist the cast to python.
So my question is, it’s possible to get this AudioFrameMeta in python? There is a workaround to get the classifier information + chunk audio in python?
There is no AudioFrameMeta in the prebuilt pyds bindings. You can generate the python binding by yourself. https://github.com/NVIDIA-AI-IOT/deepstream_python_apps/tree/master/bindings
I have already generated my own bindings but still unsuccessful on getting the AudioFrameMeta in python. Which file I need to change to generate the audio bindings that I’m missing?
Or there is another way to retrieve the classification values + audio records without changing the prebuilt pyds bindings?
Thanks in advance!
Can you tell us how you generated the AudioFrameMeta binding? What kind of error have you met?
The other way is to write c/c++ app instead of python app.
Hi Fiona!
After digging a lot, I was able to build the NvAudioFrameMeta python binding with success!
At deepstream_python_apps/bindings/src/bindnvdsmeta.cpp I added this class following with the deepstream sdk c struct:
py::class_<NvDsAudioFrameMeta>(m, "NvDsAudioFrameMeta",
                                  pydsdoc::nvmeta::FrameMetaDoc::descr)
                .def(py::init<>())
                .def_readwrite("base_meta", &NvDsAudioFrameMeta::base_meta)
                .def_readwrite("pad_index", &NvDsAudioFrameMeta::pad_index)
                .def_readwrite("batch_id", &NvDsAudioFrameMeta::batch_id)
                .def_readwrite("frame_num", &NvDsAudioFrameMeta::frame_num)
                .def_readwrite("buf_pts", &NvDsAudioFrameMeta::buf_pts)
                .def_readwrite("ntp_timestamp", &NvDsAudioFrameMeta::ntp_timestamp)
                .def_readwrite("source_id", &NvDsAudioFrameMeta::source_id)
                .def_readwrite("num_samples_per_frame",
                               &NvDsAudioFrameMeta::num_samples_per_frame)
                .def_readwrite("sample_rate", &NvDsAudioFrameMeta::sample_rate)
                .def_readwrite("num_channels", &NvDsAudioFrameMeta::num_channels)
                .def_readwrite("format", &NvDsAudioFrameMeta::format)
                .def_readwrite("layout", &NvDsAudioFrameMeta::layout)
                .def_readwrite("bInferDone", &NvDsAudioFrameMeta::bInferDone)
                .def_readwrite("class_id", &NvDsAudioFrameMeta::class_id)
                .def_readwrite("confidence", &NvDsAudioFrameMeta::confidence)
                .def_readwrite("classifier_meta_list", &NvDsAudioFrameMeta::classifier_meta_list)
                .def_readwrite("frame_user_meta_list", &NvDsAudioFrameMeta::frame_user_meta_list)
                .def("cast",
                     [](void *data) {
                         return (NvDsAudioFrameMeta *) data;
                     py::return_value_policy::reference,
                     pydsdoc::nvmeta::FrameMetaDoc::cast)
                .def("cast",
                     [](size_t data) {
                .def_property("class_label",
                              STRING_CHAR_ARRAY(NvDsAudioFrameMeta, class_label))
                .def_property("misc_frame_info",
                              [](NvDsAudioFrameMeta &self) -> py::array {
                                  auto dtype = py::dtype(
                                          py::format_descriptor<int>::format());
                                  auto base = py::array(dtype,
                                                        {MAX_USER_FIELDS},
                                                        {sizeof(int)});
                                  return py::array(dtype, {MAX_USER_FIELDS},
                                                   {sizeof(int)},
                                                   self.misc_frame_info, base);
                              [](NvDsAudioFrameMeta &self) {})
                .def_property("reserved",
                                                        {MAX_RESERVED_FIELDS},
                                                        {sizeof(int)});
                                  return py::array(dtype, {MAX_RESERVED_FIELDS},
                                                   {sizeof(int)}, self.reserved,
                                                   base);
                              [](NvDsBatchMeta &self) {});
and at deepstream_python_apps/bindings/include/pyds.hpp I added the #include "nvds_audio_meta.h".
Then I just followed the commands to generate the python bindings!
To access the audio data, we can’t do it in the same way that we do to get an image frame ( frame = pyds.get_nvds_buf_surface(hash(gst_buffer), frame_meta.batch_id) ). Instead we need to create a new function at deepstream_python_apps/bindings/src/bindfunctions.cpp and use the NvBufAudio instead of using the NvBufSurface.
Hope this can help someone!
