• Hardware (T4)
• Network Type (Yolov3)
• Training spec file
random_seed: 42
yolov3_config {
big_anchor_shape: "[(114.94, 60.67), (159.06, 114.59), (297.59, 176.38)]"
mid_anchor_shape: "[(42.99, 31.91), (79.57, 31.75), (56.80, 56.93)]"
small_anchor_shape: "[(15.60, 13.88), (30.25, 20.25), (20.67, 49.63)]"
matching_neutral_box_iou: 0.7
arch: "resnet"
nlayers: 18
arch_conv_blocks: 2
loss_loc_weight: 0.8
loss_neg_obj_weights: 100.0
loss_class_weights: 1.0
freeze_bn: false
#freeze_blocks: 0
force_relu: false
training_config {
batch_size_per_gpu: 4
num_epochs: 80
enable_qat: false
checkpoint_interval: 1
learning_rate {
soft_start_annealing_schedule {
min_learning_rate: 1e-6
max_learning_rate: 1e-4
soft_start: 0.1
annealing: 0.5
regularizer {
type: L1
weight: 3e-5
optimizer {
adam {
epsilon: 1e-7
beta1: 0.9
beta2: 0.999
amsgrad: false
pretrain_model_path: "/workspace/tao-experiments/yolo_v3/pretrained_resnet18/pretrained_object_detection_vresnet18/resnet_18.hdf5"
visualizer{
enabled: true
eval_config {
average_precision_mode: SAMPLE
batch_size: 4
matching_iou_threshold: 0.5
nms_config {
confidence_threshold: 0.001
clustering_iou_threshold: 0.5
top_k: 200
force_on_cpu: True
augmentation_config {
hue: 0.1
saturation: 1.5
exposure:1.5
vertical_flip:0
horizontal_flip: 0.5
jitter: 0.3
output_width: 1248
output_height: 384
output_channel: 3
randomize_input_shape_period: 0
dataset_config {
data_sources: {
tfrecords_path: "/workspace/tao-experiments/data/yolo_v3/kitti_trainval/kitti_trainval*"
image_directory_path: "/workspace/tao-experiments/data/training"
include_difficult_in_training: true
image_extension: "png"
target_class_mapping {
key: "car"
value: "car"
key: "pedestrian"
value: "pedestrian"
key: "cyclist"
value: "cyclist"
key: "van"
value: "car"
key: "person_sitting"
value: "pedestrian"
validation_fold: 0
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.)
When we run training with yolov3 training tutorial notebook as i posted the link below
After stating the training , i tried to run the tensorboard monitoring with below command
tensorboard --logdir yolov3_init_test:training_home/yolo_v3/experiment_dir_unpruned/ --host 0.0.0.0 --port 8080
The directly is the parent directory of where the weights folder is there
But when i run the command i can able to access the tensorboard webpage
But i saw error in the terminal so i didn’t get any details in the page
The error is
Can you support on this
