Hi. I’ve checked the other answers to this question but haven’t found any that worked. Interestingly, when running this code, everything works just fine:
import torch
from diffusers import FluxPipeline
pipe = FluxPipeline.from_pretrained("black-forest-labs/FLUX.1-dev", torch_dtype=torch.bfloat16)
#pipe.enable_model_cpu_offload() #save some VRAM by offloading the model to CPU. Remove this if you have enough GPU power
prompt = "A cat holding a sign that says hello world."
pipe = pipe.to("cuda")
image = pipe(
prompt,
height=1024,
width=1024,
guidance_scale=3.5,
num_inference_steps=50,
max_sequence_length=512,
generator=torch.Generator(device="cuda").manual_seed(0)
).images[0]
image.save("cat.png")
but when attempting to run an LLM:
import torch
from transformers import pipeline
messages = [
{"role": "system", "content": "You are a pirate chatbot who always responds in pirate speak!"},
{"role": "user", "content": "Who are you?"},
chatbot = pipeline("text-generation", model="Orenguteng/Llama-3.1-8B-Lexi-Uncensored-V2", model_kwargs={"torch_dtype": torch.bfloat16}, device="cuda")
chatbot(messages)
I run into this error:
File "/home/ferros/repos/test_ai/mistralai-7b-instruct.py", line 16, in <module>
main()
File "/home/ferros/repos/test_ai/mistralai-7b-instruct.py", line 11, in main
result = chatbot(messages)
File "/home/ferros/repos/test_ai/venv/lib/python3.10/site-packages/transformers/pipelines/text_generation.py", line 267, in __call__
return super().__call__(Chat(text_inputs), **kwargs)
File "/home/ferros/repos/test_ai/venv/lib/python3.10/site-packages/transformers/pipelines/base.py", line 1302, in __call__
return self.run_single(inputs, preprocess_params, forward_params, postprocess_params)
File "/home/ferros/repos/test_ai/venv/lib/python3.10/site-packages/transformers/pipelines/base.py", line 1309, in run_single
model_outputs = self.forward(model_inputs, **forward_params)
File "/home/ferros/repos/test_ai/venv/lib/python3.10/site-packages/transformers/pipelines/base.py", line 1209, in forward
model_outputs = self._forward(model_inputs, **forward_params)
File "/home/ferros/repos/test_ai/venv/lib/python3.10/site-packages/transformers/pipelines/text_generation.py", line 370, in _forward
generated_sequence = self.model.generate(input_ids=input_ids, attention_mask=attention_mask, **generate_kwargs)
File "/home/ferros/repos/test_ai/venv/lib/python3.10/site-packages/torch/utils/_contextlib.py", line 116, in decorate_context
return func(*args, **kwargs)
File "/home/ferros/repos/test_ai/venv/lib/python3.10/site-packages/transformers/generation/utils.py", line 1977, in generate
synced_gpus = (is_deepspeed_zero3_enabled() or is_fsdp_managed_module(self)) and dist.get_world_size() > 1
File "/home/ferros/repos/test_ai/venv/lib/python3.10/site-packages/transformers/integrations/fsdp.py", line 29, in is_fsdp_managed_module
import torch.distributed.fsdp
File "/home/ferros/repos/test_ai/venv/lib/python3.10/site-packages/torch/distributed/fsdp/__init__.py", line 1, in <module>
from ._flat_param import FlatParameter as FlatParameter
File "/home/ferros/repos/test_ai/venv/lib/python3.10/site-packages/torch/distributed/fsdp/_flat_param.py", line 45, in <module>
from torch.testing._internal.distributed.fake_pg import FakeProcessGroup
File "/home/ferros/repos/test_ai/venv/lib/python3.10/site-packages/torch/testing/_internal/distributed/fake_pg.py", line 5, in <module>
from torch._C._distributed_c10d import (
ModuleNotFoundError: No module named 'torch._C._distributed_c10d'; 'torch._C' is not a package
I have verified that it does exist in my site-packages:
(venv) ferros@ubuntu:~/repos/test_ai$ ls venv/lib/python3.10/site-packages/torch/_C/
_aoti.pyi _cpu.pyi _distributed_autograd.pyi _distributed_rpc.pyi _functions.pyi __init__.pyi _lazy.pyi _monitor.pyi _nvtx.pyi _profiler.pyi _verbose.pyi
_autograd.pyi _cudnn.pyi _distributed_c10d.pyi _distributed_rpc_testing.pyi _functorch.pyi _itt.pyi _lazy_ts_backend.pyi _nn.pyi _onnx.pyi _VariableFunctions.pyi
and that its using my virtual environment:
(venv) ferros@ubuntu:~/repos/test_ai$ which python
/home/ferros/repos/test_ai/venv/bin/python
I did install torch per nvidia instructions here
My venv has:
(venv) ferros@ubuntu:~/repos/test_ai$ pip freeze
certifi==2024.8.30
charset-normalizer==3.4.0
filelock==3.16.1
fsspec==2024.10.0
huggingface-hub==0.26.2
idna==3.10
Jinja2==3.1.4
MarkupSafe==3.0.2
mpmath==1.3.0
networkx==3.4.2
numpy==1.26.4
packaging==24.2
pillow==11.0.0
psutil==6.1.0
PyYAML==6.0.2
regex==2024.11.6
requests==2.32.3
safetensors==0.4.5
sympy==1.13.1
tokenizers==0.20.3
torch @ https://developer.download.nvidia.com/compute/redist/jp/v61/pytorch/torch-2.5.0a0+872d972e41.nv24.08.17622132-cp310-cp310-linux_aarch64.whl#sha256=6f75fd2d2ef840ede1a90dbcf40a5458214bee26cc803fa510cda2e8978d972a
tqdm==4.67.0
transformers==4.46.2
typing_extensions==4.12.2
urllib3==2.2.3
(venv) ferros@ubuntu:~/repos/test_ai$ nvcc -V
Copyright (c) 2005-2024 NVIDIA Corporation
Built on Wed_Aug_14_10:14:07_PDT_2024
Cuda compilation tools, release 12.6, V12.6.68
Build cuda_12.6.r12.6/compiler.34714021_0
Any thoughts to a path forward? I’ve tried a variety of models, the one above, Mistrial. I have blown out my environment and started over, but alas to no affect. Thanks ahead of time for any ideas!
