Mount Windows Shared Drive on Jetson TX2
I am able to mount this external shared drive using the Jetson desktop file manager UI. But I can’t figure out how to do it on the command line so that I can include it in a startup script.
I’ve tried many different variations similar to this and this is the same shared drive I’m mounting with the UI.
sudo mount -t ntfs-3g -o username=ocUser //10.0.0.240/kukaD /mnt/smb
ntfs-3g: Failed to access volume ‘//10.0.0.240/kukaD’: No such file or directory
ntfs-3g 2015.3.14AR.1 integrated FUSE 28 - Third Generation NTFS Driver
Configuration type 7, XATTRS are on, POSIX ACLS are on
Copyright (C) 2005-2007 Yura Pakhuchiy
Copyright (C) 2006-2009 Szabolcs Szakacsits
Copyright (C) 2007-2015 Jean-Pierre Andre
Copyright (C) 2009 Erik Larsson
Usage: ntfs-3g [-o option[,…]] <device|image_file> <mount_point>
Options: ro (read-only mount), windows_names, uid=, gid=,
umask=, fmask=, dmask=, streams_interface=.
Please see the details in the manual (type: man ntfs-3g).
Example: ntfs-3g /dev/sda1 /mnt/windows
Thanks,
Mike
Your device argument to mount looks like a network share, but ntfs-3g driver looks like it wants a local block device. When you have a windows fileshare you might use -t cifs independantly from what filesystem your blockdevice under windows has.
When you can mount the device with a UI, than it may show in the output of
mount
(thats with no arguments)
what device and what „driver“ you might need.
