can you specify a different directory where to save .mod from the one the compiler should look for pre-existing .mod?
I’m building f90 code using MPI (“use mpi”) and I want to produce a module. The default location of the MPI .mod is write protected (and should be) and thus the only way to bypass this problem (unable to save the module that I want to produce) is to either copy all the mpi modules or symlink them in a directory I can write in.
Not a very satisfying solution…
