Motion Blur
Is there anyway to render with motion blur in Create?
Mainly looking for non-deforming transform motion blur for objects, but would also love Volume motion blur.
For path traced mode, you can enable motion blur with these settings in the movie capture window:
FYI
When I wanted to use Movie Capture. So I followed this Movie Capture Documentation.
Movie Capture is an extension and can be enabled by navigating to Window > Extensions Manager and enabling utils.movie_capture. Once enabled you should see a new Panel labeled “Movie Capture” was added to the User Interface. If you close the panel or wish to toggle it off/on, you can navigate to Window > Movie Capture and enable/disable as desired.
However “utils.movie_capture” was not exist and it maybe changed to “MOVIE CAPTURE” (omni.kit.window.movie_maker v0.3.1).
Adding information, Movie Capture was not shown in Window > Movie Capture but Window > Rendering.
Thank you.
My environment is below,
  • Windows 10
  • Omniverse Create 2021.1.0
  • MOVIE CAPTURE v0.3.1
Yes you’re right. The doc is outdated and I will report a doc bug for it.
Thank you for reporting this and sorry for the inconvenience.
Hi kamatoto, as far as I can see we have updated the movie capture doc.
