Monitors turn off when in use USD Composer
Asus TUF-RTX4090-O24G-Gaming
Video card passes all crash tests
Drivers were installed different
Only restarting the system helps
hello @Polzovatel3971 -
is this a windows or Linux based system?
Also, can you do a nvidia-smi command prior to starting USD composer. Then the same command after the monitor turns off. reply with the data
Windows
