Hi Chris, we are very excited that your Kaya is almost up and running!
To give an example, say username on host PC is “my_host_username” and username on Nano is “my_nano_username”. Then, we would deploy using “–remote-user my_nano_username”. The script would sync to “deploy/my_host_username/” on Nano. Please note that “sudo” is not needed for deploy script. Thanks for the feedback on documentation. We’ll try to clarify this.
Regarding “I made sure was added as a member of group but that didn’t solve it”:
Are you logged in as ? Otherwise my_nano_username needs to be added to dialout. Did you restart after adding user to dialout? Does running the app with “sudo” command help? What does “ls /dev/ttyUSB0” return?
If you preface with sudo, I think it deploys to deploy/root/, not deploy//. When I didn’t preface with sudo, it gave errors, but I’ll do it again to make sure and post them here
Yes, my username was added to group . Not sure if I rebooted, but can double-check
Running with sudo did not solve it
running dmesg |grep tty returns “usb 1-2.1: FTDI USB Serial Device converter now attached to ttyUSB0” I’ll check “ls /dev/ttyUSB0” returns anything different.
if you don’t preface the deployment on the desktop with , you get a huge amount of errors like this:
chris@chris-NUC7i5BNK:~/isaac$ ./engine/build/deploy.sh --remote-user chris -d jetpack42 -h 192.168.86.47 -p //apps/kaya:joystick-pkg
Building Minidump tools
Building //apps/kaya:joystick-pkg for target platform 'jetpack42'
ERROR: /home/chris/isaac/WORKSPACE:18:1: Traceback (most recent call last):
File "/home/chris/isaac/WORKSPACE", line 18
isaac_engine_workspace()
File "/home/chris/isaac/third_party/engine.bzl", line 20, in isaac_engine_workspace
isaac_new_http_archive(name = "gtest", build_file = clean..."), <5 more arguments>)
File "/home/chris/isaac/engine/build/isaac.bzl", line 371, in isaac_new_http_archive
native.new_http_archive(**kwargs)
type 'struct' has no method new_http_archive()
[and so on for many more pages]
But if you do it with it works:
chris@chris-NUC7i5BNK:~/isaac$ sudo ./engine/build/deploy.sh --remote-user chris -d jetpack42 -h 192.168.86.47 -p //apps/kaya:joystick-pkg
INFO: Analysed target //apps/kaya:joystick-pkg (61 packages loaded, 2694 targets configured).
INFO: Found 1 target...
Target //apps/kaya:joystick-pkg up-to-date:
bazel-bin/apps/kaya/joystick-pkg.tar
INFO: Elapsed time: 8.870s, Critical Path: 1.84s, Remote (0.00% of the time): [queue: 0.00%, setup: 0.00%, process: 0.00%]
INFO: 0 processes.
INFO: Build completed successfully, 1 total action
Deploying //apps/kaya:joystick-pkg (tar) to chris@192.168.86.47 under name 'root'
The authenticity of host '192.168.86.47 (192.168.86.47)' can't be established.
ECDSA key fingerprint is SHA256:mt3y0b7PMfE4v2SUPOtxOc9VOzcpZQh3DY6tspx9iCQ.
Are you sure you want to continue connecting (yes/no)? yes
Warning: Permanently added '192.168.86.47' (ECDSA) to the list of known hosts.
chris@192.168.86.47's password:
sending incremental file list
joystick-pkg/
joystick-pkg/_solib_arm64-v8a/
On the Kaya side, running the Joystick app with either or no works until the Serial Port part:
chris@chris-desktop:~/deploy/root/joystick-pkg$ ./apps/kaya/joystick
2019-05-15 07:16:45.912 WARNING engine/alice/backend/backend.cpp@141: This application does not have an explicit scheduler configuration. One will be autogenerated to the best of the systems abilities if possible.
2019-05-15 07:16:45.912 WARNING engine/gems/scheduler/scheduler.cpp@327: No default execution groups specified. Attempting to create scheduler configuration for 4 remaining cores. This may be non optimal for the system and application.
2019-05-15 07:16:45.912 INFO engine/gems/scheduler/scheduler.cpp@280: Scheduler execution groups are:
2019-05-15 07:16:45.912 INFO engine/gems/scheduler/scheduler.cpp@289: __BlockerGroup__: Cores = [3], Workers = No
2019-0
The location of the file and line number are printed with error message:
2019-05-15 07:17:08.477 ERROR packages/dynamixel/gems/dynamixel.cpp@53: Cannot open port
You seem to be doing everything right. All I can think of is double checking stuff. By printing port name, we would double check “usb_port” parameter indeed gets set to “/dev/ttyUSB0”.
@chris5pb1j
Wonder the version of Isaac SDK you are using.
And would you like to double check the version of bazel you are using, and if all dependencies are installed via engine/build/scripts/install_dependencies.sh.
Ah. That may be the problem. I’ll try downgrading later today.
Out of curiosity, why can’t the correct Bazel just be installed as part of the dependency installation process? It seems weird to have to install that one part manually
I’ve uninstalled Bazel and let the dependency script reinstall the right version. But when I try to deploy to the Jetson device (Kaya), I still get many screens of errors that all point to the same issue:
C++ compilation of rule '@lmdb//:lmdb' failed (Exit 1) crosstool_wrapper_driver_is_not_gcc.py
Furthermore, there is no dynamixel folder in the packages folder(and thus no packages/dynamixel/gems/dynamixel.cpp):
