Mouse trails in RDP after installing updates
After installing updates on my Jetson Orin Nano, I now see mouse trails. I am RDP’ing into the nano from standard Windows RDP and I’m using the built-in “Remote Control” on the nano. This wasn’t happening prior to doing the updates. I’m on the latest and greatest of everything and would prefer not switching to an entirely new RDP setup.
Anyone know why updates would cause the mouse trails to appear? Note, that all suggested Windows settings (e.g. Accessibility/Trails, etc.) are disabled - nothing changed on that side. So, it’s 100% on the Orin Nano and related to updates.
Thanks in advance.
For this description, do you mean you install Ubuntu update? Or our Jetpack update? And please share your Jetpack version.
I am on Jetpack 7.2-b187. It was an Ubuntu update - the UI updater that pops up when I log in. The only software I’ve installed is VS Code, other than that it’s the straight Jetson Orin Nano Super Developer Kit.
Please run the command to get what packages are updated:
$ cat /var/log/apt/history.log
See if this can bring some clue about the issue.
This gave no clue. To be specific, I’m seeing two mouse cursors. So, for some reason, two mouse cursors are being drawn, and one occasionally leaves trails. Did some hardware mouse rendering flag get turned on somewhere? I looked for where this is set but I don’t even have the files (xrdp) I’m supposed to look for and am not even sure xrdp is what I’m using as gnome-remote-desktop-daemon appears to have CPU when I’m RDP’d in.
No, there is no hardware mouse rendering flag. It is more like certain update in Ubuntu 24.04 triggers the issue. Please share hostory.log. Would like to see what packages are updated.
Start-Date: 2026-08-23 11:12:05
Commandline: aptdaemon role=‘role-commit-packages’ sender=‘:1.26271’
Upgrade: openvpn:arm64 (2.6.19-0ubuntu0.24.04.2, 2.6.19-0ubuntu0.24.04.3), nvidia-l4t-weston:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), nvidia-vpi:arm64 (7.2-b187, 7.2.1-b49), libnvptxcompiler-13-2:arm64 (13.2.78-1, 13.2.86-1), dnsmasq:arm64 (2.90-2ubuntu0.3, 2.90-2ubuntu0.4), containerd.io:arm64 (2.2.6-1~ubuntu.24.04~noble, 2.3.3-1~ubuntu.24.04~noble), libreoffice-calc:arm64 (4:24.2.7-0ubuntu0.24.04.5, 4:24.2.7-0ubuntu0.24.04.6), docker-compose-plugin:arm64 (5.3.1-1~ubuntu.24.04~noble, 5.5.0-1~ubuntu.24.04~noble), libcusolver-dev-13-2:arm64 (12.2.0.1-1, 12.2.0.11-1), libcurand-13-2:arm64 (10.4.2.55-1, 10.4.2.66-1), libpam-runtime:arm64 (1.5.3-5ubuntu5.5, 1.5.3-5ubuntu5.6), udev:arm64 (255.4-1ubuntu8.16, 255.4-1ubuntu8.17), systemd-oomd:arm64 (255.4-1ubuntu8.16, 255.4-1ubuntu8.17), nvidia-l4t-vulkan-sc-samples:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), libexif-dev:arm64 (0.6.24-1build2, 0.6.24-1ubuntu0.24.04.1), libreoffice-gnome:arm64 (4:24.2.7-0ubuntu0.24.04.5, 4:24.2.7-0ubuntu0.24.04.6), cuda-cudart-dev-13-2:arm64 (13.2.75-1, 13.2.86-1), uno-libs-private:arm64 (4:24.2.7-0ubuntu0.24.04.5, 4:24.2.7-0ubuntu0.24.04.6), libreoffice-base-core:arm64 (4:24.2.7-0ubuntu0.24.04.5, 4:24.2.7-0ubuntu0.24.04.6), libcudla-dev-13-2:arm64 (13.2.75-1, 13.2.86-1), bind9-host:arm64 (1:9.18.39-0ubuntu0.24.04.5, 1:9.18.39-0ubuntu0.24.04.6), libgssapi-krb5-2:arm64 (1.20.1-6ubuntu2.6, 1.20.1-6ubuntu2.8), libcudla-13-2:arm64 (13.2.75-1, 13.2.86-1), docker-ce-cli:arm64 (5:29.6.1-1~ubuntu.24.04~noble, 5:29.7.2-1~ubuntu.24.04~noble), nvidia-l4t-vulkan-sc-sdk:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), openssh-client:arm64 (1:9.6p1-3ubuntu13.16, 1:9.6p1-3ubuntu13.18), libjbig2dec0:arm64 (0.20-1build3, 0.20-1ubuntu0.24.04.1), nvidia-l4t-kernel-partitions:arm64 (6.8.12-tegra-39.2.0-20260601141651, 6.8.12-tegra-39.2.1-20260806224157), cuda-gdb-13-2:arm64 (13.2.75-1, 13.2.86-1), libreoffice-uiconfig-impress:arm64 (4:24.2.7-0ubuntu0.24.04.5, 4:24.2.7-0ubuntu0.24.04.6), libreoffice-core:arm64 (4:24.2.7-0ubuntu0.24.04.5, 4:24.2.7-0ubuntu0.24.04.6), nvidia-l4t-firstboot:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), nvidia-l4t-firmware:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), nvidia-l4t-init-openrm:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), nvidia-opencv:arm64 (7.2-b187, 7.2.1-b49), libfprint-2-2:arm64 (1:1.94.7+tod1-0ubuntu5~24.04.7, 1:1.94.7+tod1-0ubuntu5~24.04.8), nvidia-l4t-kernel-oot-headers:arm64 (6.8.12-tegra-39.2.0-20260601141651, 6.8.12-tegra-39.2.1-20260806224157), gnome-control-center-faces:arm64 (1:46.7-0ubuntu0.24.04.4, 1:46.7-0ubuntu0.24.04.5), systemd-timesyncd:arm64 (255.4-1ubuntu8.16, 255.4-1ubuntu8.17), tzdata:arm64 (2026b-0ubuntu0.24.04.1, 2026c-0ubuntu0.24.04.1), libldb2:arm64 (2:2.8.0+samba4.19.5+dfsg-4ubuntu9.6, 2:2.8.0+samba4.19.5+dfsg-4ubuntu9.7), ntfs-3g:arm64 (1:2022.10.3-1.2ubuntu3.1, 1:2022.10.3-1.2ubuntu3.2), libvirt-daemon:arm64 (10.0.0-2ubuntu8.14, 10.0.0-2ubuntu8.16), nvidia-l4t-jetson-multimedia-api:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), libatopology2t64:arm64 (1.2.11-1ubuntu0.2, 1.2.11-1ubuntu0.3), network-manager-config-connectivity-ubuntu:arm64 (1.46.0-1ubuntu2.7, 1.46.0-1ubuntu2.8), libpipewire-0.3-common:arm64 (1.0.5-1ubuntu3.2, 1.0.5-1ubuntu3.3), nvidia-l4t-multimedia-openrm:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), libpam-systemd:arm64 (255.4-1ubuntu8.16, 255.4-1ubuntu8.17), pipewire-pulse:arm64 (1.0.5-1ubuntu3.2, 1.0.5-1ubuntu3.3), libreoffice-uiconfig-math:arm64 (4:24.2.7-0ubuntu0.24.04.5, 4:24.2.7-0ubuntu0.24.04.6), nvidia-l4t-wayland:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), libnvjpeg-dev-13-2:arm64 (13.1.0.48-1, 13.1.0.59-1), libreoffice-common:arm64 (4:24.2.7-0ubuntu0.24.04.5, 4:24.2.7-0ubuntu0.24.04.6), libreoffice-uiconfig-writer:arm64 (4:24.2.7-0ubuntu0.24.04.5, 4:24.2.7-0ubuntu0.24.04.6), apport-gtk:arm64 (2.28.2-0ubuntu0.1, 2.28.3-0ubuntu0.1), nvidia-l4t-kernel-oot-modules:arm64 (6.8.12-tegra-39.2.0-20260601141651, 6.8.12-tegra-39.2.1-20260806224157), libuno-sal3t64:arm64 (4:24.2.7-0ubuntu0.24.04.5, 4:24.2.7-0ubuntu0.24.04.6), nvidia-container:arm64 (7.2-b187, 7.2.1-b49), tar:arm64 (1.35+dfsg-3ubuntu0.2, 1.35+dfsg-3ubuntu0.4), libheif1:arm64 (1.17.6-1ubuntu4.5, 1.17.6-1ubuntu4.7), ure:arm64 (4:24.2.7-0ubuntu0.24.04.5, 4:24.2.7-0ubuntu0.24.04.6), nvidia-l4t-kernel:arm64 (6.8.12-tegra-39.2.0-20260601141651, 6.8.12-tegra-39.2.1-20260806224157), vim:arm64 (2:9.1.0016-1ubuntu7.17, 2:9.1.0016-1ubuntu7.19), cuda-libraries-13-2:arm64 (13.2.1-1, 13.2.2-1), nvidia-jetpack-runtime:arm64 (7.2-b187, 7.2.1-b49), cuda-nsight-compute-13-2:arm64 (13.2.1-1, 13.2.2-1), xxd:arm64 (2:9.1.0016-1ubuntu7.17, 2:9.1.0016-1ubuntu7.19), libheif-plugin-libde265:arm64 (1.17.6-1ubuntu4.5, 1.17.6-1ubuntu4.7), nvidia-l4t-wpasupplicant:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), libnvjitlink-dev-13-2:arm64 (13.2.78-1, 13.2.86-1), cuda-tools-13-2:arm64 (13.2.1-1, 13.2.2-1), heif-thumbnailer:arm64 (1.17.6-1ubuntu4.5, 1.17.6-1ubuntu4.7), remmina-plugin-rdp:arm64 (1.4.35+dfsg-0ubuntu5.2, 1.4.43+dfsg-0ubuntu0.24.04.2), libopencv-samples:arm64 (4.8.0-3-g6ef37b4, 4.8.0-4-g18251aa), libgif7:arm64 (5.2.2-1ubuntu1, 5.2.2-1ubuntu1.2), cuda-cuobjdump-13-2:arm64 (13.2.78-1, 13.2.86-1), cuda-libraries-dev-13-2:arm64 (13.2.1-1, 13.2.2-1), cuda-toolkit-13-2:arm64 (13.2.1-1, 13.2.2-1), remmina-plugin-vnc:arm64 (1.4.35+dfsg-0ubuntu5.2, 1.4.43+dfsg-0ubuntu0.24.04.2), alsa-ucm-conf:arm64 (1.2.10-1ubuntu5.13, 1.2.10-1ubuntu5.14), nvidia-tensorrt-dev:arm64 (7.2-b187, 7.2.1-b49), libnvfatbin-13-2:arm64 (13.2.78-1, 13.2.86-1), nvidia-l4t-graphics-demos:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), vim-common:arm64 (2:9.1.0016-1ubuntu7.17, 2:9.1.0016-1ubuntu7.19), cuda-toolkit-config-common:arm64 (13.2.75-1, 13.2.86-1), libreoffice-draw:arm64 (4:24.2.7-0ubuntu0.24.04.5, 4:24.2.7-0ubuntu0.24.04.6), libinput10:arm64 (1.25.0-1ubuntu3.5, 1.25.0-1ubuntu3.6), cuda-driver-dev-13-2:arm64 (13.2.75-1, 13.2.86-1), libsystemd0:arm64 (255.4-1ubuntu8.16, 255.4-1ubuntu8.17), cuda-nsight-systems-13-2:arm64 (13.2.1-1, 13.2.2-1), nvidia-l4t-adaruntime:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), nvidia-l4t-3d-core:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), vpi4-dev:arm64 (4.1.3, 4.1.4), nvidia-l4t-nvpmodel:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), libnss-systemd:arm64 (255.4-1ubuntu8.16, 255.4-1ubuntu8.17), nvidia-l4t-cuda-utils:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), libwbclient0:arm64 (2:4.19.5+dfsg-4ubuntu9.6, 2:4.19.5+dfsg-4ubuntu9.7), libreoffice-uiconfig-calc:arm64 (4:24.2.7-0ubuntu0.24.04.5, 4:24.2.7-0ubuntu0.24.04.6), python3-httplib2:arm64 (0.20.4-3, 0.20.4-3ubuntu0.1), libudev-dev:arm64 (255.4-1ubuntu8.16, 255.4-1ubuntu8.17), cuda-nvrtc-13-2:arm64 (13.2.78-1, 13.2.86-1), cuda-command-line-tools-13-2:arm64 (13.2.1-1, 13.2.2-1), openssh-server:arm64 (1:9.6p1-3ubuntu13.16, 1:9.6p1-3ubuntu13.18), wireless-regdb:arm64 (2025.10.07-0ubuntu1~24.04.1, 2026.02.04-0ubuntu1~24.04.1), nvidia-l4t-kernel-nvgpu:arm64 (6.8.12-tegra-39.2.0-20260601141651, 6.8.12-tegra-39.2.1-20260806224157), pipewire:arm64 (1.0.5-1ubuntu3.2, 1.0.5-1ubuntu3.3), cuda-nvdisasm-13-2:arm64 (13.2.78-1, 13.2.86-1), libcurand-dev-13-2:arm64 (10.4.2.55-1, 10.4.2.66-1), nvidia-l4t-tools:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), libkrb5support0:arm64 (1.20.1-6ubuntu2.6, 1.20.1-6ubuntu2.8), nvidia-opencv-dev:arm64 (7.2-b187, 7.2.1-b49), nvidia-l4t-power-adapter-check:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), libreoffice-impress:arm64 (4:24.2.7-0ubuntu0.24.04.5, 4:24.2.7-0ubuntu0.24.04.6), libgphoto2-dev:arm64 (2.5.31-2.1ubuntu1, 2.5.31-2.1ubuntu1.1), nvidia-l4t-firmware-openrm:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), nvidia-l4t-core:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), nvidia-l4t-firmware-nvgpu:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), nvidia-l4t-kernel-dtbs:arm64 (6.8.12-tegra-39.2.0-20260601141651, 6.8.12-tegra-39.2.1-20260806224157), remmina-plugin-secret:arm64 (1.4.35+dfsg-0ubuntu5.2, 1.4.43+dfsg-0ubuntu0.24.04.2), libxpm4:arm64 (1:3.5.17-1build2, 1:3.5.17-1ubuntu0.24.04.1), libopencv-python:arm64 (4.8.0-3-g6ef37b4, 4.8.0-4-g18251aa), fonts-opensymbol:arm64 (4:102.12+LibO24.2.7-0ubuntu0.24.04.5, 4:102.12+LibO24.2.7-0ubuntu0.24.04.6), systemd:arm64 (255.4-1ubuntu8.16, 255.4-1ubuntu8.17), libudev1:arm64 (255.4-1ubuntu8.16, 255.4-1ubuntu8.17), nvidia-l4t-optee:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), nvidia-l4t-cuda:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), wget:arm64 (1.21.4-1ubuntu4.1, 1.21.4-1ubuntu4.5), remmina:arm64 (1.4.35+dfsg-0ubuntu5.2, 1.4.43+dfsg-0ubuntu0.24.04.2), libnvjpeg-13-2:arm64 (13.1.0.48-1, 13.1.0.59-1), docker-buildx-plugin:arm64 (0.35.0-1~ubuntu.24.04~noble, 0.36.1-1~ubuntu.24.04~noble), cuda-toolkit-13-2-config-common:arm64 (13.2.75-1, 13.2.86-1), libvirt0:arm64 (10.0.0-2ubuntu8.14, 10.0.0-2ubuntu8.16), nvidia-l4t-nvml:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), libcurl3t64-gnutls:arm64 (8.5.0-2ubuntu10.11, 8.5.0-2ubuntu10.12), power-profiles-daemon:arm64 (0.21-1ubuntu1, 0.21-1ubuntu2), cuda-sanitizer-13-2:arm64 (13.2.76-1, 13.2.87-1), libheif-plugin-aomdec:arm64 (1.17.6-1ubuntu4.5, 1.17.6-1ubuntu4.7), libasound2t64:arm64 (1.2.11-1ubuntu0.2, 1.2.11-1ubuntu0.3), docker-ce:arm64 (5:29.6.1-1~ubuntu.24.04~noble, 5:29.7.2-1~ubuntu.24.04~noble), nvidia-l4t-openwfd:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), libarchive13t64:arm64 (3.7.2-2ubuntu0.7, 3.7.2-2ubuntu0.8), nvidia-l4t-nvfancontrol:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), pva-sdk-2.9-l4t:arm64 (2.9.1, 2.9.4), libheif-plugin-aomenc:arm64 (1.17.6-1ubuntu4.5, 1.17.6-1ubuntu4.7), libxfont2:arm64 (1:2.0.6-1build1, 1:2.0.6-1+deb13u1build0.24.04.2), python3.12-vpi4:arm64 (4.1.3, 4.1.4), opencv-samples-data:arm64 (4.8.0-3-g6ef37b4, 4.8.0-4-g18251aa), nvidia-l4t-bsp:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), vpi4-samples:arm64 (4.1.3, 4.1.4), systemd-dev:arm64 (255.4-1ubuntu8.16, 255.4-1ubuntu8.17), nvidia-l4t-cuda-nvgpu:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), nvidia-l4t-nvsci:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), nvidia-l4t-init:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), cuda-documentation-13-2:arm64 (13.2.75-1, 13.2.86-1), libgstreamer-plugins-good1.0-0:arm64 (1.24.2-1ubuntu1.4, 1.24.2-1ubuntu1.5), nvidia-nsight-systems:arm64 (7.2-b187, 7.2.1-b49), nvidia-l4t-gbm:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), libcublas-dev-13-2:arm64 (13.4.0.1-1, 13.4.1.3-1), nvidia-l4t-jetsonpower-gui-tools:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), libc6:arm64 (2.39-0ubuntu8.7, 2.39-0ubuntu8.8), locales:arm64 (2.39-0ubuntu8.7, 2.39-0ubuntu8.8), dnsmasq-base:arm64 (2.90-2ubuntu0.3, 2.90-2ubuntu0.4), ubuntu-pro-client-l10n:arm64 (37.2ubuntu~24.04, 37.2ubuntu~24.04.1), gir1.2-nm-1.0:arm64 (1.46.0-1ubuntu2.7, 1.46.0-1ubuntu2.8), libreoffice-style-colibre:arm64 (4:24.2.7-0ubuntu0.24.04.5, 4:24.2.7-0ubuntu0.24.04.6), cuda-cuxxfilt-13-2:arm64 (13.2.78-1, 13.2.86-1), libkrb5-3:arm64 (1.20.1-6ubuntu2.6, 1.20.1-6ubuntu2.8), gir1.2-accountsservice-1.0:arm64 (23.13.9-2ubuntu6, 23.13.9-2ubuntu6.1), libopencv:arm64 (4.8.0-3-g6ef37b4, 4.8.0-4-g18251aa), libpam-modules:arm64 (1.5.3-5ubuntu5.5, 1.5.3-5ubuntu5.6), nvidia-cuda-dev:arm64 (7.2-b187, 7.2.1-b49), nvidia-l4t-display-kernel:arm64 (6.8.12-tegra-39.2.0-20260601141651, 6.8.12-tegra-39.2.1-20260806224157), libspa-0.2-bluetooth:arm64 (1.0.5-1ubuntu3.2, 1.0.5-1ubuntu3.3), cuda-culibos-dev-13-2:arm64 (13.2.75-1, 13.2.86-1), nvidia-l4t-configs:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), libgstreamer-plugins-good1.0-dev:arm64 (1.24.2-1ubuntu1.4, 1.24.2-1ubuntu1.5), gstreamer1.0-gtk3:arm64 (1.24.2-1ubuntu1.4, 1.24.2-1ubuntu1.5), nvidia-l4t-pva:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), nvidia-l4t-multimedia:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), libreoffice-writer:arm64 (4:24.2.7-0ubuntu0.24.04.5, 4:24.2.7-0ubuntu0.24.04.6), libfprint-2-tod1:arm64 (1:1.94.7+tod1-0ubuntu5~24.04.7, 1:1.94.7+tod1-0ubuntu5~24.04.8), libsmbclient0:arm64 (2:4.19.5+dfsg-4ubuntu9.6, 2:4.19.5+dfsg-4ubuntu9.7), cuda-cccl-13-2:arm64 (13.2.75-1, 13.2.86-1), nvidia-tensorrt:arm64 (7.2-b187, 7.2.1-b49), gstreamer1.0-plugins-good:arm64 (1.24.2-1ubuntu1.4, 1.24.2-1ubuntu1.5), nvidia-l4t-multimedia-utils:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), cuda-cupti-13-2:arm64 (13.2.75-1, 13.2.86-1), nvidia-l4t-vulkan-sc-nvgpu:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), libvirt-daemon-driver-qemu:arm64 (10.0.0-2ubuntu8.14, 10.0.0-2ubuntu8.16), systemd-resolved:arm64 (255.4-1ubuntu8.16, 255.4-1ubuntu8.17), nvidia-l4t-x11:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), nvidia-l4t-usb-service:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), nvidia-l4t-oobe:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), libcusparse-dev-13-2:arm64 (12.7.10.1-1, 12.7.10.12-1), docker-ce-rootless-extras:arm64 (5:29.6.1-1~ubuntu.24.04~noble, 5:29.7.2-1~ubuntu.24.04~noble), nvidia-l4t-apt-source:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), gstreamer1.0-pipewire:arm64 (1.0.5-1ubuntu3.2, 1.0.5-1ubuntu3.3), bind9-dnsutils:arm64 (1:9.18.39-0ubuntu0.24.04.5, 1:9.18.39-0ubuntu0.24.04.6), nvidia-l4t-kernel-headers:arm64 (6.8.12-tegra-39.2.0-20260601141651, 6.8.12-tegra-39.2.1-20260806224157), network-manager:arm64 (1.46.0-1ubuntu2.7, 1.46.0-1ubuntu2.8), libgphoto2-6t64:arm64 (2.5.31-2.1ubuntu1, 2.5.31-2.1ubuntu1.1), rsyslog:arm64 (8.2312.0-3ubuntu9.2, 8.2312.0-3ubuntu9.3), libk5crypto3:arm64 (1.20.1-6ubuntu2.6, 1.20.1-6ubuntu2.8), libfreerdp3-3:arm64 (3.5.1+dfsg1-0ubuntu1.6, 3.30.0+dfsg-0ubuntu0.24.04.2), libnpp-13-2:arm64 (13.1.0.48-1, 13.1.0.59-1), cuda-visual-tools-13-2:arm64 (13.2.1-1, 13.2.2-1), libnvjitlink-13-2:arm64 (13.2.78-1, 13.2.86-1), libreoffice-uiconfig-draw:arm64 (4:24.2.7-0ubuntu0.24.04.5, 4:24.2.7-0ubuntu0.24.04.6), libhttp-date-perl:arm64 (6.06-1, 6.06-1ubuntu0.24.04.1), nvidia-l4t-bootloader:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), nvidia-l4t-vulkan-sc-openrm:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), snapd:arm64 (2.75.2+ubuntu24.04, 2.76.3+ubuntu24.04), libssl-dev:arm64 (3.0.13-0ubuntu3.11, 3.0.13-0ubuntu3.12), libsqlite3-0:arm64 (3.45.1-1ubuntu2.6, 3.45.1-1ubuntu2.7), libcusolver-13-2:arm64 (12.2.0.1-1, 12.2.0.11-1), libcurl4t64:arm64 (8.5.0-2ubuntu10.11, 8.5.0-2ubuntu10.12), nvidia-l4t-gstreamer:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), pipewire-audio:arm64 (1.0.5-1ubuntu3.2, 1.0.5-1ubuntu3.3), libhtml-parser-perl:arm64 (3.81-1build3, 3.81-1ubuntu0.1), pipewire-bin:arm64 (1.0.5-1ubuntu3.2, 1.0.5-1ubuntu3.3), libasound2-data:arm64 (1.2.11-1ubuntu0.2, 1.2.11-1ubuntu0.3), gnome-control-center-data:arm64 (1:46.7-0ubuntu0.24.04.4, 1:46.7-0ubuntu0.24.04.5), nvidia-vpi-dev:arm64 (7.2-b187, 7.2.1-b49), distro-info-data:arm64 (0.60ubuntu0.6, 0.72-0ubuntu0.24.04.1), linux-firmware:arm64 (20240318.git3b128b60-0ubuntu2.27, 20240318.git3b128b60-0ubuntu2.29), vim-runtime:arm64 (2:9.1.0016-1ubuntu7.17, 2:9.1.0016-1ubuntu7.19), libwinpr3-3:arm64 (3.5.1+dfsg1-0ubuntu1.6, 3.30.0+dfsg-0ubuntu0.24.04.2), libfreerdp-server3-3:arm64 (3.5.1+dfsg1-0ubuntu1.6, 3.30.0+dfsg-0ubuntu0.24.04.2), vpi4-python-src:arm64 (4.1.3, 4.1.4), libpam-modules-bin:arm64 (1.5.3-5ubuntu5.5, 1.5.3-5ubuntu5.6), nvidia-cudnn:arm64 (7.2-b187, 7.2.1-b49), libcufft-13-2:arm64 (12.2.0.46-1, 12.2.0.57-1), nvidia-l4t-multimedia-nvgpu:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), libgphoto2-port12t64:arm64 (2.5.31-2.1ubuntu1, 2.5.31-2.1ubuntu1.1), tzdata-legacy:arm64 (2026b-0ubuntu0.24.04.1, 2026c-0ubuntu0.24.04.1), nvidia-l4t-video-codec-openrm:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), python3-uno:arm64 (4:24.2.7-0ubuntu0.24.04.5, 4:24.2.7-0ubuntu0.24.04.6), cuda-nvprune-13-2:arm64 (13.2.78-1, 13.2.86-1), libc-dev-bin:arm64 (2.39-0ubuntu8.7, 2.39-0ubuntu8.8), nvidia-l4t-camera:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), openssh-sftp-server:arm64 (1:9.6p1-3ubuntu13.16, 1:9.6p1-3ubuntu13.18), libpam0g:arm64 (1.5.3-5ubuntu5.5, 1.5.3-5ubuntu5.6), nvidia-l4t-kernel-module-configs:arm64 (6.8.12-tegra-39.2.0-20260601141651, 6.8.12-tegra-39.2.1-20260806224157), libspa-0.2-modules:arm64 (1.0.5-1ubuntu3.2, 1.0.5-1ubuntu3.3), libopencv-dev:arm64 (4.8.0-3-g6ef37b4, 4.8.0-4-g18251aa), bind9-libs:arm64 (1:9.18.39-0ubuntu0.24.04.5, 1:9.18.39-0ubuntu0.24.04.6), nvidia-l4t-libvulkan:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), nvidia-cupva:arm64 (7.2-b187, 7.2.1-b49), accountsservice:arm64 (23.13.9-2ubuntu6, 23.13.9-2ubuntu6.1), libyelp0:arm64 (42.2-1ubuntu0.24.04.1, 42.2-1ubuntu0.24.04.2), nvidia-l4t-nvpmodel-gui-tools:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), samba-libs:arm64 (2:4.19.5+dfsg-4ubuntu9.6, 2:4.19.5+dfsg-4ubuntu9.7), nvidia-cudnn-dev:arm64 (7.2-b187, 7.2.1-b49), gnome-control-center:arm64 (1:46.7-0ubuntu0.24.04.4, 1:46.7-0ubuntu0.24.04.5), libcublas-13-2:arm64 (13.4.0.1-1, 13.4.1.3-1), libc-bin:arm64 (2.39-0ubuntu8.7, 2.39-0ubuntu8.8), libsystemd-shared:arm64 (255.4-1ubuntu8.16, 255.4-1ubuntu8.17), libc-devtools:arm64 (2.39-0ubuntu8.7, 2.39-0ubuntu8.8), yelp:arm64 (42.2-1ubuntu0.24.04.1, 42.2-1ubuntu0.24.04.2), libnvvpi4:arm64 (4.1.3, 4.1.4), libpipewire-0.3-0t64:arm64 (1.0.5-1ubuntu3.2, 1.0.5-1ubuntu3.3), python3-apport:arm64 (2.28.2-0ubuntu0.1, 2.28.3-0ubuntu0.1), nvidia-l4t-initrd:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), libfreerdp-client3-3:arm64 (3.5.1+dfsg1-0ubuntu1.6, 3.30.0+dfsg-0ubuntu0.24.04.2), cuda-cudart-13-2:arm64 (13.2.75-1, 13.2.86-1), libntfs-3g89t64:arm64 (1:2022.10.3-1.2ubuntu3.1, 1:2022.10.3-1.2ubuntu3.2), cuda-nvrtc-dev-13-2:arm64 (13.2.78-1, 13.2.86-1), libssl3t64:arm64 (3.0.13-0ubuntu3.11, 3.0.13-0ubuntu3.12), libc6-dbg:arm64 (2.39-0ubuntu8.7, 2.39-0ubuntu8.8), libc6-dev:arm64 (2.39-0ubuntu8.7, 2.39-0ubuntu8.8), code:arm64 (1.128.0-1783465398, 1.134.0-1787078750), libreoffice-style-yaru:arm64 (4:24.2.7-0ubuntu0.24.04.5, 4:24.2.7-0ubuntu0.24.04.6), systemd-sysv:arm64 (255.4-1ubuntu8.16, 255.4-1ubuntu8.17), libreoffice-uiconfig-common:arm64 (4:24.2.7-0ubuntu0.24.04.5, 4:24.2.7-0ubuntu0.24.04.6), python3-idna:arm64 (3.6-2ubuntu0.1, 3.6-2ubuntu0.2), libcufft-dev-13-2:arm64 (12.2.0.46-1, 12.2.0.57-1), curl:arm64 (8.5.0-2ubuntu10.11, 8.5.0-2ubuntu10.12), heif-gdk-pixbuf:arm64 (1.17.6-1ubuntu4.5, 1.17.6-1ubuntu4.7), apport-core-dump-handler:arm64 (2.28.2-0ubuntu0.1, 2.28.3-0ubuntu0.1), libnpp-dev-13-2:arm64 (13.1.0.48-1, 13.1.0.59-1), libcusparse-13-2:arm64 (12.7.10.1-1, 12.7.10.12-1), libreoffice-math:arm64 (4:24.2.7-0ubuntu0.24.04.5, 4:24.2.7-0ubuntu0.24.04.6), cuda-profiler-api-13-2:arm64 (13.2.75-1, 13.2.86-1), libreoffice-gtk3:arm64 (4:24.2.7-0ubuntu0.24.04.5, 4:24.2.7-0ubuntu0.24.04.6), libpipewire-0.3-modules:arm64 (1.0.5-1ubuntu3.2, 1.0.5-1ubuntu3.3), nvidia-l4t-bootloader-utils:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), remmina-common:arm64 (1.4.35+dfsg-0ubuntu5.2, 1.4.43+dfsg-0ubuntu0.24.04.2), libnvfatbin-dev-13-2:arm64 (13.2.78-1, 13.2.86-1), libuno-cppu3t64:arm64 (4:24.2.7-0ubuntu0.24.04.5, 4:24.2.7-0ubuntu0.24.04.6), cuda-crt-13-2:arm64 (13.2.78-1, 13.2.86-1), cuda-nvtx-13-2:arm64 (13.2.75-1, 13.2.86-1), nvidia-l4t-jetson-io:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), libaccountsservice0:arm64 (23.13.9-2ubuntu6, 23.13.9-2ubuntu6.1), libnm0:arm64 (1.46.0-1ubuntu2.7, 1.46.0-1ubuntu2.8), libuno-cppuhelpergcc3-3t64:arm64 (4:24.2.7-0ubuntu0.24.04.5, 4:24.2.7-0ubuntu0.24.04.6), libde265-0:arm64 (1.0.15-1build3, 1.0.15-1ubuntu0.1), nvidia-l4t-cuda-openrm:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), libpq5:arm64 (16.14-0ubuntu0.24.04.1, 16.15-0ubuntu0.24.04.1), python3-problem-report:arm64 (2.28.2-0ubuntu0.1, 2.28.3-0ubuntu0.1), libreoffice-style-elementary:arm64 (4:24.2.7-0ubuntu0.24.04.5, 4:24.2.7-0ubuntu0.24.04.6), cuda-nvcc-13-2:arm64 (13.2.78-1, 13.2.86-1), cuda-cupti-dev-13-2:arm64 (13.2.75-1, 13.2.86-1), libuno-purpenvhelpergcc3-3t64:arm64 (4:24.2.7-0ubuntu0.24.04.5, 4:24.2.7-0ubuntu0.24.04.6), nvidia-l4t-extlinux:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), nvidia-l4t-kernel-openrm:arm64 (6.8.12-tegra-39.2.0-20260601141651, 6.8.12-tegra-39.2.1-20260806224157), libuno-salhelpergcc3-3t64:arm64 (4:24.2.7-0ubuntu0.24.04.5, 4:24.2.7-0ubuntu0.24.04.6), cuda-compiler-13-2:arm64 (13.2.1-1, 13.2.2-1), opencv-licenses:arm64 (4.8.0-3-g6ef37b4, 4.8.0-4-g18251aa), apport:arm64 (2.28.2-0ubuntu0.1, 2.28.3-0ubuntu0.1), pipewire-alsa:arm64 (1.0.5-1ubuntu3.2, 1.0.5-1ubuntu3.3), libexif12:arm64 (0.6.24-1build2, 0.6.24-1ubuntu0.24.04.1), nvidia-jetpack-dev:arm64 (7.2-b187, 7.2.1-b49), cuda-tileiras-13-2:arm64 (13.2.78-1, 13.2.86-1), nvidia-cuda:arm64 (7.2-b187, 7.2.1-b49), nvidia-l4t-xwayland:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), cuda-toolkit-13-config-common:arm64 (13.2.75-1, 13.2.86-1), libnvvm-13-2:arm64 (13.2.78-1, 13.2.86-1), openssl:arm64 (3.0.13-0ubuntu3.11, 3.0.13-0ubuntu3.12), nvidia-l4t-vulkan-sc-dev:arm64 (39.2.0-20260601141651, 39.2.1-20260806224157), libasound2-dev:arm64 (1.2.11-1ubuntu0.2, 1.2.11-1ubuntu0.3), libinput-bin:arm64 (1.25.0-1ubuntu3.5, 1.25.0-1ubuntu3.6), cuda-nvml-dev-13-2:arm64 (13.2.82-1, 13.2.86-1), linux-libc-dev:arm64 (6.8.0-134.134, 6.8.0-138.138), ubuntu-pro-client:arm64 (37.2ubuntu~24.04, 37.2ubuntu~24.04.1)
End-Date: 2026-08-23 11:24:14
Start-Date: 2026-08-23 11:25:13
Upgrade: console-setup:arm64 (1.226ubuntu1, 1.226ubuntu1.1), console-setup-linux:arm64 (1.226ubuntu1, 1.226ubuntu1.1), keyboard-configuration:arm64 (1.226ubuntu1, 1.226ubuntu1.1)
End-Date: 2026-08-23 11:25:25
Start-Date: 2026-08-30 12:16:35
Commandline: aptdaemon role=‘role-commit-packages’ sender=‘:1.5483’
Upgrade: vim:arm64 (2:9.1.0016-1ubuntu7.19, 2:9.1.0016-1ubuntu7.20), xxd:arm64 (2:9.1.0016-1ubuntu7.19, 2:9.1.0016-1ubuntu7.20), sssd-proxy:arm64 (2.9.4-1.1ubuntu6.6, 2.9.4-1.1ubuntu6.7), vim-common:arm64 (2:9.1.0016-1ubuntu7.19, 2:9.1.0016-1ubuntu7.20), sssd-ad-common:arm64 (2.9.4-1.1ubuntu6.6, 2.9.4-1.1ubuntu6.7), sssd-ipa:arm64 (2.9.4-1.1ubuntu6.6, 2.9.4-1.1ubuntu6.7), libcurl3t64-gnutls:arm64 (8.5.0-2ubuntu10.12, 8.5.0-2ubuntu10.13), sssd-krb5-common:arm64 (2.9.4-1.1ubuntu6.6, 2.9.4-1.1ubuntu6.7), libsss-nss-idmap0:arm64 (2.9.4-1.1ubuntu6.6, 2.9.4-1.1ubuntu6.7), libssl-dev:arm64 (3.0.13-0ubuntu3.12, 3.0.13-0ubuntu3.15), libcurl4t64:arm64 (8.5.0-2ubuntu10.12, 8.5.0-2ubuntu10.13), vim-runtime:arm64 (2:9.1.0016-1ubuntu7.19, 2:9.1.0016-1ubuntu7.20), python3-sss:arm64 (2.9.4-1.1ubuntu6.6, 2.9.4-1.1ubuntu6.7), sssd:arm64 (2.9.4-1.1ubuntu6.6, 2.9.4-1.1ubuntu6.7), libssl3t64:arm64 (3.0.13-0ubuntu3.12, 3.0.13-0ubuntu3.15), code:arm64 (1.134.0-1787078750, 1.135.0-1787669187), libnss-sss:arm64 (2.9.4-1.1ubuntu6.6, 2.9.4-1.1ubuntu6.7), sssd-krb5:arm64 (2.9.4-1.1ubuntu6.6, 2.9.4-1.1ubuntu6.7), libipa-hbac0t64:arm64 (2.9.4-1.1ubuntu6.6, 2.9.4-1.1ubuntu6.7), curl:arm64 (8.5.0-2ubuntu10.12, 8.5.0-2ubuntu10.13), libsss-idmap0:arm64 (2.9.4-1.1ubuntu6.6, 2.9.4-1.1ubuntu6.7), sssd-ad:arm64 (2.9.4-1.1ubuntu6.6, 2.9.4-1.1ubuntu6.7), sssd-common:arm64 (2.9.4-1.1ubuntu6.6, 2.9.4-1.1ubuntu6.7), libpam-sss:arm64 (2.9.4-1.1ubuntu6.6, 2.9.4-1.1ubuntu6.7), sssd-ldap:arm64 (2.9.4-1.1ubuntu6.6, 2.9.4-1.1ubuntu6.7), libsss-certmap0:arm64 (2.9.4-1.1ubuntu6.6, 2.9.4-1.1ubuntu6.7), openssl:arm64 (3.0.13-0ubuntu3.12, 3.0.13-0ubuntu3.15)
End-Date: 2026-08-30 12:18:05
Start-Date: 2026-08-30 12:19:26
Upgrade: containerd.io:arm64 (2.3.3-1~ubuntu.24.04~noble, 2.3.4-1~ubuntu.24.04~noble), libpam-runtime:arm64 (1.5.3-5ubuntu5.6, 1.5.3-5ubuntu5.7), python3.12:arm64 (3.12.3-1ubuntu0.15, 3.12.3-1ubuntu0.16), perl:arm64 (5.38.2-3.2ubuntu0.3, 5.38.2-3.2ubuntu0.4), libheif1:arm64 (1.17.6-1ubuntu4.7, 1.17.6-1ubuntu4.8), libheif-plugin-libde265:arm64 (1.17.6-1ubuntu4.7, 1.17.6-1ubuntu4.8), libp11-kit0:arm64 (0.25.3-4ubuntu2.1, 0.25.3-4ubuntu2.2), heif-thumbnailer:arm64 (1.17.6-1ubuntu4.7, 1.17.6-1ubuntu4.8), libpython3.12-minimal:arm64 (3.12.3-1ubuntu0.15, 3.12.3-1ubuntu0.16), libproc2-0:arm64 (2:4.0.4-4ubuntu3.2, 2:4.0.4-4ubuntu3.3), python3.12-venv:arm64 (3.12.3-1ubuntu0.15, 3.12.3-1ubuntu0.16), p11-kit-modules:arm64 (0.25.3-4ubuntu2.1, 0.25.3-4ubuntu2.2), libheif-plugin-aomdec:arm64 (1.17.6-1ubuntu4.7, 1.17.6-1ubuntu4.8), libheif-plugin-aomenc:arm64 (1.17.6-1ubuntu4.7, 1.17.6-1ubuntu4.8), libpython3.12t64:arm64 (3.12.3-1ubuntu0.15, 3.12.3-1ubuntu0.16), libpam-modules:arm64 (1.5.3-5ubuntu5.6, 1.5.3-5ubuntu5.7), libpam-modules-bin:arm64 (1.5.3-5ubuntu5.6, 1.5.3-5ubuntu5.7), procps:arm64 (2:4.0.4-4ubuntu3.2, 2:4.0.4-4ubuntu3.3), libpython3.12-dev:arm64 (3.12.3-1ubuntu0.15, 3.12.3-1ubuntu0.16), perl-base:arm64 (5.38.2-3.2ubuntu0.3, 5.38.2-3.2ubuntu0.4), libpam0g:arm64 (1.5.3-5ubuntu5.6, 1.5.3-5ubuntu5.7), python3.12-dev:arm64 (3.12.3-1ubuntu0.15, 3.12.3-1ubuntu0.16), heif-gdk-pixbuf:arm64 (1.17.6-1ubuntu4.7, 1.17.6-1ubuntu4.8), python3.12-minimal:arm64 (3.12.3-1ubuntu0.15, 3.12.3-1ubuntu0.16), perl-modules-5.38:arm64 (5.38.2-3.2ubuntu0.3, 5.38.2-3.2ubuntu0.4), libperl5.38t64:arm64 (5.38.2-3.2ubuntu0.3, 5.38.2-3.2ubuntu0.4), libpython3.12-stdlib:arm64 (3.12.3-1ubuntu0.15, 3.12.3-1ubuntu0.16), p11-kit:arm64 (0.25.3-4ubuntu2.1, 0.25.3-4ubuntu2.2)
End-Date: 2026-08-30 12:20:06
Start-Date: 2026-08-31 08:54:05
Commandline: aptdaemon role=‘role-commit-packages’ sender=‘:1.1141’
Upgrade: coreutils:arm64 (9.4-3ubuntu6.2, 9.4-3ubuntu6.3), bind9-host:arm64 (1:9.18.39-0ubuntu0.24.04.6, 1:9.18.39-0ubuntu0.24.04.7), libssh-4:arm64 (0.10.6-2ubuntu0.4, 0.10.6-2ubuntu0.5), bzip2:arm64 (1.0.8-5.1build0.1, 1.0.8-5.1ubuntu0.1), libminizip1t64:arm64 (1:1.3.dfsg-3.1ubuntu2.1, 1:1.3.dfsg-3.1ubuntu2.2), libssh-gcrypt-4:arm64 (0.10.6-2ubuntu0.4, 0.10.6-2ubuntu0.5), zlib1g-dev:arm64 (1:1.3.dfsg-3.1ubuntu2.1, 1:1.3.dfsg-3.1ubuntu2.2), libmysqlclient21:arm64 (8.0.46-0ubuntu0.24.04.3, 8.0.46-0ubuntu0.24.04.4), diffutils:arm64 (1:3.10-1build1, 1:3.10-1ubuntu0.1), bind9-dnsutils:arm64 (1:9.18.39-0ubuntu0.24.04.6, 1:9.18.39-0ubuntu0.24.04.7), libfreerdp3-3:arm64 (3.30.0+dfsg-0ubuntu0.24.04.2, 3.31.0+dfsg-0ubuntu0.24.04.1), libwinpr3-3:arm64 (3.30.0+dfsg-0ubuntu0.24.04.2, 3.31.0+dfsg-0ubuntu0.24.04.1), libfreerdp-server3-3:arm64 (3.30.0+dfsg-0ubuntu0.24.04.2, 3.31.0+dfsg-0ubuntu0.24.04.1), bind9-libs:arm64 (1:9.18.39-0ubuntu0.24.04.6, 1:9.18.39-0ubuntu0.24.04.7), libattr1:arm64 (1:2.5.2-1build1.1, 1:2.5.2-1ubuntu0.1), libfreerdp-client3-3:arm64 (3.30.0+dfsg-0ubuntu0.24.04.2, 3.31.0+dfsg-0ubuntu0.24.04.1), libbz2-1.0:arm64 (1.0.8-5.1build0.1, 1.0.8-5.1ubuntu0.1), zlib1g:arm64 (1:1.3.dfsg-3.1ubuntu2.1, 1:1.3.dfsg-3.1ubuntu2.2)
End-Date: 2026-08-31 08:54:17
Please downgrade the packages for a try:
$ sudo apt install --allow-downgrades libfreerdp-server3-3=3.5.0+dfsg1-0ubuntu1 libfreerdp-client3-3=3.5.0+dfsg1-0ubuntu1 libfreerdp3-3=3.5.0+dfsg1-0ubuntu1 libwinpr3-3=3.5.0+dfsg1-0ubuntu1
