Monitoring PX2 (telemetry)
Wonder if there is existing solution to add telemetry to px2? I want to install DCGM (https://github.com/NVIDIA/gpu-monitoring-tools/tree/master/exporters/prometheus-dcgm) or NVML based prometheus exporter (https://github.com/mindprince/nvidia_gpu_prometheus_exporter) on px2 but not sure if it is doable?
Dear @rren,
I do not see aarch64 in NVML supported supported platforms at NVML API Reference Guide :: GPU Deployment and Management Documentation
Do you know how I can check what GPU was specifically used in my PX2 (GP106 etc.)? I saw GP100 was supported on the list following the link you provided.
Or does “GP100” mean the whole “GP10X” series? which would mean all Pascal GPUs are supported?
I found that I could use “devicequery” to get the GPU models (How to Monitor Discrete GPU Workload/Usage on PX2? - #2 by SteveNV)
I am also trying to find the units of temperature metrics from “tegrastats”. When I run “tegrastats GPU-therm”, it gives “GPU-therm 55000”. Is the unit mC here? (i.e. the temperature should be interpreted as 55 celcius?)
Dear @rren,
GP100 does not mean GP 10x series. I don’t find “tegrastats GPU-therm” command working on my machine. Did you check the tegrastats documentation at 5.x_Linux_DPX_SDK
