The AGX Xavier developer kit documentation explicitly states that the module may be orientated on any side (see image below).
I cannot find information regarding whether the production module (SoM) can be orientated on its side.
The thermal design guide shows heat pipes within the AGX Xavier, therefore I can’t be certain that side orientation is permitted. Teardown photos of the developer kit do not show these heat pipes.
Is it permitted to mount the AGX Xavier production module on its side?
One final question on the topic, do you know if the heat pipes are are wicked heat pipes, or wickless (non-wicked, gravity assisted) heat pipes? I ask as wicked heat pipes can work against gravity within limits.
