ModuleNotFoundError: No module named 'graphsurgeon'
• Hardware Platform (Jetson / GPU) NVIDIA RTX A3000
• DeepStream Version 6.2
• TensorRT Version
**• NVIDIA GPU Driver Version (valid for GPU only)****• 525.105
I am trying to run this model tracker_NvDeepSORT
graphsurgeon-tf and onnx-graphsurgeon is already installed.
Still I am getting this error
/opt/nvidia/deepstream/deepstream-6.2/sources/tracker_NvDeepSORT$ python3 convert.py
File “convert.py”, line 17, in
import graphsurgeon as gs
ModuleNotFoundError: No module named ‘graphsurgeon’
Are you using DeepStream docker? Which docker are you using?
Please refer here if you want to convert DeepSORT model: Deepstream Tracker FAQ - #5 by kesong
No I am not using Docker. I have installed DeepStream 6.2 on my local Ubuntu device.
I manually installed graphsurgeon-tf and onnx-graphsurgeon using .whl file available in TensorRT tar file.
Now that error is gone.
But I am getting this tensorflow error. I followed this to install tensorflow Deepstream Tracker FAQ - #5 by kesong
I did pip3 install tensorflow==2.11.0 PyYAML
ModuleNotFoundError: No module named ‘tensorflow’
During handling of the above exception, another exception occurred:
File “/usr/lib/python3.8/dist-packages/graphsurgeon/init.py”, line 51, in
raise ImportError(“”"ERROR: Failed to import module ({})
ImportError: ERROR: Failed to import module (No module named ‘tensorflow’)
Seems it is your setup issue. Can you have a try with DeepStream docker?
