i am not able to trace proper API documentation for ‘Motion Planning((Path Evaluation, Path Selection )’ and Vehicle Control (Lateral control & longitudinal control ) OR any dw*** sample application.
Can you help on that ?
Best Regards,
Manas Sarkar
Dear @manas.sarkar ,
Could you share details about used DRIVE release?
Here is the details:
Software Version
Target Operating System
Linux
Hardware Platform
SDK Manager Version
1.4.0.7363
Host Machine Version
native Ubuntu 18.04
Are you referring to file:///usr/local/driveworks-2.2/doc/nvapp_html/arch_vehicleDynamicsController.html ?
Please see file:///usr/local/driveworks-2.2-old/doc/nvsdk_html/dwx_modules.html#dwx_vehicle_motion_actuation if it helps?
As mentioned by you, 'arch_vehicleDynamicsController.html ’ talks about - “how VDC module receives desired path and speed/acceleration information from the Behavior Planner module”. But details of this behavior Planner module is not given or not any sample application code.
I aslo checked into ‘arch_trajectoryEstimation.html’ also, which is indicating egomotion module as Motion estimator or Trajectory Estimator. But here is also no details or proper explanation of the matter like - “trajectory estimation is the result of putting all these estimated motion vectors between subsequent time events, which results in the trajectory of the vehicle.”.
Please suggest where i should look.
Best Regards,
Manas Sarkar
The pages you are referring to are part of road runner application which is built on top of DW. The implementation details of roadrunner is not open in public.
