I’m trying to compile the kernel from sources Jetson version 35.2.1 directly inside the AGX Orin 32Gb.
I’m using the following command :
make -C kernel/kernel-5.10/ ARCH=arm64 O=$KERNEL_OUT LOCALVERSION=-tegra -j4 modules
I’m having errors on the modules compilation error:
/home/nvidia/kernel/Linux_for_Tegra/source/public/kernel/nvidia/drivers/hid/hid-atv-jarvis.c: In function ‘atvr_mic_ctrl’:
/home/nvidia/kernel/Linux_for_Tegra/source/public/kernel/nvidia/drivers/hid/hid-atv-jarvis.c:449:21: error: ‘USB_DEVICE_ID_NVIDIA_FRIDAY’ undeclared (first use in this function); did you mean ‘USB_DEVICE_ID_NVIDIA_RAVEN’?
449 | hdev->product == USB_DEVICE_ID_NVIDIA_FRIDAY) {
/home/nvidia/kernel/Linux_for_Tegra/source/public/kernel/nvidia/drivers/hid/hid-atv-jarvis.c:449:21: note: each undeclared identifier is reported only once for each function it appears in
/home/nvidia/kernel/Linux_for_Tegra/source/public/kernel/nvidia/drivers/hid/hid-atv-jarvis.c: In function ‘snd_atvr_pcm_open’:
/home/nvidia/kernel/Linux_for_Tegra/source/public/kernel/nvidia/drivers/hid/hid-atv-jarvis.c:1372:2: error: implicit declaration of function ‘setup_timer’; did you mean ‘del_timer’? [-Werror=implicit-function-declaration]
1372 | setup_timer(&atvr_snd->decoding_timer, snd_atvr_timer_callback,
| del_timer
/home/nvidia/kernel/Linux_for_Tegra/source/public/kernel/nvidia/drivers/hid/hid-atv-jarvis.c: In function ‘atvr_snd_initialize’:
/home/nvidia/kernel/Linux_for_Tegra/source/public/kernel/nvidia/drivers/hid/hid-atv-jarvis.c:1578:21: error: ‘USB_DEVICE_ID_NVIDIA_FRIDAY’ undeclared (first use in this function); did you mean ‘USB_DEVICE_ID_NVIDIA_RAVEN’?
1578 | hdev->product == USB_DEVICE_ID_NVIDIA_FRIDAY)
/home/nvidia/kernel/Linux_for_Tegra/source/public/kernel/nvidia/drivers/hid/hid-atv-jarvis.c: In function ‘atvr_jarvis_break_events’:
/home/nvidia/kernel/Linux_for_Tegra/source/public/kernel/nvidia/drivers/hid/hid-atv-jarvis.c:1655:20: error: ‘USB_DEVICE_ID_NVIDIA_FRIDAY’ undeclared (first use in this function); did you mean ‘USB_DEVICE_ID_NVIDIA_RAVEN’?
1655 | hdev->product == USB_DEVICE_ID_NVIDIA_FRIDAY) &&
CC [M] drivers/net/ethernet/qlogic/qlcnic/qlcnic_hw.o
/home/nvidia/kernel/Linux_for_Tegra/source/public/kernel/nvidia/drivers/hid/hid-atv-jarvis.c: In function ‘atvr_probe’:
/home/nvidia/kernel/Linux_for_Tegra/source/public/kernel/nvidia/drivers/hid/hid-atv-jarvis.c:1998:23: error: ‘USB_DEVICE_ID_NVIDIA_FRIDAY’ undeclared (first use in this function); did you mean ‘USB_DEVICE_ID_NVIDIA_RAVEN’?
1998 | if (hdev->product != USB_DEVICE_ID_NVIDIA_FRIDAY) {
/home/nvidia/kernel/Linux_for_Tegra/source/public/kernel/nvidia/drivers/hid/hid-atv-jarvis.c: In function ‘atvr_remove’:
/home/nvidia/kernel/Linux_for_Tegra/source/public/kernel/nvidia/drivers/hid/hid-atv-jarvis.c:2069:21: error: ‘USB_DEVICE_ID_NVIDIA_FRIDAY’ undeclared (first use in this function); did you mean ‘USB_DEVICE_ID_NVIDIA_RAVEN’?
2069 | hdev->product == USB_DEVICE_ID_NVIDIA_FRIDAY) {
In file included from /home/nvidia/kernel/Linux_for_Tegra/source/public/kernel/nvidia/drivers/hid/hid-atv-jarvis.c:20:
/home/nvidia/kernel/Linux_for_Tegra/source/public/kernel/nvidia/drivers/hid/hid-atv-jarvis.c: At top level:
/home/nvidia/kernel/Linux_for_Tegra/source/public/kernel/nvidia/drivers/hid/hid-atv-jarvis.c:2165:10: error: ‘USB_DEVICE_ID_NVIDIA_FRIDAY’ undeclared here (not in a function); did you mean ‘USB_DEVICE_ID_NVIDIA_RAVEN’?
2165 | USB_DEVICE_ID_NVIDIA_FRIDAY)},
/home/nvidia/kernel/Linux_for_Tegra/source/public/kernel/kernel-5.10/include/linux/hid.h:681:53: note: in definition of macro ‘HID_BLUETOOTH_DEVICE’
681 | .bus = BUS_BLUETOOTH, .vendor = (ven), .product = (prod)
/home/nvidia/kernel/Linux_for_Tegra/source/public/kernel/nvidia/drivers/hid/hid-atv-jarvis.c:2169:10: error: ‘USB_DEVICE_ID_NVIDIA_STORMCASTER’ undeclared here (not in a function); did you mean ‘USB_DEVICE_ID_NVIDIA_RAVEN’?
2169 | USB_DEVICE_ID_NVIDIA_STORMCASTER)},
I can’t find any other sources, or anyone who had the same problem. Any idea ?
Thank you
