Movement, textures and mdl material not applying or refreshing
System used Intel(R) Core™ i7-7700K CPU @ 4.20GHz, Ram 64,0 GB, NVIDIA GeForce RTX 3090, Windows 10 64bits, Autodesk Maya 2022, Autodesk 3dsMax 2022, Create and Unreal 4.27.0
All the applications except 3dsMax were working perfectly, if I moved any object in the scene from Maya, unreal or create, it was moving in all applications at the same time, but when I tried to move the objects in 3dsMax, inside this program it moved, but did not move in any other program, the other thing was that 3dsMax never showed the textures or materials from the USD scene, not even in render.
Thank you for reporting this, we’ll look into it!
–Aron
Thank you for your time and effort!
Tracking Note: Development team has created an internal ticket (OM-36806)
Hi, francisco
does only this scene not work, or all scenes ? for example, create a simple cube and move it
what type is this scene file ? usd, usda or a maya or max scene file
Since I updated Create and the connectors to the least version, the only software that does not interact is Create, and 3dsMax is still not showing the textures or materials from the USD scene, not even in render.
