Monitor is not turning ON after starting device
Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
[1] DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[1] Linux
QNX
other
Hardware Platform
[1] DRIVE AGX Orin Developer Kit (940-63710-0010-100)
other
SDK Manager Version
2.1.0
other
Host Machine Version
[1] native Ubuntu Linux 20.04 Host installed with SDK Manager
other
Issue Description
Dear Team,
My monitor is not turning on after starting the
I am using DP cable to connect to monitor. Tried multiple cables and monitor combination which concluded that the issue is not with the monitor.
Reflash the device as well. Still the issue persist.
In ttyAMC01 logs not able see any error related to DP cables. Please guide me how to proceed. Is there any commands which will help me to debug the issue and find the root cause.
Error String
< Please provide just the error messages here >
Logs
Provide logs in text box instead of image
Please paste the complete application log here. If there are multiple logs, please use multiple text box
Dear @akanksha.jain1,
Were you able to get display earlier and notice issue now with same monitor? What the used monitors?
Did you accept EULA after booting the device first time as indicated in Finalize DRIVE AGX Orin System Setup | NVIDIA Docs
Any reason for using older release?
FYI, If you need display monitor just to check application GUI output, you can use VNC to unblock your development meanwhile. Please see Driveworks 5.14 issue with DRIVE AGX Orin - #4 by SivaRamaKrishnaNV
It was working previously with the same monitor display. Yes we accepted EULA after booting first time. We can try for the newer version, will it solve the monitor issue?
Is it with the same DRIVE OS 6.0.6 release?
If it is a SW/system state issue, it could get resolved with reflash. If you don’t have any dependency on old release, consider moving to latest release .
