Monitor identified as “Nvidia” on Debian 13 (GNOME/Wayland) Driver 595
Issue with Monitor Identification on Fresh Debian 13 Install
System Configuration:
GPU: NVIDIA GeForce RTX 5060
Driver Version: 595.xx (Current/Problematic)
OS: Debian 13 (Trixie/Testing)
Desktop Environment: GNOME 48.7 (Wayland)
Kernel Parameter: nvidia-drm.modeset=1 enabled
Display Setup:
Monitor 1: Connected via HDMI (Detected correctly).
Monitor 2: Connected via DP-to-HDMI adapter (Detected only as "Nvidia" in GNOME settings).
The Problem:
While Monitor 1 displays its correct model name and specifications, Monitor 2 (connected via the adapter) is generically identified as “Nvidia”.
Crucially, this exact hardware configuration worked perfectly with the previous driver version 590.48.01-1, where both monitors were identified correctly with their proper model names. The issue appeared specifically after upgrading to the 595.xx series.
nvidia-bug-report.log.gz (1.1 MB)
The problem is also tracked on version 595.71.05 on Debian 13
nvidia-bug-report.log.gz (660.4 KB)
The problem is also tracked on version 610.43.02 on Debian 13(Linux 6.12.90+deb13-amd64)
nvidia-bug-report.log.gz (476.7 KB)
Ugreen DisplayPort to HDMI 4K 60Hz 25 см Black (MM137) Adapter
The problem is also tracked on version 610.57.04 on Debian 13(Linux 6.12.100+deb13-amd64)
nvidia-bug-report.log.gz (477.0 KB)
The problem is also tracked on version 615.71.09 on Debian 13(Linux 6.12.107
nvidia-bug-report.log.gz (503.2 KB)
+deb13-amd64)
