The board config should be jetson-nano-qspi-sd
Please check if your Linux_for_Tegra/bootloader folder has system.img or not.
Mounting a file requires loopback. Use “-o loop
”, e.g.:
sudo mount -o loop bootloader/system.img.raw ./tmp_system
Without the loopback option it assumes “bootloader/system.img.raw
” is a block device special file, but it is really just binary content with no meaning until loopback covers it.
OK. I did all that. First without the ‘-o loop’, then With that added option.
Both times I got the same UBUNTU Box message
"Installation failed
The installer encountered an unrecoverable error. A desktop session will now be run that you may investigate the problem or try installing again.’ Box message OK, I selected OK
I am seeing many 'Started Session ‘23’ of user gnome-initial-setup
Startup user Manager for UID 123
Started Wait until snap is fully seeded
The last one so far is a Green [ OK ] started update UTMP about System Runlevel Changes. at 16:35.
I give up!
I wanted to do this the Nvidia way, but …
I finished using the JetsonHacks method.
If you could post a full log of the command used, then the debug messages would become usable. An example of logging a command (I don’t know what your specific command is, so I’ll pretend the command is “ls
ls 2>&1 | tee my_log.txt
(substitute everything you used for your command with “ls
”, and then append everything from the “2>&1
” and further to the right…should create “my_log.txt
If the command and error are from a purely GUI app which you did not run on command line, then there might be some alternative method of logging, but I don’t know what your most recent error is from.
Just a note, moving to an SSD or other setup has changed over time. Not sure if the JetsonHacks method applies to your release. You can see your release via “head -n 1 /etc/nv_tegra_release
Now I have completed a few simple steps (without using the SDK and other things) and very easily launched the system from a USB media to Jetson-Nano.
- I downloaded the latest image for SD card for Jetson-Nano, unpacked it and wrote it to the SD card (as usual images are written to any medium).
- Connected the resulting SD card to the Nano (a monitor, keyboard and mouse are connected to it, no PC connections are needed).
- Turned on the power. The system automatically started from the SD card and itself (without my participation) updated the bootloader in Nano (SPI).
- The system started automatically from the SD card .
- I performed the initial settings Turned off Nano.
- Wrote the same image for SD card to a USB drive. I opened a file on a USB drive in the editor (/boot/extlinux/extlinux.conf) and simply replaced the fragment in the APPEND line with “mmcblk0p1” with “sda1”.
- I connected the USB media to the Nano, turned on the power and voila, the system is running from the USB media.
I pay attention, I didn’t do any complex operations with the SDK and other things, the whole process took 15 minutes.
ps As a USB carrier, I used a USB-SD card adapter and used the same SD card as a USB. But I think it doesn’t matter which USB media to use. The logs clearly show that the system is running and fully works only from a USB drive.
