Rank newby here and have trawled the search engines with no luck.
Setup
Three HP workstations with Quadro M5000, M4000, M2000
Running through an Aten DP1.2 KVM
Dual Dell U2717D monitors in daisy chain configuration DP/mDP
Ambition
For the two monitors to act as a single wide display - presumably a Mosaic
Currently
The two are acting as clones both showing the same stuff although in NVIDIA Control Panel Cloning is shown as disabled. Control Panel shows each card as Single GPU Sync but the Create New Configuration link is not active.
Info on how to spread the desktop across the two would be most appreciated.
