More than one operator "=" error while compiling with CUDA 12.2
I am trying to build Spconv library with CUDA 12.2 and GCC 9 (for some reasons I can’t use GCC version > 10)
There is a problem related to implicit conversions:
[build] /usr/include/c++/9/bits/stl_algobase.h(342): error: more than one operator “=” matches these operands:
[build] function “__half::operator=(float)” (declared at line 341 of /usr/local/cuda/include/cuda_fp16.hpp)
I have defined
 __CUDA_FP16_DISABLE_IMPLICIT_INTEGER_CONVERTS_FOR_HOST_COMPILERS__
 __CUDA_BF16_DISABLE_IMPLICIT_INTEGER_CONVERTS_FOR_HOST_COMPILERS__
macros as suggested in documentation, but it doesn’t help.
There are conditional compilation strings in
#if !(defined __CUDA_FP16_DISABLE_IMPLICIT_INTEGER_CONVERTS_FOR_HOST_COMPILERS__) || (defined __CUDACC__)
/usr/local/cuda/include/cuda_bf16.hpp
#if !(defined __CUDA_BF16_DISABLE_IMPLICIT_INTEGER_CONVERTS_FOR_HOST_COMPILERS__) || (defined __CUDACC__)
If I try to modify these strings like that:
Spconv library can be compiled succesfully (disable implicit converts macros are applied). So there is some error related to __CUDACC__ macro…
Also I can compile Spconv with CUDA 12.1 without errors.
Could you help with this problem?
