I am trying to mount a cv2 plugin specification as a “.csv” in “/etc/nvidia-container-runtime/host-files-for-container.d” but I am having troubles writing all the relevant dependencies. I do not want to install and build OpenCV inside my container, I want to mount it.
So far, this is what I have. It´s not working.
dir, /usr/lib/aarch64-linux-gnu
dir, /usr/share/opencv4
lib, /usr/lib/aarch64-linux-gnu/libopencv_calib3d.so.4.1.1
lib, /usr/lib/aarch64-linux-gnu/libopencv_core.so.4.1.1
lib, /usr/lib/aarch64-linux-gnu/libopencv_dnn.so.4.1.1
lib, /usr/lib/aarch64-linux-gnu/libopencv_features2d.so.4.1.1
lib, /usr/lib/aarch64-linux-gnu/libopencv_flann.so.4.1.1
lib, /usr/lib/aarch64-linux-gnu/libopencv_gapi.so.4.1.1
lib, /usr/lib/aarch64-linux-gnu/libopencv_highgui.so.4.1.1
lib, /usr/lib/aarch64-linux-gnu/libopencv_imgcodecs.so.4.1.1
lib, /usr/lib/aarch64-linux-gnu/libopencv_imgproc.so.4.1.1
lib, /usr/lib/aarch64-linux-gnu/libopencv_ml.so.4.1.1
lib, /usr/lib/aarch64-linux-gnu/libopencv_objdetect.so.4.1.1
lib, /usr/lib/aarch64-linux-gnu/libopencv_photo.so.4.1.1
lib, /usr/lib/aarch64-linux-gnu/libopencv_stitching.so.4.1.1
lib, /usr/lib/aarch64-linux-gnu/libopencv_video.so.4.1.1
lib, /usr/lib/aarch64-linux-gnu/libopencv_videoio.so.4.1.1
lib, /usr/share/opencv4/haarcascades/haarcascade_eye.xml
lib, /usr/share/opencv4/haarcascades/haarcascade_eye_tree_eyeglasses.xml
lib, /usr/share/opencv4/haarcascades/haarcascade_frontalcatface.xml
lib, /usr/share/opencv4/haarcascades/haarcascade_frontalcatface_extended.xml
lib, /usr/share/opencv4/haarcascades/haarcascade_frontalface_alt.xml
lib, /usr/share/opencv4/haarcascades/haarcascade_frontalface_alt2.xml
lib, /usr/share/opencv4/haarcascades/haarcascade_frontalface_alt_tree.xml
lib, /usr/share/opencv4/haarcascades/haarcascade_frontalface_default.xml
lib, /usr/share/opencv4/haarcascades/haarcascade_fullbody.xml
lib, /usr/share/opencv4/haarcascades/haarcascade_lefteye_2splits.xml
lib, /usr/share/opencv4/haarcascades/haarcascade_licence_plate_rus_16stages.xml
lib, /usr/share/opencv4/haarcascades/haarcascade_lowerbody.xml
lib, /usr/share/opencv4/haarcascades/haarcascade_profileface.xml
lib, /usr/share/opencv4/haarcascades/haarcascade_righteye_2splits.xml
lib, /usr/share/opencv4/haarcascades/haarcascade_russian_plate_number.xml
lib, /usr/share/opencv4/haarcascades/haarcascade_smile.xml
lib, /usr/share/opencv4/haarcascades/haarcascade_upperbody.xml
lib, /usr/share/opencv4/lbpcascades/lbpcascade_frontalcatface.xml
lib, /usr/share/opencv4/lbpcascades/lbpcascade_frontalface.xml
lib, /usr/share/opencv4/lbpcascades/lbpcascade_frontalface_improved.xml
lib, /usr/share/opencv4/lbpcascades/lbpcascade_profileface.xml
lib, /usr/share/opencv4/lbpcascades/lbpcascade_silverware.xml
Is there any example of a working plugin for OpenCV?
This is not an installation related problem. While running “sudo dpkg --get-selections | grep nvidia” everything is installed.
Many thanks!!
