molpro2006.1 segfault
curious if anyone encountered seg fault when starting molpro2006.1
the symptom occurs when I first start molpro, it seg fault within a minute.
after 2 or 3 retrys (restarting molpro), it seems to work. This behaviour is consistent everything. It’s a serial program with PGF and gcc on
rocks 4.3 kernel 2.6.9-55.0.2.ELsmp.
thanks in advance for your help
output file
patkowsk@compute-0-2 patkowsk]$ cat arhfcc.out_1
Primary working directories: /scratch/patkowsk
Secondary working directories: /scratch/patkowsk
skipped …
ERROR EXIT
CURRENT STACK: MAIN
PROGRAMS * TOTAL
CPU TIMES * 0.22
REAL TIME * 0.24 SEC
DISK USED * 0.00 MB
the molpros.rc
-d/scratch/$LOGNAME # directory in which the program should be run
-I/scratch/$LOGNAME # directory to store permanent copies of int files (1)
-W$HOME/wfu # directory to store permanent copies of wf files (2,3)
-L/home/patkowsk/molpro2006.1/lib/ # directory containing library files
-x/home/patkowsk/molpro2006.1/bin/molpros_2006_1_i8_x86_64.exe # executable
-m8000000 # default memory in 8-byte words
-K131072 # mxma cache size in 8-byte words
-B64 # mxma blocking size
-k id=udeledu,date=:2012/10/25,version=:2006&KlYv1dUqDhqeA4ya
–environment MOLPRO_COMPILER=pgf6.0-8
–environment MOLPRO_BLASLIB=atlas
Please try our latest version 7.1-4. Release 6.0-8 is quite old and may have had some bug that we fix in later release.
Thank you,
Hongyon
