MONAI framework is very slow while computing stain normalisation
I am new to MONAI framework and I am working on stain normalization approach to generate images similar to target image using MONAI framework.
I have checked the blog for the implementation of Stain normalization and I found out that the implementation is using numpy rather than cupy or something similar.
Here is the implementation, I found from MONAI blog :
Copyright (c) MONAI Consortium
Licensed under the Apache License, Version 2.0 (the “License”);
you may not use this file except in compliance with the License.
You may obtain a copy of the License at
http://www.apache.org/licenses/LICENSE-2.0
Unless required by applicable law or agreed to in writing, software
distributed under the License is distributed on an “AS IS” BASIS,
WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
See the License for the specific language governing permissions and
limitations under the License.
from future import annotations
import numpy as np
from monai.transforms.transform import Transform
[docs]
class ExtractHEStains(Transform):
“”"Class to extract a target stain from an image, using stain deconvolution (see Note).
Args:
    tli: transmitted light intensity. Defaults to 240.
    alpha: tolerance in percentile for the pseudo-min (alpha percentile)
        and pseudo-max (100 - alpha percentile). Defaults to 1.
    beta: absorbance threshold for transparent pixels. Defaults to 0.15
    max_cref: reference maximum stain concentrations for Hematoxylin & Eosin (H&E).
        Defaults to (1.9705, 1.0308).
Note:
    For more information refer to:
    - the original paper: Macenko et al., 2009 http://wwwx.cs.unc.edu/~mn/sites/default/files/macenko2009.pdf
    - the previous implementations:
      - MATLAB: https://github.com/mitkovetta/staining-normalization
      - Python: https://github.com/schaugf/HEnorm_python
def __init__(
    self, tli: float = 240, alpha: float = 1, beta: float = 0.15, max_cref: tuple | np.ndarray = (1.9705, 1.0308)
) -> None:
    self.tli = tli
    self.alpha = alpha
    self.beta = beta
    self.max_cref = np.array(max_cref)
def _deconvolution_extract_stain(self, image: np.ndarray) -> np.ndarray:
    """Perform Stain Deconvolution and return stain matrix for the image.
    Args:
        image: uint8 RGB image to perform stain deconvolution on
    Return:
        he: H&E absorbance matrix for the image (first column is H, second column is E, rows are RGB values)
    # check image type and values
    if not isinstance(image, np.ndarray):
        raise TypeError("Image must be of type numpy.ndarray.")
    if image.min() < 0:
        raise ValueError("Image should not have negative values.")
    if image.max() > 255:
        raise ValueError("Image should not have values greater than 255.")
    # reshape image and calculate absorbance
    image = image.reshape((-1, 3))
    image = image.astype(np.float32, copy=False) + 1.0
    absorbance = -np.log(image.clip(max=self.tli) / self.tli)
    # remove transparent pixels
    absorbance_hat = absorbance[np.all(absorbance > self.beta, axis=1)]
    if len(absorbance_hat) == 0:
        raise ValueError("All pixels of the input image are below the absorbance threshold.")
    # compute eigenvectors
    _, eigvecs = np.linalg.eigh(np.cov(absorbance_hat.T).astype(np.float32, copy=False))
    # project on the plane spanned by the eigenvectors corresponding to the two largest eigenvalues
    t_hat = absorbance_hat.dot(eigvecs[:, 1:3])
    # find the min and max vectors and project back to absorbance space
    phi = np.arctan2(t_hat[:, 1], t_hat[:, 0])
    min_phi = np.percentile(phi, self.alpha)
    max_phi = np.percentile(phi, 100 - self.alpha)
    v_min = eigvecs[:, 1:3].dot(np.array([(np.cos(min_phi), np.sin(min_phi))], dtype=np.float32).T)
    v_max = eigvecs[:, 1:3].dot(np.array([(np.cos(max_phi), np.sin(max_phi))], dtype=np.float32).T)
    # a heuristic to make the vector corresponding to hematoxylin first and the one corresponding to eosin second
    if v_min[0] > v_max[0]:
        he = np.array((v_min[:, 0], v_max[:, 0]), dtype=np.float32).T
    else:
        he = np.array((v_max[:, 0], v_min[:, 0]), dtype=np.float32).T
    return he
def __call__(self, image: np.ndarray) -> np.ndarray:
    """Perform stain extraction.
    Args:
        image: uint8 RGB image to extract stain from
    return:
        target_he: H&E absorbance matrix for the image (first column is H, second column is E, rows are RGB values)
    target_he = self._deconvolution_extract_stain(image)
    return target_he
[docs]
class NormalizeHEStains(Transform):
“”"Class to normalize patches/images to a reference or target image stain (see Note).
Performs stain deconvolution of the source image using the ExtractHEStains
class, to obtain the stain matrix and calculate the stain concentration matrix
for the image. Then, performs the inverse Beer-Lambert transform to recreate the
patch using the target H&E stain matrix provided. If no target stain provided, a default
reference stain is used. Similarly, if no maximum stain concentrations are provided, a
reference maximum stain concentrations matrix is used.
Args:
    alpha: tolerance in percentile for the pseudo-min (alpha percentile) and
    beta: absorbance threshold for transparent pixels. Defaults to 0.15.
    target_he: target stain matrix. Defaults to ((0.5626, 0.2159), (0.7201, 0.8012), (0.4062, 0.5581)).
        Defaults to [1.9705, 1.0308].
Note:
def __init__(
    self,
    tli: float = 240,
    alpha: float = 1,
    beta: float = 0.15,
    target_he: tuple | np.ndarray = ((0.5626, 0.2159), (0.7201, 0.8012), (0.4062, 0.5581)),
    max_cref: tuple | np.ndarray = (1.9705, 1.0308),
) -> None:
    self.tli = tli
    self.target_he = np.array(target_he)
    self.stain_extractor = ExtractHEStains(tli=self.tli, alpha=alpha, beta=beta, max_cref=self.max_cref)
    """Perform stain normalization.
    Args:
        image: uint8 RGB image/patch to be stain normalized, pixel values between 0 and 255
    Return:
        image_norm: stain normalized image/patch
    if image.min() < 0:
    # extract stain of the image
    he = self.stain_extractor(image)
    h, w, _ = image.shape
    image = image.astype(np.float32) + 1.0
    # rows correspond to channels (RGB), columns to absorbance values
    y = np.reshape(absorbance, (-1, 3)).T
    # determine concentrations of the individual stains
    conc = np.linalg.lstsq(he, y, rcond=None)[0]
    # normalize stain concentrations
    max_conc = np.asarray([np.percentile(conc[0, :], 99), np.percentile(conc[1, :], 99)], dtype=np.float32)
    tmp = np.divide(max_conc, self.max_cref, dtype=np.float32)
    image_c = np.divide(conc, tmp[:, np.newaxis], dtype=np.float32)
    image_norm: np.ndarray = np.multiply(self.tli, np.exp(-self.target_he.dot(image_c)), dtype=np.float32)
    image_norm[image_norm > 255] = 254
    image_norm = np.reshape(image_norm.T, (h, w, 3)).astype(np.uint8)
    return image_norm
For me when I am running on a folder which contains 5400 webp tiles it is taking around half an hour. I have more than 2000 such folders and it takes at least a month to complete this procedure.
Could u please let me know if there is anything I could do to speed up the process.
