Mosaic from 24 to 48 using configuremosaic , no available refresh rates until restart
Hi I have an inquery about configuremosaic.exe and pre/post creating mosiac.
The system is as follows:
A/B cluster of 1 Leader with 9 Followers that have Nvidia RTX A6000 cards at driver 553.62
All the machines have framesync cards that are at fw 2.21
leaders are fed refrence by an evertz 5700 and the followers gain that by using framesync.
All machines are on windows 10 22H2 19045. Each machine has an edid that is avalible to 24, 30,48 and 60 fps
Now these more or less stay at 24fps for all our shoots. Recently weve had a request to move these walls at 48fps and 60fps. Given the amount of the machines and the avalibility of the configuremosaic.exe application, we have tried to speed up the process of manually breaking & recreating mosaic on said machines. However weve encountered some issues. Some machines wont see 48 or 60 as refresh rates though after a restart they show up. When using the configuremoasic app during this issue the moasic will be created at the highest avalible refresh rate, usally 30fps. This was checked in windows display, Nvidia Control Panel, and via the monitor advanced settings in control panel to see what FPS could be achived. All mentioned was 24 or 30 until there was the mentioned restart and then all advertised rates were avaliblie again.
In addition to that, weve had a back & forth on whether invidual screens/monitors need to be set at the refresh rate AND then mosaic could be configurerd or would just simply creating mosaic force the individual monitors to be at set rate?
When you say “Some machines wont see 48 or 60 as refresh rates” - where are you seeing this?
With configureMosaic you can specify the display mode using the commandline argument:
res=width,height,refresh_rate
the current mode of the displays should not matter when setting the Mosaic, but it would help if all the displays used the same EDID and that was forced (via the Nvidia Control Panel under the View System Topology page).
You mention an Evertz house sync signal - at what point are you applying sync? It should be done after setting up Mosaic. Note that the house sync signal must be within 50 PPM of the refresh rate of the displays (or .005%).
Updating to a newer driver and firmware may also help, as many bugs have been fixed since those versions.
Steve
Hallo,
A:I see refresh rates in either configure display or via the mosaic config screen. All machines have the same edid loaded as to keep uniformity. Its when we try to change it to 24/48/60 that it futzes out.
B: so if I have indivdual displays set at say 24fps and create a mosiac at 60fps, those individual displays would be overwritten? Good to know and would help save a step.
C: We apply sync after all computers are moasic’d and only to the leader which creates the timing server.
Both images are the only places I can check to see if the machine is capable of going to X refresh rate, If I only see 24 & 30 then a reboot reestablishes the 24/30/48/60 rates
