So I managed to get access to the TX from the console. The Rx somehow doesnt work. but for now should be enough.
Here is the U-boot log
[0000.179] I> Welcome to MB2(TBoot-BPMP)(version: 01.00.160913-t186-M-00.00-mobile-7d3edb9d)
[0000.187] I> bit @ 0xd480000
[0000.190] I> Boot-device: eMMC
[0000.198] I> sdmmc bdev is already initialized
[0000.202] I> pmic: reset reason (nverc) : 0x0
[0000.234] I> Found 18 partitions in SDMMC_BOOT (instance 3)
[0000.253] I> Found 33 partitions in SDMMC_USER (instance 3)
[0000.259] W> No valid slot number is found in scratch register
[0000.264] W> Return default slot: _a
[0000.268] I> A/B: bin_type (16) slot 0
[0000.271] I> Loading partition bpmp-fw at 0xd7800000
[0000.276] I> Reading two headers - addr:0xd7800000 blocks:1
[0000.282] I> Addr: 0xd7800000, start-block: 58777608, num_blocks: 1
[0000.306] I> Binary(16) of size 533504 is loaded @ 0xd7800000
[0000.312] W> No valid slot number is found in scratch register
[0000.318] W> Return default slot: _a
[0000.321] I> A/B: bin_type (17) slot 0
[0000.325] I> Loading partition bpmp-fw-dtb at 0xd79f0000
[0000.330] I> Reading two headers - addr:0xd79f0000 blocks:1
[0000.336] I> Addr: 0xd79f0000, start-block: 58780024, num_blocks: 1
[0000.359] I> Binary(17) of size 465840 is loaded @ 0xd798e200
[0000.537] I> Loading SCE-FW ...
[0000.540] W> No valid slot number is found in scratch register
[0000.545] W> Return default slot: _a
[0000.549] I> A/B: bin_type (12) slot 0
[0000.552] I> Loading partition sce-fw at 0xd7300000
[0000.557] I> Reading two headers - addr:0xd7300000 blocks:1
[0000.563] I> Addr: 0xd7300000, start-block: 58784120, num_blocks: 1
[0000.582] I> Binary(12) of size 125168 is loaded @ 0xd7300000
[0000.587] I> Init SCE
[0000.590] I> Loading APE-FW ...
[0000.593] W> No valid slot number is found in scratch register
[0000.598] W> Return default slot: _a
[0000.602] I> A/B: bin_type (11) slot 0
[0000.605] I> Loading partition adsp-fw at 0xd7400000
[0000.610] I> Reading two headers - addr:0xd7400000 blocks:1
[0000.616] I> Addr: 0xd7400000, start-block: 58761224, num_blocks: 1
[0000.635] I> Binary(11) of size 107808 is loaded @ 0xd7400000
[0000.641] I> Copy BTCM section
[0000.644] W> No valid slot number is found in scratch register
[0000.649] W> Return default slot: _a
[0000.653] I> A/B: bin_type (13) slot 0
[0000.656] I> Loading partition cpu-bootloader at 0x96000000
[0000.662] I> Reading two headers - addr:0x96000000 blocks:1
[0000.667] I> Addr: 0x96000000, start-block: 58740744, num_blocks: 1
[0000.688] I> Binary(13) of size 283728 is loaded @ 0x96000000
[0000.694] W> No valid slot number is found in scratch register
[0000.700] W> Return default slot: _a
[0000.703] I> A/B: bin_type (20) slot 0
[0000.707] I> Loading partition bootloader-dtb at 0x8520f400
[0000.712] I> Reading two headers - addr:0x8520f400 blocks:1
[0000.718] I> Addr: 0x8520f400, start-block: 58742792, num_blocks: 1
[0000.739] I> Binary(20) of size 371232 is loaded @ 0x8520f400
[0000.745] W> No valid slot number is found in scratch register
[0000.751] W> Return default slot: _a
[0000.754] I> A/B: bin_type (14) slot 0
[0000.758] I> Loading partition secure-os at 0x8530f600
[0000.763] I> Reading two headers - addr:0x8530f600 blocks:1
[0000.768] I> Addr: 0x8530f600, start-block: 58744840, num_blocks: 1
[0000.789] I> Binary(14) of size 312752 is loaded @ 0x8530f600
[0000.797] I> TOS boot-params @ 0x85000000
[0000.801] I> TOS params prepared
[0000.804] I> Loading EKS ...
[0000.807] I> A/B: bin_type (15) slot 0
[0000.810] I> Loading partition eks at 0x8590f800
[0000.815] I> Reading two headers - addr:0x8590f800 blocks:1
[0000.820] I> Addr: 0x8590f800, start-block: 58757128, num_blocks: 1
[0000.839] I> Binary(15) of size 1040 is loaded @ 0x8590f800
[0000.844] I> EKB detected (length: 0x400) @ 0x8590f800
[0000.850] I> Copied encrypted keys
[0000.853] I> boot profiler @ 0x275844000
[0000.857] I> boot profiler for TOS @ 0x275844000
[0000.862] I> Unhalting SCE
[0000.865] I> Primary Memory Start:80000000 Size:70000000
[0000.870] I> Extended Memory Start:f0110000 Size:1856f0000
[0000.876] I> MB2(TBoot-BPMP) done
NOTICE: BL31: v1.3(release):23b153a63
NOTICE: BL31: Built : 22:43:09, Dec 9 2019
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
keystore-demo: 141: Hello world from keystore-demo app
keystore-demo: 207: main: EKB contents match expected value
exit called, thread 0xffffffffea87ad58, name trusty_app_2_7d18fc60-e9fc-11e8
platform_bootstrap_epilog: trusty bootstrap complete
[0001.237] I> Welcome to Cboot
[0001.240] I> Cboot Version: t186-c3c778fb
[0001.244] I> CPU-BL Params @ 0x275800000
[0001.247] I> 0) Base:0x00000000 Size:0x00000000
[0001.252] I> 1) Base:0x277f00000 Size:0x00100000
[0001.256] I> 2) Base:0x277e00000 Size:0x00100000
[0001.261] I> 3) Base:0x277d00000 Size:0x00100000
[0001.265] I> 4) Base:0x277c00000 Size:0x00100000
[0001.270] I> 5) Base:0x277b00000 Size:0x00100000
[0001.274] I> 6) Base:0x277800000 Size:0x00200000
[0001.279] I> 7) Base:0x277400000 Size:0x00400000
[0001.283] I> 8) Base:0x277a00000 Size:0x00100000
[0001.288] I> 9) Base:0x277300000 Size:0x00100000
[0001.293] I> 10) Base:0x276800000 Size:0x00800000
[0001.297] I> 11) Base:0x30000000 Size:0x00040000
[0001.301] I> 12) Base:0xf0000000 Size:0x00100000
[0001.306] I> 13) Base:0x30040000 Size:0x00001000
[0001.310] I> 14) Base:0x30048000 Size:0x00001000
[0001.315] I> 15) Base:0x30049000 Size:0x00001000
[0001.319] I> 16) Base:0x3004a000 Size:0x00001000
[0001.324] I> 17) Base:0x3004b000 Size:0x00001000
[0001.328] I> 18) Base:0x3004c000 Size:0x00001000
[0001.332] I> 19) Base:0x3004d000 Size:0x00001000
[0001.337] I> 20) Base:0x3004e000 Size:0x00001000
[0001.341] I> 21) Base:0x3004f000 Size:0x00001000
[0001.346] I> 22) Base:0x00000000 Size:0x00000000
[0001.350] I> 23) Base:0xf0100000 Size:0x00010000
[0001.355] I> 24) Base:0x00000000 Size:0x00000000
[0001.359] I> 25) Base:0x00000000 Size:0x00000000
[0001.363] I> 26) Base:0x00000000 Size:0x00000000
[0001.368] I> 27) Base:0x00000000 Size:0x00000000
[0001.372] I> 28) Base:0x84400000 Size:0x00400000
[0001.377] I> 29) Base:0x30000000 Size:0x00010000
[0001.381] I> 30) Base:0x278000000 Size:0x08000000
[0001.386] I> 31) Base:0x00000000 Size:0x00000000
[0001.390] I> 32) Base:0x276000000 Size:0x00600000
[0001.395] I> 33) Base:0x80000000 Size:0x70000000
[0001.399] I> 34) Base:0xf0110000 Size:0x1856f0000
[0001.404] I> 35) Base:0x00000000 Size:0x00000000
[0001.408] I> 36) Base:0x00000000 Size:0x00000000
[0001.412] I> 37) Base:0x2772e0000 Size:0x00020000
[0001.417] I> 38) Base:0x84000000 Size:0x00400000
[0001.421] I> 39) Base:0x96000000 Size:0x02000000
[0001.426] I> 40) Base:0x85000000 Size:0x01200000
[0001.430] I> 41) Base:0x275800000 Size:0x00500000
[0001.435] I> 42) Base:0x00000000 Size:0x00000000
[0001.439] I> 43) Base:0x00000000 Size:0x00000000
[0001.444] GIC-SPI Target CPU: 4
[0001.447] Interrupts Init done
[0001.450] calling constructors
[0001.453] initializing heap
[0001.456] initializing threads
[0001.459] initializing timers
[0001.462] creating bootstrap completion thread
[0001.467] top of bootstrap2()
[0001.470] CPU: ARM Cortex A57
[0001.473] CPU: MIDR: 0x411FD073, MPIDR: 0x80000100
[0001.478] initializing platform
[0001.482] I> Bl_dtb @0x8520f400
[0001.485] I> gpio framework initialized
[0001.491] I> tegrabl_gpio_driver_register: register 'nvidia,tegra186-gpio' driver
[0001.501] I> tegrabl_gpio_driver_register: register 'nvidia,tegra186-gpio-aon' driver
[0001.509] I> GPIO framework and drivers are initialized.
[0001.514] I> Boot-device: eMMC
[0001.521] I> sdmmc bdev is already initialized
[0001.552] I> Found 18 partitions in SDMMC_BOOT (instance 3)
[0001.569] I> Found 33 partitions in SDMMC_USER (instance 3)
[0001.574] W> opt-in fuse is not set, skip fuse_burning
[0001.579] I> Reserved memory at 0xfbe00000 for U-Boot relocation
[0001.585] W> No valid slot number is found in scratch register
[0001.591] W> Return default slot: _a
[0001.594] I> A/B: bin_type (21) slot 0
[0001.598] I> Loading partition kernel-dtb at 0x80000000 from device(0x1)
[0001.615] I> Kernel_dtb @0x80000000
[0001.619] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xee
[0001.627] E> I2C: slave not found in slaves.
[0001.631] E> I2C: Could not write 0 bytes to slave: 0x00ee with repeat start false.
[0001.639] E> I2C_DEV: Failed to send register address 0x00000004.
[0001.644] E> I2C_DEV: Could not write 1 registers of size 1 to slave 0xee at 0x00000004 via instance 0.
[0001.654] E> tca9539_device_init: failed to write polar reg
[0001.659] E> tegrabl_tca9539_init: failed to init device!
[0001.664] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xe8
[0001.673] I> tegrabl_gpio_driver_register: register 'tca9539_gpio_driver' driver
[0001.683] I> fixed regulator driver initialized
[0001.716] I> register 'maxim' power off handle
[0001.722] I> virtual i2c enabled
[0001.725] I> registered 'maxim,max77620' pmic
[0001.730] I> tegrabl_gpio_driver_register: register 'max77620-gpio' driver
[0001.743] I> Find /i2c@c250000's alias i2c7
[0001.747] I> Reading eeprom i2c=7 address=0x50
[0001.776] I> Device at /i2c@c250000:0x50
[0001.780] I> Reading eeprom i2c=7 address=0x57
[0001.784] E> I2C: slave not found in slaves.
[0001.789] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0001.796] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.802] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 7.
[0001.812] E> eeprom: Failed to read I2C slave device
[0001.816] I> Eeprom read failed 0x3526070d
[0001.821] I> Find /i2c@c240000's alias i2c1
[0001.825] I> Reading eeprom i2c=1 address=0x51
[0001.830] E> I2C: slave not found in slaves.
[0001.834] E> I2C: Could not write 0 bytes to slave: 0x00a2 with repeat start true.
[0001.842] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.848] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa2 at 0x00000000 via instance 1.
[0001.857] E> eeprom: Retry to read I2C slave device.
[0001.862] E> I2C: slave not found in slaves.
[0001.866] E> I2C: Could not write 0 bytes to slave: 0x00a2 with repeat start true.
[0001.874] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.880] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa2 at 0x00000000 via instance 1.
[0001.889] E> eeprom: Failed to read I2C slave device
[0001.894] I> Eeprom read failed 0x3526070d
[0001.899] I> Find /i2c@3160000's alias i2c0
[0001.903] I> Reading eeprom i2c=0 address=0x50
[0001.907] E> I2C: slave not found in slaves.
[0001.911] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.919] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.925] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 0.
[0001.934] E> eeprom: Failed to read I2C slave device
[0001.939] I> Eeprom read failed 0x3526070d
[0001.944] I> Find /i2c@3180000's alias i2c2
[0001.948] I> Reading eeprom i2c=2 address=0x54
[0001.952] I> Enabling gpio chip_id = 2, gpio pin = 9
[0001.957] C> GPIO driver for chip_id 0x2 could not be found
[0001.962] E> cam_eeprom_read: Can't get gpio driver
[0001.967] I> Eeprom read failed 0x4d4d000d
[0001.971] I> Reading eeprom i2c=2 address=0x57
[0001.975] I> Enabling gpio chip_id = 2, gpio pin = 9
[0001.980] C> GPIO driver for chip_id 0x2 could not be found
[0001.985] E> cam_eeprom_read: Can't get gpio driver
[0001.990] I> Eeprom read failed 0x4d4d000d
[0001.994] I> create_pm_ids: id: 3310-1000-D00-F, len: 15
[0001.999] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.034] I> enabling 'vdd-hdmi' regulator
[0002.049] I> regulator 'vdd-hdmi' already enabled
[0002.054] I> hdmi cable connected
[0002.062] I> setting 'vdd-pex-1v00' regulator to 1000000 micro volts
[0002.074] I> setting 'vdd-1v8' regulator to 1800000 micro volts
[0002.083] E> cannot find any other nvdisp nodes
[0002.104] I> edid read success
[0002.119] I> edid read success
[0002.122] I> width = 640, height = 480, frequency = 25174825
[0002.128] I> width = 640, height = 480, frequency = 25174825
[0002.133] I> width = 640, height = 480, frequency = 25174825
[0002.139] I> width = 640, height = 480, frequency = 25174825
[0002.144] I> width = 1920, height = 1080, frequency = 148500000
[0002.150] I> width = 1366, height = 768, frequency = 85500000
[0002.155] I> width = 1920, height = 540, frequency = 74250000
[0002.161] I> width = 1920, height = 1080, frequency = 148351648
[0002.167] I> width = 1920, height = 1080, frequency = 148351648
[0002.172] I> width = 1280, height = 720, frequency = 74175824
[0002.178] I> width = 1280, height = 720, frequency = 74175824
[0002.183] I> width = 720, height = 480, frequency = 26973026
[0002.189] I> width = 720, height = 576, frequency = 26973026
[0002.194] I> width = 1920, height = 1080, frequency = 74175824
[0002.200] I> width = 1920, height = 1080, frequency = 74175824
[0002.206] I> width = 1920, height = 1080, frequency = 74175824
[0002.211] I> Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.221] I> hdmi_enable, starting HDMI initialisation
[0002.229] I> hdmi_enable, HDMI initialisation complete
[0002.242] initializing target
[0002.245] calling apps_init()
[0002.248] starting app kernel_boot_app
[0002.271] I> found decompressor handler: lz4-legacy
[0002.276] I> decompressing BMP blob ...
[0002.286] I> Kernel type = Normal
[0002.289] I> Loading partition kernel-bootctrl at 0xa8000000 from device(0x1)
[0002.303] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0002.310] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0002.317] I> ########## Fixed storage boot ##########
[0002.322] I> Loading kernel from partition ...
[0002.326] W> No valid slot number is found in scratch register
[0002.332] W> Return default slot: _a
[0002.335] I> A/B: bin_type (24) slot 0
[0002.351] I> Boot image size read from image header: f2f08
[0002.356] I> Boot image load address: 0x0x80400000
[0002.361] I> Loading partition kernel at 0x80400000 from device(0x1)
[0003.303] I> Validate kernel ...
[0003.306] I> T18x: Authenticate kernel (bin_type 24), max size 0x4000000
[0003.314] I> kernel-dtb is already loaded
[0003.317] I> Validate kernel-dtb ...
[0003.321] I> T18x: Authenticate kernel-dtb (bin_type 21), max size 0x100000
[0003.328] I> Checking boot.img header magic ... [0003.333] I> [OK]
[0003.334] I> Kernel hdr @0x80400000
[0003.338] I> Kernel dtb @0x80000000
[0003.341] I> decompressor handler not found
[0003.345] I> Copying kernel image (477882 bytes) from 0x80400800 to 0x80800000 ... [0003.353] I> Done
[0003.354] I> Move ramdisk (len: 0) from 0x80475800 to 0x94830000
[0003.362] I> Updated bpmp info to DTB
[0003.367] I> Ramdisk: Base: 0x94830000; Size: 0x0
[0003.372] I> Updated initrd info to DTB
[0003.376] W> WARN: Fail to override "console=none" in commandline
[0003.382] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0003.389] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0003.396] I> disabled_core_mask: 0xffffff0c
[0003.400] W> No valid slot number is found in scratch register
[0003.406] W> Return default slot: _a
[0003.409] I> Active slot suffix:
[0003.412] I> add_boot_slot_suffix: slot_suffix =
[0003.417] I> Linux Cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x2772e0000 gpt tegra_fbmem2=0x800000@0x9607d000 lut_mem2=0x2008@0x9607a000 usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2031647.1 bl_prof_dataptr=0x10000@0x275840000 sdhci_tegra.en_boot_part_access=1
[0003.458] I> Updated bootarg info to DTB
[0003.462] I> eeprom_get_mac_addr: MAC (type: 0): 00:04:4b:df:80:e2
[0003.468] I> eeprom_get_mac_addr: MAC (type: 1): 00:04:4b:df:80:e3
[0003.475] I> eeprom_get_mac_addr: MAC (type: 2): 00:04:4b:df:80:e4
[0003.481] E> Found no plugin manager ids in source DT
[0003.486] W> Add plugin manager ids from board info
[0003.490] E> "plugin-manager" doesn't exist, creating
[0003.495] E> "ids" doesn't exist, creating
[0003.499] E> "connection" doesn't exist, creating
[0003.504] E> "configs" doesn't exist, creating
[0003.508] I> create_pm_ids: id: 3310-1000-D00-F, len: 15
[0003.513] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0003.524] I> Adding plugin-manager/ids/3310-1000-D00=/i2c@c250000:module@0x50
[0003.532] E> "i2c@c250000" doesn't exist, creating
[0003.536] E> "module@0x50" doesn't exist, creating
[0003.543] I> Adding plugin-manager/ids/3310-1000-D00-F
[0003.550] I> Adding plugin-manager/configs/3310-mem-type 00
[0003.556] I> Adding plugin-manager/configs/3310-power-config 00
[0003.562] I> Adding plugin-manager/configs/3310-misc-config 00
[0003.568] I> Adding plugin-manager/configs/3310-modem-config 00
[0003.574] I> Adding plugin-manager/configs/3310-touch-config 00
[0003.579] I> Adding plugin-manager/configs/3310-display-config 00
[0003.586] I> Adding plugin-manager/cvm
[0003.590] E> "chip-id" doesn't exist, creating
[0003.594] I> Adding plugin-manager/chip-id/A02P
[0003.598] E> "odm-data" doesn't exist, creating
[0003.603] I> Adding /chosen/plugin-manager/odm-data
[0003.613] I> added [base:0x80000000, size:0x70000000] to /memory
[0003.619] I> added [base:0xf0200000, size:0x185600000] to /memory
[0003.624] I> added [base:0x275e00000, size:0x200000] to /memory
[0003.630] I> added [base:0x276600000, size:0x200000] to /memory
[0003.636] I> added [base:0x277000000, size:0x200000] to /memory
[0003.642] I> Updated memory info to DTB
[0003.646] E> add_disp_param: failed to get display params for du=1
[0003.654] E> "reset" doesn't exist, creating
[0003.658] E> "pmc-reset-reason" doesn't exist, creating
[0003.664] E> "pmic-reset-reason" doesn't exist, creating
[0003.670] I> Adding ecid(00000001645cf3090000000001ff0480) to DT
[0003.676] I> disabled_core_mask: 0xffffff0c
[0003.689] I> Add serial number:1422719049922 as DT property
[0003.698] I> Plugin-manager override starting
[0003.703] I> node /plugin-manager/fragement@0 matches
[0003.714] I> node /plugin-manager/fragement@4 matches
[0003.726] I> node /plugin-manager/fragment-sdwake-p3310-1000-300 matches
[0003.746] I> node /plugin-manager/fragement-pmon-p3310-1000-300 matches
[0003.755] I> node /plugin-manager/fragement-pmon-p3310-1000-800 matches
[0003.764] I> node /plugin-manager/fragment-devslp@0 matches
[0003.777] I> node /plugin-manager/fragment-500-pcie-config matches
[0003.791] I> node /plugin-manager/fragment-500-xusb-config matches
[0003.815] I> node /plugin-manager/fragment-p3310-c00-comm matches
[0003.828] I> node /plugin-manager/fragment-p3310-c00-pmic matches
[0003.839] I> node /plugin-manager/fragment-p3310-c01 matches
[0003.852] I> node /plugin-manager/fragment-p3310-c03 matches
[0003.890] I> node /plugin-manager/fragment-p3310-c00-camera matches
[0003.916] I> Disable plugin-manager status in FDT
[0003.921] I> Plugin-manager override finished successfully
[0003.926] I> tegrabl_load_kernel_and_dtb: Done
[0003.969] I> Kernel EP: 0x80800000, DTB: 0x80000000
U-Boot 2016.07-g0536cf2a27 (Dec 09 2019 - 22:43:10 -0800)
TEGRA186
Model: NVIDIA P2771-0000-500
DRAM: 7.8 GiB
MC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: eth0: ethernet@2490000
Hit any key to stop autoboot: 0
MMC: no card present
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
1161 bytes read in 119 ms (8.8 KiB/s)
1: primary kernel
Retrieving file: /boot/initrd
5565140 bytes read in 228 ms (23.3 MiB/s)
Retrieving file: /boot/Image
34191368 bytes read in 853 ms (38.2 MiB/s)
append: root=/dev/nvme0n1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x2772e0000 gpt tegra_fbmem2=0x800000@0x9607d000 lut_mem2=0x2008@0x9607a000 usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2031647.1 bl_prof_dataptr=0x10000@0x275840000 sdhci_tegra.en_boot_part_access=1
## Flattened Device Tree blob at 80000000
Booting using the fdt blob at 0x80000000
reserving fdt memory region: addr=80000000 size=10000
Using Device Tree in place at 0000000080000000, end 000000008005f9bd
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-1935) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Mon Dec 9 22:52:02 PST 2019
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 16416,
[ 0.000000] OF: fdt: - 80000000 , 70000000
[ 0.000000] OF: fdt: - f0200000 , 185600000
[ 0.000000] OF: fdt: - 275e00000 , 200000
[ 0.000000] OF: fdt: - 276600000 , 200000
[ 0.000000] OF: fdt: - 277000000 , 200000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000003100000 (options '')
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] Found tegra_fbmem2: 00800000@9607d000
[ 0.000000] Found lut_mem2: 00002008@9607a000
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc1f676a000 s61592 r8192 d32616 u102400
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2020917
[ 0.000000] Kernel command line: root=/dev/nvme0n1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x2772e0000 gpt tegra_fbmem2=0x800000@0x9607d000 lut_mem2=0x2008@0x9607a000 usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2031647.1 bl_prof_dataptr=0x10000@0x275840000 sdhci_tegra.en_boot_part_access=1
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29520(90%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7960808K/8212468K available (15230K kernel code, 2926K rwdata, 6620K rodata, 8576K init, 609K bss, 186124K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f60000 ( 15232 KB)
[ 0.000000] .rodata : 0xffffff8008f60000 - 0xffffff80095e0000 ( 6656 KB)
[ 0.000000] .init : 0xffffff80095e0000 - 0xffffff8009e40000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e40000 - 0xffffff800a11b808 ( 2927 KB)
[ 0.000000] .bss : 0xffffff800a11b808 - 0xffffff800a1b3dbc ( 610 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf07dc8000 ( 125 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc1f7200000 ( 8050 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.009974] Console: colour dummy device 80x25
[ 0.014638] console [tty0] enabled
[ 0.018195] bootconsole [uart8250] disabled
<hit enter to activate fiq debugger>
[ 0.022571] kmemleak: Kernel memory leak detector disabled
[ 0.022589] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.022603] pid_max: default: 32768 minimum: 301
[ 0.022919] Security Framework initialized
[ 0.023080] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.023090] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.023687] ftrace: allocating 47001 entries in 184 pages
[ 0.146950] sched-energy: Sched-energy-costs installed from DT
[ 0.146970] ASID allocator initialised with 65536 entries
[ 0.184578] tegra-id: chipid=21817.
[ 0.184594] tegra-id: opt_subrevision=1.
[ 0.184615] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[ 0.184629] DTS File Name: /home/auvidea/Downloads/l4t_rev_32_3_1/TX2/Linux_for_Tegra/source/public/kernel_src/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.184649] DTB Build time: Feb 24 2020 16:47:32
[ 0.234028] CPU1: Booted secondary processor [4e0f0030]
[ 0.265659] CPU2: Booted secondary processor [4e0f0030]
[ 0.297453] CPU3: Booted secondary processor [411fd073]
[ 0.329444] CPU4: Booted secondary processor [411fd073]
[ 0.361428] CPU5: Booted secondary processor [411fd073]
[ 0.361481] Brought up 6 CPUs
[ 0.361527] SMP: Total of 6 processors activated.
[ 0.361540] CPU features: detected feature: 32-bit EL0 Support
[ 0.362394] CPU: All CPU(s) started at EL2
[ 0.362456] alternatives: patching kernel code
[ 0.371841] devtmpfs: initialized
[ 0.410557] Initilizing CustomIPI irq domain
[ 0.410771] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.410797] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.411601] pinctrl core: initialized pinctrl subsystem
[ 0.411819] OS set in device tree is not L4T.
[ 0.411992] regulator-dummy: no parameters
[ 0.412141] Initializing plugin-manager
[ 0.412204] Plugin module not found
[ 0.412248] Plugin-manager status disabled
[ 0.414131] NET: Registered protocol family 16
[ 0.414827] pstore: using zlib compression
[ 0.415214] console [pstore-1] enabled
[ 0.415226] pstore: Registered ramoops as persistent store backend
[ 0.415240] ramoops: attached 0x200000@0x275880000, ecc: 0/0
[ 0.429059] cpuidle: using governor menu
[ 0.430601] bpmp: waiting for handshake
[ 0.430620] bpmp: handshake completed
[ 0.430643] bpmp: synchronizing channels
[ 0.430659] bpmp: channels synchronized
[ 0.430670] bpmp: mail init ok
[ 0.432802] arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.432822] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.432836] arm-smmu 12000000.iommu: stage 1 translation
[ 0.432849] arm-smmu 12000000.iommu: stage 2 translation
[ 0.432861] arm-smmu 12000000.iommu: nested translation
[ 0.432876] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.432895] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.432914] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.432929] arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.432942] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.435087] vdso: 2 pages (1 code @ ffffff8008f67000, 1 data @ ffffff8009e44000)
[ 0.435118] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.437257] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.439223] Registering BPMP clocks...
[ 0.439332] tegra_bpmp_clk_init: clock init ok (638 clks)
[ 0.441640] tegra_powergate_init: DONE
[ 0.441664] DTS File Name: /home/auvidea/Downloads/l4t_rev_32_3_1/TX2/Linux_for_Tegra/source/public/kernel_src/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.441699] DTB Build time: Feb 24 2020 16:47:32
[ 0.443837] Tegra reboot handler registered.
[ 0.445396] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.445506] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.445532] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[ 0.445545] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L1
[ 0.445557] tegra-pmc: ### PMC reset status reg: 0x2d
[ 0.445728] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.445754] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.446090] iommu: Adding device 3460000.sdhci to group 0
[ 0.446788] iommu: Adding device 3400000.sdhci to group 1
[ 0.447850] iommu: Adding device 3507000.ahci-sata to group 2
[ 0.447876] arm-smmu: forcing sodev map for 3507000.ahci-sata
[ 0.448326] iommu: Adding device 3160000.i2c to group 3
[ 0.448781] iommu: Adding device c240000.i2c to group 4
[ 0.449138] iommu: Adding device 3180000.i2c to group 5
[ 0.449508] iommu: Adding device 3190000.i2c to group 6
[ 0.449953] iommu: Adding device 31b0000.i2c to group 7
[ 0.450296] iommu: Adding device 31c0000.i2c to group 8
[ 0.450643] iommu: Adding device c250000.i2c to group 9
[ 0.450987] iommu: Adding device 31e0000.i2c to group 10
[ 0.452496] iommu: Adding device 3210000.spi to group 11
[ 0.452845] iommu: Adding device c260000.spi to group 12
[ 0.453184] iommu: Adding device 3230000.spi to group 13
[ 0.453551] iommu: Adding device 3240000.spi to group 14
[ 0.454251] iommu: Adding device 3100000.serial to group 15
[ 0.454603] iommu: Adding device 3110000.serial to group 16
[ 0.454943] iommu: Adding device c280000.serial to group 17
[ 0.455280] iommu: Adding device 3130000.serial to group 18
[ 0.456634] iommu: Adding device 2490000.ether_qos to group 19
[ 0.456657] arm-smmu: forcing sodev map for 2490000.ether_qos
[ 0.457355] iommu: Adding device b000000.rtcpu to group 20
[ 0.459574] iommu: Adding device 13e10000.host1x to group 21
[ 0.459897] iommu: Adding device 13e10000.host1x:ctx0 to group 22
[ 0.460209] iommu: Adding device 13e10000.host1x:ctx1 to group 23
[ 0.460535] iommu: Adding device 13e10000.host1x:ctx2 to group 24
[ 0.460850] iommu: Adding device 13e10000.host1x:ctx3 to group 25
[ 0.461167] iommu: Adding device 13e10000.host1x:ctx4 to group 26
[ 0.461514] iommu: Adding device 13e10000.host1x:ctx5 to group 27
[ 0.461836] iommu: Adding device 13e10000.host1x:ctx6 to group 28
[ 0.462150] iommu: Adding device 13e10000.host1x:ctx7 to group 29
[ 0.462618] iommu: Adding device 150c0000.nvcsi to group 30
[ 0.463267] iommu: Adding device 15700000.vi to group 31
[ 0.463632] iommu: Adding device 15600000.isp to group 32
[ 0.464094] iommu: Adding device 15210000.nvdisplay to group 33
[ 0.464212] platform 15210000.nvdisplay: OF IOVA linear map 0x9607d000 size (0x800000)
[ 0.464269] platform 15210000.nvdisplay: OF IOVA linear map 0x9607a000 size (0x2008)
[ 0.464790] iommu: Adding device 15340000.vic to group 34
[ 0.465023] iommu: Adding device 154c0000.nvenc to group 35
[ 0.465251] iommu: Adding device 15480000.nvdec to group 36
[ 0.465640] iommu: Adding device 15380000.nvjpg to group 37
[ 0.465869] iommu: Adding device 15500000.tsec to group 38
[ 0.466091] iommu: Adding device 15100000.tsecb to group 39
[ 0.466769] iommu: Adding device 15810000.se to group 40
[ 0.466998] iommu: Adding device 15820000.se to group 41
[ 0.467223] iommu: Adding device 15830000.se to group 42
[ 0.467445] iommu: Adding device 15840000.se to group 43
[ 0.468345] iommu: Adding device smmu_test to group 44
[ 0.468945] mc: mapped MMIO address: 0xffffff800a690000 -> 0x2c10000
[ 0.468970] mc: mapped MMIO address: 0xffffff800a6b0000 -> 0x2c20000
[ 0.468990] mc: mapped MMIO address: 0xffffff800a6d0000 -> 0x2c30000
[ 0.469011] mc: mapped MMIO address: 0xffffff800a7b0000 -> 0x2c40000
[ 0.469030] mc: mapped MMIO address: 0xffffff800a7d0000 -> 0x2c50000
[ 0.469047] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.469067] mc-err: mcerr ops are set to t18x
[ 0.469228] dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
[ 0.470358] iommu: Adding device 3530000.xhci to group 45
[ 0.470383] arm-smmu: forcing sodev map for 3530000.xhci
[ 0.470829] iommu: Adding device 3550000.xudc to group 46
[ 0.470858] arm-smmu: forcing sodev map for 3550000.xudc
[ 0.471583] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.471602] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 0.472185] iommu: Adding device 17000000.gp10b to group 47
[ 0.473230] tegra-reset 5000000.clock: registered 193 resets.
[ 0.475445] iommu: Adding device d000000.bpmp to group 48
[ 0.475667] bpmp: ping status is 0
[ 0.475766] bpmp d000000.bpmp: firmware tag is 4208eb5c85fe47a2235fbc0b8eb87dca
[ 0.478198] bpmp d000000.bpmp: probe ok
[ 0.481327] iommu: Adding device 2600000.dma to group 49
[ 0.482623] GPIO line 461 (camera-control-output-low) hogged as output/low
[ 0.482665] GPIO line 456 (camera-control-output-low) hogged as output/low
[ 0.482701] GPIO line 457 (camera-control-output-low) hogged as output/low
[ 0.482735] GPIO line 426 (camera-control-output-low) hogged as output/low
[ 0.482770] GPIO line 424 (wifi-enable) hogged as output/high
[ 0.482804] GPIO line 445 (sdmmc-wake-support-input) hogged as input
[ 0.482839] GPIO line 446 (sdmmc-wake-support-output) hogged as output/low
[ 0.483042] gpiochip_setup_dev: registered GPIOs 320 to 511 on device: gpiochip0 (tegra-gpio)
[ 0.486799] GPIO line 315 (wifi-wake-ap) hogged as input
[ 0.486982] gpiochip_setup_dev: registered GPIOs 256 to 319 on device: gpiochip1 (tegra-gpio-aon)
[ 0.488584] iommu: Adding device 10003000.pcie-controller to group 50
[ 0.488612] arm-smmu: forcing sodev map for 10003000.pcie-controller
[ 0.488947] iommu: Adding device sound to group 51
[ 0.489319] iommu: Adding device 3510000.hda to group 52
[ 0.498279] iommu: Adding device c1a0000.aon to group 53
[ 0.499528] vdd-ac-bat: 5000 mV
[ 0.503155] vdd-1v8-ap: 1800 mV
[ 0.521671] random: fast init done
[ 0.538965] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.545011] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.545586] SCSI subsystem initialized
[ 0.546235] usbcore: registered new interface driver usbfs
[ 0.546326] usbcore: registered new interface driver hub
[ 0.546476] usbcore: registered new device driver usb
[ 0.550877] GPIO line 241 (touch-rails) hogged as output/high
[ 0.551417] GPIO line 242 (touch-rails) hogged as output/high
[ 0.551833] gpiochip_setup_dev: registered GPIOs 240 to 255 on device: gpiochip2 (tca9539)
[ 0.552358] tegra-i2c 3160000.i2c: no acknowledge from address 0x77
[ 0.552456] pca953x 0-0077: failed reading register
[ 0.552558] pca953x: probe of 0-0077 failed with error -121
[ 0.565650] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 0.570231] vddio-ddr: at 1125 mV
[ 0.574076] avdd_dsi_csi: 1200 mV
[ 0.577464] vdd-1v8: 1800 mV
[ 0.581458] vdd-3v3-sys: 3300 mV
[ 0.582313] spmic-ldo0: at 1800 mV
[ 0.583012] spmic-ldo1: at 800 mV
[ 0.585465] vddio-3v3: 3300 mV
[ 0.586224] vddio-sdmmc1: 1800 <--> 3300 mV at 3300 mV
[ 0.589464] vdd-rtc: at 800 mV
[ 0.590082] avdd-ts-hv: 1800 <--> 3300 mV at 1800 mV
[ 0.593459] spmic-ldo6: at 1500 mV
[ 0.597781] vdd-pex-1v00: 1000 mV
[ 0.598608] dvdd-pex: 1000 mV
[ 0.601523] GPIO line 237 (spmic_gpio_input) hogged as input
[ 0.601740] GPIO line 238 (spmic_gpio_input) hogged as input
[ 0.602028] gpiochip_setup_dev: registered GPIOs 232 to 239 on device: gpiochip3 (max77620-gpio)
[ 0.602335] max77620 4-003c: max77620 probe successful
[ 0.602883] media: Linux media interface: v0.10
[ 0.602967] Linux video capture interface: v2.00
[ 0.606540] pps_core: LinuxPPS API ver. 1 registered
[ 0.606589] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.606663] PTP clock support registered
[ 0.607437] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.607505] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.612004] tegra_fiq_debugger_init: found FIQ source (IRQ 387)
[ 0.617644] trusty trusty: trusty version: Built: 22:43:54 Dec 9 2019
[ 0.617772] trusty trusty: selected api version: 3 (requested 3)
[ 0.618941] Advanced Linux Sound Architecture Driver Initialized.
[ 0.619539] Bluetooth: Core ver 2.22
[ 0.619617] NET: Registered protocol family 31
[ 0.619656] Bluetooth: HCI device and connection manager initialized
[ 0.619703] Bluetooth: HCI socket layer initialized
[ 0.619747] Bluetooth: L2CAP socket layer initialized
[ 0.619823] Bluetooth: SCO socket layer initialized
[ 0.620847] en-vdd-sd: 3300 mV
[ 0.625493] vdd-hdmi: 5000 mV
[ 0.625999] vdd-usb0-5v: 5000 mV
[ 0.626471] vdd-usb1-5v: 5000 mV
[ 0.630059] en-vdd-ts-1v8: 1800 mV
[ 0.634150] en-vdd-ts-hv-3v3: 3300 mV
[ 0.634989] en-vdd-disp-3v3: 3300 mV
[ 0.635868] en-mdm-pwr-3v7: 3700 mV
[ 0.636708] en-vdd-disp-1v8: 1800 mV
[ 0.637524] en-vdd-cam-hv-2v8: 2800 mV
[ 0.638442] vdd-fan: 5000 mV
[ 0.638889] vdd-3v3: 3300 mV
[ 0.640065] dis-vdd-1v2: 1200 mV
[ 0.640474] en-vdd-vcm-2v8: 2800 mV
[ 0.641332] vdd-usb2-5v: 5000 mV
[ 0.641720] vdd-sys-bl: 3300 mV
[ 0.645282] camchar: rtcpu character device driver loaded
[ 0.646011] gpio tegra-gpio wake53 for gpio=159(X:7)
[ 0.648198] extcon-gpio-states external-connection:extcon@1: Cable state:1, cable id:2
[ 0.649749] clocksource: Switched to clocksource arch_sys_counter
[ 0.690465] VFS: Disk quotas dquot_6.6.0
[ 0.690723] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.691389] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.692343] nvmap: nvmap_select_cache_ops() nvmap cache ops set to roc
[ 0.692385] nvmap_page_pool_init: Total RAM pages: 2006586
[ 0.692417] nvmap_page_pool_init: nvmap page pool size: 250823 pages (979 MB)
[ 0.692632] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.696433] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 0.707858] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 0.708092] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 0.708571] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.708701] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.708882] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[ 0.709043] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 0.709285] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type PMIC-Die
[ 0.709581] la/ptsa driver initialized.
[ 0.709612] pre_t19x_iso_plat_init(): iso emc max clk=1866000KHz
[ 0.709636] pre_t19x_iso_plat_init(): max_iso_bw=26870400KB
[ 0.710849] NET: Registered protocol family 2
[ 0.712876] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.713566] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.714467] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.714574] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.714805] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.715688] NET: Registered protocol family 1
[ 0.716791] RPC: Registered named UNIX socket transport module.
[ 0.716823] RPC: Registered udp transport module.
[ 0.716846] RPC: Registered tcp transport module.
[ 0.716867] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.717121] Trying to unpack rootfs image as initramfs...
[ 0.908038] Freeing initrd memory: 5432K
[ 0.930506] host1x 13e10000.host1x: initialized
[ 0.932009] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.937011] audit: initializing netlink subsys (disabled)
[ 0.937080] audit: type=2000 audit(0.820:1): initialized
[ 0.938042] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 0.950941] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.953629] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.955278] 9p: Installing v9fs 9p2000 file system support
[ 0.962053] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.962266] io scheduler noop registered
[ 0.962922] io scheduler cfq registered (default)
[ 0.967855] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 1.091595] iommu: Adding device aconnect@2a41000:adsp_audio to group 54
[ 1.132493] iommu: Adding device 2993000.adsp to group 55
[ 1.133694] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 1.136732] tegra-xusb-padctl 3520000.xusb_padctl: VBUS over-current detection enabled
[ 1.140157] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 1.141374] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 1.142825] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 1.144284] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.147460] tegra-pcie 10003000.pcie-controller: wrong configuration updated in DT, switching to default 2x1, 1x1, 1x1 configuration
[ 1.148625] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[ 1.149086] tegra-pcie 10003000.pcie-controller: probing port 0, using 2 lanes
[ 1.149497] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.149708] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 1.149809] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=2000000, max_bw=4687500
[ 1.152942] tegra-pcie 10003000.pcie-controller: probing port 1, using 1 lanes
[ 1.154669] tsec 15500000.tsec: initialized
[ 1.156338] tsec 15100000.tsecb: initialized
[ 1.160861] nvdec 15480000.nvdec: initialized
[ 1.168864] falcon 15340000.vic: initialized
[ 1.170494] falcon 154c0000.nvenc: initialized
[ 1.171981] falcon 15380000.nvjpg: initialized
[ 1.175973] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.177698] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.179425] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.181063] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.182810] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.184458] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.186141] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.187921] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.191975] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.192021] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.192082] tegradccommon 15200000.dc_common: dma mapping done
[ 1.193147] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=391
[ 1.193235] tegradc 15210000.nvdisplay: disp0 connected to head1->/host1x/sor1
[ 1.193301] tegra_cec 3960000.tegra_cec: Unpowergate DISP: 0.
[ 1.193303] generic_infoframe_type: 0x87
[ 1.193420] tegradc 15210000.nvdisplay: DT parsed successfully
[ 1.193454] tegradc 15210000.nvdisplay: Display dc.ffffff800b690000 registered with id=0
[ 1.193636] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[ 1.193690] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[ 1.194073] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[ 1.194102] tegra_cec 3960000.tegra_cec: probed
[ 1.199002] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[ 1.199028] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[ 1.199046] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[ 1.199235] tegradc 15210000.nvdisplay: vblank syncpt # 8 for dc 1
[ 1.199255] tegradc 15210000.nvdisplay: vpulse3 syncpt # 9 for dc 1
[ 1.200867] tegradc 15210000.nvdisplay: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
[ 1.207189] tegradc 15210000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 1.207238] tegradc 15210000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 1.210713] tegradc 15210000.nvdisplay: probed
[ 1.214069] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 32 channels
[ 1.215027] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.215599] kfuse 3830000.kfuse: initialized
[ 1.217286] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.222361] Console: switching to colour frame buffer device 240x67
[ 1.222538] tegradc 15210000.nvdisplay: fb registered
[ 1.222664] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.222899] gpio tegra-gpio wake21 for gpio=121(P:1)
[ 1.223358] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 1.223435] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 1.223500] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 1.231697] Parent Clock set for DC plld2
[ 1.232322] console [ttyS0] disabled
[ 1.232405] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 37, base_baud = 25500000) is a Tegra
[ 1.299021] tegradc 15210000.nvdisplay: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_111m_223m
[ 1.299512] tegradc 15210000.nvdisplay: hdmi: get RGB quant from REG programmed by BL.
[ 1.299521] tegradc 15210000.nvdisplay: hdmi: get YCC quant from REG programmed by BL.
[ 1.325639] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 1.325642] Extcon AUX1(HDMI) enable
[ 1.693848] tegra-pcie 10003000.pcie-controller: link 1 down, retrying
[ 2.101667] tegra-pcie 10003000.pcie-controller: link 1 down, retrying
[ 2.229785] tegra_cec 3960000.tegra_cec: physical address: 10:00.
[ 2.294305] tegra_cec 3960000.tegra_cec: Sent <Text View On> res: 0.
[ 2.411616] tegra_cec 3960000.tegra_cec: Broadcast <Active Source> res: 0.
[ 2.411622] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[ 2.508507] tegra-pcie 10003000.pcie-controller: link 1 down, retrying
[ 2.510544] tegra-pcie 10003000.pcie-controller: link 1 down, ignoring
[ 2.617900] tegra-pcie 10003000.pcie-controller: PCI host bridge to bus 0000:00
[ 2.617909] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 2.617915] pci_bus 0000:00: root bus resource [mem 0x40100000-0x47ffffff]
[ 2.617921] pci_bus 0000:00: root bus resource [mem 0x48000000-0x7fffffff pref]
[ 2.617927] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.618310] iommu: Adding device 0000:00:01.0 to group 56
[ 2.618321] arm-smmu: forcing sodev map for 0000:00:01.0
[ 2.618431] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.619278] iommu: Adding device 0000:01:00.0 to group 57
[ 2.619284] arm-smmu: forcing sodev map for 0000:01:00.0
[ 2.630048] pci 0000:00:01.0: BAR 14: assigned [mem 0x40100000-0x401fffff]
[ 2.630059] pci 0000:01:00.0: BAR 0: assigned [mem 0x40100000-0x40103fff 64bit]
[ 2.630093] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 2.630103] pci 0000:00:01.0: bridge window [mem 0x40100000-0x401fffff]
[ 2.630453] pcieport 0000:00:01.0: Signaling PME through PCIe PME interrupt
[ 2.630458] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 3.802748] console [ttyS0] enabled
[ 3.802756] tegradc 15210000.nvdisplay: blank - powerdown
[ 3.804784] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 3.805936] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 3.806156] serial-tegra 3130000.serial: RX in PIO mode
[ 3.807123] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 40, base_baud = 0) is a TEGRA_UART
[ 3.808211] [drm] Initialized
[ 3.818608] brd: module loaded
[ 3.823863] loop: module loaded
[ 3.823952] tegra_profiler: version: 1.139, samples/io: 47/27
[ 3.824092] tegra_profiler: auth: init
[ 3.824691] nct1008_nct72 7-004c: starting parse dt
[ 3.824830] nct1008_nct72 7-004c: !!!Found deprecated property!!!
[ 3.824840] nct1008_nct72 7-004c: success parsing dt
[ 3.824978] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 3.825180] THERMAL EST: found 3 subdevs
[ 3.825222] THERMAL EST num_resources: 0
[ 3.825262] [THERMAL EST subdev 0]
[ 3.825267] [THERMAL EST subdev 1]
[ 3.825271] [THERMAL EST subdev 2]
[ 3.825624] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 3.825627] THERMAL EST: thz register success.
[ 3.825849] THERMAL EST: end of probe, return err: 0
[ 3.826955] hisi_sas: driver version v1.6
[ 3.827783] nvme nvme0: pci function 0000:01:00.0
[ 3.827825] nvme 0000:01:00.0: enabling device (0000 -> 0002)
[ 3.831767] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 3.831778] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 3.832883] scsi host0: tegra_ahci
[ 3.833928] scsi host1: tegra_ahci
[ 3.834117] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 24
[ 3.834121] ata2: DUMMY
[ 3.840264] spi-tegra114 3240000.spi: chipselect 0 already in use
[ 3.840269] spi_master spi3: spi_device register error /spi@3240000/spi3_0
[ 3.840277] spi_master spi3: Failed to create SPI device for /spi@3240000/spi3_0
[ 3.842080] libphy: Fixed MDIO Bus: probed
[ 3.842718] tun: Universal TUN/TAP device driver, 1.6
[ 3.842721] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 3.843453] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 3.843457] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 3.843502] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 3.843504] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 3.843543] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 3.843546] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 3.843584] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 3.843587] Copyright(c) 1999 - 2017 Intel Corporation.
[ 3.849904] eqos 2490000.ether_qos: can't get pllrefe_vcoout clk (-2)
[ 3.851700] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 3.851702] Extcon AUX1(HDMI) disable
[ 3.853736] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b df 80 e4
[ 3.853898] libphy: dwc_phy: probed
[ 3.854317] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 3.856603] PPP generic driver version 2.4.2
[ 3.856781] PPP BSD Compression module registered
[ 3.856785] PPP Deflate Compression module registered
[ 3.856831] PPP MPPE Compression module registered
[ 3.856836] NET: Registered protocol family 24
[ 3.856887] usbcore: registered new interface driver r8152
[ 3.856924] usbcore: registered new interface driver asix
[ 3.856961] usbcore: registered new interface driver ax88179_178a
[ 3.856995] usbcore: registered new interface driver cdc_ether
[ 3.857034] usbcore: registered new interface driver net1080
[ 3.857063] usbcore: registered new interface driver cdc_subset
[ 3.857099] usbcore: registered new interface driver zaurus
[ 3.857147] usbcore: registered new interface driver cdc_ncm
[ 3.857336] VFIO - User Level meta-driver version: 0.3
[ 3.857645] nct1008_nct72 7-004c: LOC shutdown limit 107
[ 3.858160] nct1008_nct72 7-004c: EXT shutdown limit 107
[ 3.859229] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.859247] ehci-pci: EHCI PCI platform driver
[ 3.859282] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 3.859291] ohci-pci: OHCI PCI platform driver
[ 3.859324] ohci-platform: OHCI generic platform driver
[ 3.865383] tegra-xusb 3530000.xhci: USB2 port 0 has OTG_CAP
[ 3.867825] tegra-xusb 3530000.xhci: extcon 0: ffffffc1ead91400 id
[ 3.868655] usbcore: registered new interface driver uas
[ 3.868700] usbcore: registered new interface driver usb-storage
[ 3.868791] usbcore: registered new interface driver usbserial
[ 3.869798] tegra-xusb 3530000.xhci: Firmware timestamp: 2019-07-08 19:32:42 UTC, Version: 55.15 release
[ 3.873514] tegra-xudc-new 3550000.xudc: device count: 1
[ 3.876773] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[ 3.877081] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 3.877652] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 3.878210] tegra-xudc-new 3550000.xudc: vbus state: 0
[ 3.878242] tegra-xudc-new 3550000.xudc: entering ELPG
[ 3.880011] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 3.880513] mousedev: PS/2 mouse device common for all mice
[ 3.880587] usbcore: registered new interface driver xpad
[ 3.886372] tegradc 15210000.nvdisplay: unblank
[ 3.887089] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 3.887195] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 3.887289] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 3.889914] nct1008_nct72 7-004c: initial LOC temp: 47000
[ 3.890222] nct1008_nct72 7-004c: initial EXT temp: 49500
[ 3.890834] nct1008_nct72 7-004c: hi_b:-11, lo_b:0
[ 3.891183] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
[ 3.891370] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 3.893018] Parent Clock set for DC plld2
[ 3.896485] tegradc 15210000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 3.897726] tegradc 15210000.nvdisplay: hdmi: get RGB quant from EDID.
[ 3.897751] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[ 3.925794] tegra-xusb 3530000.xhci: xHCI Host Controller
[ 3.925828] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 1
[ 3.926672] tegra-xusb 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00050810
[ 3.926715] tegra-xusb 3530000.xhci: irq 71, io mem 0x03530000
[ 3.926968] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.926974] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.926979] usb usb1: Product: xHCI Host Controller
[ 3.926983] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 3.926988] usb usb1: SerialNumber: 3530000.xhci
[ 3.927482] hub 1-0:1.0: USB hub found
[ 3.927530] hub 1-0:1.0: 4 ports detected
[ 3.927938] tegra-xusb 3530000.xhci: xHCI Host Controller
[ 3.927949] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 2
[ 3.928166] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 3.928173] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.928177] usb usb2: Product: xHCI Host Controller
[ 3.928181] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 3.928185] usb usb2: SerialNumber: 3530000.xhci
[ 3.928607] hub 2-0:1.0: USB hub found
[ 3.928645] hub 2-0:1.0: 3 ports detected
[ 3.933119] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 3.933121] Extcon AUX1(HDMI) enable
[ 4.010808] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 4.012307] Wake73 for irq=42
[ 4.013579] rtc rtc1: alarm rtc device
[ 4.013593] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 4.013625] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 4.013887] i2c /dev entries driver
[ 4.016148] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 4.022267] parse_throttle_dt_data: Num cap clks = 4
[ 4.022273] parse_throttle_dt_data: clk=mcpu type=1
[ 4.022277] parse_throttle_dt_data: clk=bcpu type=2
[ 4.022286] parse_throttle_dt_data: clk=gpu type=4
[ 4.022289] parse_throttle_dt_data: clk=emc type=3
[ 4.023420] tegra_throttle_probe: probe successful. #cdevs=4
[ 4.023923] FAN dev name: pwm-fan
[ 4.023986] FAN:gpio request success.
[ 4.023995] FAN: can't find tach_gpio
[ 4.024028] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 4.024234] pwm_fan_driver pwm-fan: got pwm for fan. polarity is inversed
[ 4.024240] pwm_fan_driver pwm-fan: tach period: 1000
[ 4.024628] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 4.024634] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 4.024639] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 4.024644] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 4.024648] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 4.024652] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 4.024656] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 4.024660] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 4.024666] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 4.024671] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 4.026312] device-mapper: uevent: version 1.0.3
[ 4.027204] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 4.027529] CPU EMC frequency mapping table: default setting
[ 4.031972] cpufreq: platform driver Initialization: pass
[ 4.032713] cpuidle: Initializing cpuidle driver init for Denver cluster
[ 4.032825] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 4.033653] sdhci: Secure Digital Host Controller Interface driver
[ 4.033655] sdhci: Copyright(c) Pierre Ossman
[ 4.033657] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.035228] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 4.037158] CMDQ: cmdq_platfm_init successful
[ 4.038342] CQE: CMD_TIMING bit set for R1B DCMD
[ 4.041132] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 4.045935] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 4.045982] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 4.046964] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 4.048833] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 258
[ 4.054113] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 4.055228] tegra-se-nvhost 15810000.se: initialized
[ 4.056199] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 4.057096] tegra-se-nvhost 15820000.se: initialized
[ 4.058048] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 4.058954] tegra-se-nvhost 15830000.se: initialized
[ 4.059466] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 4.060334] tegra-se-nvhost 15840000.se: initialized
[ 4.061151] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 4.061421] hidraw: raw HID events driver (C) Jiri Kosina
[ 4.062775] usbcore: registered new interface driver usbhid
[ 4.062777] usbhid: USB HID core driver
[ 4.065239] tegra-i2c 3160000.i2c: no acknowledge from address 0x42
[ 4.065274] ina3221x 0-0042: ina3221 reset failure status: 0xffffff87
[ 4.065455] ina3221x: probe of 0-0042 failed with error -121
[ 4.065701] tegra-i2c 3160000.i2c: no acknowledge from address 0x43
[ 4.065728] ina3221x 0-0043: ina3221 reset failure status: 0xffffff87
[ 4.065821] ina3221x: probe of 0-0043 failed with error -121
[ 4.068401] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 4.071450] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xbfef0000-0xbfefdb7f size=56192
[ 4.071871] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 4.072128] tegra-ivc ivc-b000000.rtcpu:i2c@480: i2c: ver=0 grp=1 RX[8x128]=0x1900-0x1d80 TX[8x128]=0x1d80-0x2200
[ 4.072576] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x2200-0x4280 TX[64x128]=0x4280-0x6300
[ 4.073792] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x6300-0x63c0 TX[1x64]=0x63c0-0x6480
[ 4.073882] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x6480-0x7900 TX[16x320]=0x7900-0x8d80
[ 4.073957] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8d80-0x9200 TX[16x64]=0x9200-0x9680
[ 4.074031] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x9680-0x9880 TX[1x384]=0x9880-0x9a80
[ 4.074166] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x8192]=0x9a80-0xbb00 TX[1x8192]=0xbb00-0xdb80
[ 4.074648] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (52)
[ 4.074652] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 4.075653] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=5 sha1=3ecb1dca25fa98771f988f238c025334776c9a96
[ 4.077279] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 4.077717] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 4.078087] register_ari_mca_banks: Registered MCA ROC:IOB
[ 4.078170] register_ari_mca_banks: Registered MCA ROC:CCE
[ 4.078918] tegra18-bridge 2390000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.078922] tegra18-bridge 2390000.axi2apb: enabled timeout = 11155000
[ 4.078925] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 4.078991] tegra18-bridge 23a0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.079017] tegra18-bridge 23a0000.axi2apb: enabled timeout = 11155000
[ 4.079020] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 4.079079] tegra18-bridge 23b0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.079082] tegra18-bridge 23b0000.axi2apb: enabled timeout = 11155000
[ 4.079085] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 4.079141] tegra18-bridge 23c0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.079144] tegra18-bridge 23c0000.axi2apb: enabled timeout = 11155000
[ 4.079147] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 4.079203] tegra18-bridge 23d0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.079206] tegra18-bridge 23d0000.axi2apb: enabled timeout = 11155000
[ 4.079208] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 4.079266] tegra18-bridge 2100000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.079272] tegra18-bridge 2100000.axip2p: enabled timeout = 11155000
[ 4.079274] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 4.079342] tegra18-bridge 2110000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.079348] tegra18-bridge 2110000.axip2p: enabled timeout = 11155000
[ 4.079350] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 4.079421] tegra18-bridge 2120000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.079426] tegra18-bridge 2120000.axip2p: enabled timeout = 11155000
[ 4.079429] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 4.079486] tegra18-bridge 2130000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.079492] tegra18-bridge 2130000.axip2p: enabled timeout = 11155000
[ 4.079495] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 4.079552] tegra18-bridge 2140000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.079556] tegra18-bridge 2140000.axip2p: enabled timeout = 11155000
[ 4.079558] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 4.079615] tegra18-bridge 2150000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.079621] tegra18-bridge 2150000.axip2p: enabled timeout = 11155000
[ 4.079623] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 4.079683] tegra18-bridge 2160000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.079689] tegra18-bridge 2160000.axip2p: enabled timeout = 11155000
[ 4.079692] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 4.079751] tegra18-bridge 2170000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.079757] tegra18-bridge 2170000.axip2p: enabled timeout = 11155000
[ 4.079760] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 4.079819] tegra18-bridge 2180000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.079828] tegra18-bridge 2180000.axip2p: enabled timeout = 11155000
[ 4.079831] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 4.079892] tegra18-bridge 2190000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.079897] tegra18-bridge 2190000.axip2p: enabled timeout = 11155000
[ 4.079919] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 4.079992] tegra18_a57_serr_init: on CPU 2 a Denver Core
[ 4.080057] tegra18x_actmon d230000.actmon: in actmon_register()...
[ 4.080695] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 4.081237] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 4.081352] denver_knobs_init:MTS_VERSION:47926945
[ 4.081777] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 4.085773] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 4.086620] nvpmodel: initialized successfully
[ 4.088620] trusty-virtio trusty:virtio: initializing
[ 4.088817] trusty_ipc virtio0: vring0: va(pa) ffffffc1e69f2000(0) qsz 32 notifyid 1
[ 4.088826] trusty_ipc virtio0: vring1: va(pa) ffffffc1e69f4000(0) qsz 32 notifyid 2
[ 4.088941] trusty-virtio trusty:virtio: initializing done
[ 4.089174] trusty_ipc virtio0: is online
[ 4.090820] usbcore: registered new interface driver snd-usb-audio
[ 4.097884] gpio tegra-gpio wake71 for gpio=125(P:5)
[ 4.097946] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 4.119248] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 4.119424] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 4.131682] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[ 4.136847] OPE platform probe
[ 4.136985] OPE platform probe successful
[ 4.142347] random: crng init done
[ 4.148076] mmc0: periodic cache flush enabled
[ 4.148089] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 4.148436] ata1: SATA link down (SStatus 0 SControl 300)
[ 4.148609] mmcblk0: mmc0:0001 DG4032 29.1 GiB
[ 4.148857] mmcblk0boot0: mmc0:0001 DG4032 partition 1 4.00 MiB
[ 4.149146] mmcblk0boot1: mmc0:0001 DG4032 partition 2 4.00 MiB
[ 4.149388] mmcblk0rpmb: mmc0:0001 DG4032 partition 3 4.00 MiB
[ 4.153250] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29 p30 p31 p32 p33
[ 4.211324] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 4.211414] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 4.211500] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 4.211589] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 4.211671] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 4.211756] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 4.212389] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 4.212503] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 4.212602] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 4.212693] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 4.212775] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 4.212856] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 4.212941] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 4.213047] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 4.213133] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 4.213217] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 4.213299] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 4.213386] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 4.213493] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 4.213582] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 4.253823] usb 1-2: new low-speed USB device number 2 using tegra-xusb
[ 4.255424] u32 classifier
[ 4.255428] Actions configured
[ 4.255527] Initializing XFRM netlink socket
[ 4.257187] NET: Registered protocol family 10
[ 4.258476] NET: Registered protocol family 17
[ 4.258489] NET: Registered protocol family 15
[ 4.258694] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 4.258772] Bluetooth: RFCOMM socket layer initialized
[ 4.258800] Bluetooth: RFCOMM ver 1.11
[ 4.258806] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.258812] Bluetooth: HIDP socket layer initialized
[ 4.258832] 9pnet: Installing 9P2000 support
[ 4.258876] Key type dns_resolver registered
[ 4.260083] Registered cp15_barrier emulation handler
[ 4.261123] Registered setend emulation handler
[ 4.262641] registered taskstats version 1
[ 4.267185] isp 15600000.isp: initialized
[ 4.272242] nvcsi 150c0000.nvcsi: initialized
[ 4.279402] gpio tegra-gpio-aon wake29 for gpio=56(FF:0)
[ 4.279488] gpio tegra-gpio-aon wake67 for gpio=57(FF:1)
[ 4.279570] gpio tegra-gpio-aon wake68 for gpio=58(FF:2)
[ 4.279737] input: gpio-keys as /devices/gpio-keys/input/input2
[ 4.280183] tegra-vi4 15700000.vi: initialized
[ 4.281182] tegra-vi4 15700000.vi: ep of_device is not enabled /host1x/vi@15700000/ports/port@0/endpoint.
[ 4.281185] tegra-vi4 15700000.vi: ep of_device is not enabled /host1x/vi@15700000/ports/port@1/endpoint.
[ 4.288339] usb 1-2: New USB device found, idVendor=046a, idProduct=0011
[ 4.288346] usb 1-2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.302891] input: HID 046a:0011 as /devices/3530000.xhci/usb1/1-2/1-2:1.0/0003:046A:0011.0001/input/input3
[ 4.311139] tegra_rtc c2a0000.rtc: setting system clock to 2022-03-22 11:26:27 UTC (1647948387)
[ 4.312831] mmcblk mmc0:0001: Card claimed for testing.
[ 4.344817] mmc1: hw tuning done ...
[ 4.352304] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 4.354506] bpmp: mounted debugfs mirror
[ 4.356474] bwmgr: missing cdev-type property
[ 4.361947] spmic-ldo0: disabling
[ 4.362185] spmic-ldo1: disabling
[ 4.362305] hid-generic 0003:046A:0011.0001: input,hidraw0: USB HID v1.11 Keyboard [HID 046a:0011] on usb-3530000.xhci-2/input0
[ 4.362369] en-vdd-sd: disabling
[ 4.362373] vdd-usb0-5v: disabling
[ 4.362375] vdd-usb1-5v: disabling
[ 4.362378] en-vdd-disp-3v3: disabling
[ 4.362380] en-mdm-pwr-3v7: disabling
[ 4.362383] en-vdd-disp-1v8: disabling
[ 4.362385] en-vdd-cam-hv-2v8: disabling
[ 4.362387] vdd-fan: disabling
[ 4.362409] vdd-3v3: disabling
[ 4.362411] en-vdd-vcm-2v8: disabling
[ 4.362414] vdd-usb2-5v: disabling
[ 4.362416] vdd-sys-bl: disabling
[ 4.362419] ALSA device list:
[ 4.362422] #0: tegra-hda at 0x3518000 irq 384
[ 4.362424] #1: tegra-snd-t186ref-mobile-rt565x
[ 4.481794] usb 1-3: new high-speed USB device number 3 using tegra-xusb
[ 4.502358] usb 1-3: New USB device found, idVendor=045b, idProduct=0209
[ 4.502363] usb 1-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.503155] hub 1-3:1.0: USB hub found
[ 4.503240] hub 1-3:1.0: 4 ports detected
[ 4.645821] usb 1-3: usb_suspend_both: status 0
[ 7.046589] Wake76 for irq=199
[ 7.046592] Wake77 for irq=199
[ 7.046593] Wake78 for irq=199
[ 7.046595] Wake79 for irq=199
[ 7.046596] Wake80 for irq=199
[ 7.046598] Wake81 for irq=199
[ 7.046599] Wake82 for irq=199
[ 7.046634] tegra-xusb 3530000.xhci: Upgrade port 0 to USB3.0
[ 7.046639] tegra-xusb 3530000.xhci: Upgrade port 1 to USB3.0
[ 7.388851] usb 2-2: new SuperSpeed USB device number 2 using tegra-xusb
[ 7.457148] usb 2-2: New USB device found, idVendor=045b, idProduct=0210
[ 7.457153] usb 2-2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 7.524211] hub 2-2:1.0: USB hub found
[ 7.534481] hub 2-2:1.0: 4 ports detected
[ 7.865785] usb 2-2: usb_suspend_both: status 0
[ 7.865979] usb usb2: usb_suspend_both: status 0
[ 8.622173] extcon-disp-state external-connection:disp-state: cable 51 state 1
[ 8.623977] Freeing unused kernel memory: 8576K
[ 8.636364] Extcon HDMI: HPD enabled
[ 8.636389] tegradc 15210000.nvdisplay: hdmi: plugged
[ 8.693825] No root-device: Mount failed
