MODULUS with 2022.3.3 version
I’m using version 2022.3.3 and MODULUS doesn’t work, I can’t find it in WINDOW>EXTENSION.
Could you please help me with this?
Or should I use version 2022.2.0 or earlier? (Modulus Extension — Omniverse Extensions documentation)
If so, where can I find the download link for previous versions?
Thank you very much!
Hi @contato48
Yes, as mentioned in the docs “Currently the extension works with Omniverse USD Composer 2022.2.0 or older”. You should be able to select older version of Omniverse in the launcher.
Disclaimer: The Modulus OV extension is presently paused for development. If you are interested in visualization I would suggest using Modulus to output VTK files then using the Paraview connector to render.
Hi @ngeneva
Thanks for the feedback
My goal is to generate CFD (Computational fluid dynamics) type physics simulations using Omniverse tools.
Question: Would the only way be to use CREATE together with MODULUS or is there another APP that would allow me to do CFD simulations?
Thank you very much for your attention.
