I’ve made a 2x2 screens mosaic configuration.
When i normally stop/restart computer running Windows 10, everything is fine.
After a power loss, mosaic configuration is lost.
I’d like to stick with the configuration made and nobody should change it later.
Restoring files at startup may be an option : where is mosaic configuration saved ?
The best way to do this is to use the command line Mosaic Utility Driver (nvidia.com) and create a batch file that is run at startup of your system to set MOSIAC correctly.
I am trying to use the Mosaic utility because Windows keeps wiping out my mosaic every time it updates. There isn’t a lot of documentation on how to actually use the configuremosaic.exe utility. Can you share a screenshot of what your script looks like?
