Hi there,
I am trying to move the RFS from the internal memory(/dev/mmcblk0) to the M.2 type M PCIe NVME( /dev/nvme0n1) flash memory.
I tried already this suggestions. But always gets stuck on bootloader. Luckly I can revert everything throught the terminal.
https://forums.developer.nvidia.com/t/booting-from-nvme-on-tx2/54117/29
Here is my output from /proc/cmdline
jetson@jetson-desktop:~$ cat /proc/cmdline
root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x2772e0000 gpt usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2031647.1 bl_prof_dataptr=0x10000@0x275840000 sdhci_tegra.en_boot_part_access=1 quiet
The current working for mmc /boot/extlinux/extlinux.conf
jetson@jetson-desktop:~$ cat /boot/extlinux/extlinux.conf
TIMEOUT 30
DEFAULT primary
MENU TITLE L4T boot options
LABEL primary
MENU LABEL primary kernel
LINUX /boot/Image
INITRD /boot/initrd
APPEND ${cbootargs} quiet
jetson@jetson-desktop:~$ ls /dev/nvme0
nvme0 nvme0n1
I tried to replace the APPEND ${cbootargs} quiet from the /boot/extlinux/extlinux.conf to
APPEND root=/dev/nvme0n1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x2772e0000 gpt usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2031647.1 bl_prof_dataptr=0x10000@0x275840000 sdhci_tegra.en_boot_part_access=1 quiet
But then it gets stuck on boot. I have then under bash terminal mount the mmc and change the extlinux.conf back to the original in order to be able to boot.
Any toughts what I might be missing?
Any help would be much appreciated
